WhiteInk72
I just have a question regarding the disclaimer. Is there a specific reason for not using an older drive? I'm only aware certain old drives won't work with 4k blu-rays, but is there something I'm missing? I have a Samsung SE-506CB/RSBD and judging by the disclaimers, it really sounds like I might break it or smth.
PM sent.ClueMeIN wrote: ↑Fri Dec 05, 2025 7:04 amI am a complete rookie with this. I followed rule one and tried to read extensively, but I am lost on getting my particular drive UHD friendly. I would really appreciate a kind soul helping me out. I feel confident I can do what's needed if I have the right files and some very basic instructions.
Here is my info:
OS device name: K:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E101
Serial number: XXXXXXXXXXX
Firmware date: 2015-10-20
Drive platform: RS8600
Firmware version: E101/ID76
Thank you in advance for the help!
PM sent.ahaddadin wrote: ↑Fri Dec 05, 2025 12:48 amHello just got this drive but it won’t read uhd disks
Verbatim 43888 Pioneer UD03, UHD discs spin then ‘no disc inserted’, regular Blu-ray works fine”:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number:
Firmware date: 2020-06-15
Drive platform: RS8511
Firmware version: 1.14
OS device name: E:
Product: BD-RE BU40N
Revision: 1.02
Serial number: MO1P5691624
Bus encryption flags: 1F
Harware support: Yes
Firmware support: No
Firmware version: 1.02
No disc insertedExecuted:
C:\Program Files (x86)\MakeMKV>makemkvcon64.exe f --all-yes -d E: rawflash -i "C:\Users\Glenn\Downloads\The all you need firmware pack\The all you need firmware pack\LG slim BU40N\HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin"
Reading input file C:\Users\Glenn\Downloads\The all you need firmware pack\The all you need firmware pack\LG slim BU40N\HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Current Drive ID: HL-DT-ST_BD-RE_BU40N_1.02_212012011716_MO1P5691624
100% Operation finished
Done successfullyDrive still shows as 1.02 in MakeMkV..... I waited, I rebooted. Ran the flash again. Still 1.02.
Is it possible it is encrypted firmware 1.02?
Halp pls.
If this is an Archgon, you must take the drive out of the enclosure to flash.ANZAC wrote: ↑Sat Dec 06, 2025 5:52 amCode: Select all
Drive Information OS device name: E: Manufacturer: HL-DT-ST Product: BD-RE BU40N Revision: 1.02 Serial number: MO1P5691624 Firmware date: 2120-12-01 17:16 Bus encryption flags: 1F LibreDrive Information Status: Possible (with patched firmware) Drive platform: MT1959 Harware support: Yes Firmware support: No Firmware type: Original (patched version available) Firmware version: 1.02 DVD all regions: Possible (with patched firmware) BD raw data read: Possible (with patched firmware) BD raw metadata read: Possible (with patched firmware) Unrestricted read speed: Possible (with patched firmware) No disc inserted
Executed:Code: Select all
C:\Program Files (x86)\MakeMKV>makemkvcon64.exe f --all-yes -d E: rawflash -i "C:\Users\Glenn\Downloads\The all you need firmware pack\The all you need firmware pack\LG slim BU40N\HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin" Reading input file C:\Users\Glenn\Downloads\The all you need firmware pack\The all you need firmware pack\LG slim BU40N\HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin Flashing flags = 0x0 : 0 0 0 0 : ---- ---- ---- ---- Current Drive ID: HL-DT-ST_BD-RE_BU40N_1.02_212012011716_MO1P5691624 Ready to write drive flash memory. (auto confirmed) Operation started: Sending flash image to drive 100% Operation finished Operation started: Programming flash 100% Operation finished Done successfully
Halp pls.
I snagged a Hitachi/LG BU40N off Amazon recently to replace my defunct BH16NS55 (RIP following 7 years of service). It came with firmware version 1.05 but a quick flash to 1.03MK and I'm off to the races.
I'm glad to be back to two drives again.
Hello!
I'm a long user of your software and first timer when it comes to Blu-Rays. I just have a brand new supported ASUS drive with firmware in revision 3.11. I'm preparing for flashing the drive according to the instruction. I downloaded last supported Linux version binary, 1.17.7, but when I tried to display the drive's identification, I see something is a bit off. According to the docs:
Is "dev_21:3" identfier supported by the tool? I don't know if makemkvcon will understand this different syntax and follow smoothly. Thanks in advance for your support!
In my case I see the identifier to be a bit different:6. type "./makemkvcon f -l"
This will show your drive identifier should look similar to this ''/IOBDServices/D5D25996'
Found 1 drives(s)
00: /IOBDServices/D5D25996, /dev/rdisk3, /dev/rdisk3
HL-DT-ST_BD-RE_BU40N_1.01_211910161032_MOFK6283224
lukasz@ryzen ~/makemkv-bin-1.17.7/bin/amd64 $ ./makemkvcon f -l
Found 1 drives(s)
00: dev_21:3, /dev/sr0, /dev/sr0
ASUS_BW-16D1HT_3.11_212012011759_KLZP84G1350Re: Ultimate UHD Drives Flashing Guide Updated 2025
Verbatim branded.MartyMcNuts wrote: ↑Sat Dec 06, 2025 9:55 amIf this is an Archgon, you must take the drive out of the enclosure to flash.ANZAC wrote: ↑Sat Dec 06, 2025 5:52 amCode: Select all
Halp pls.
The YouTube how-to video said BU40N 1.04 onwards are encrypted.....
But then, looking at the encrypted firmware list it shows this:
HL-DT-ST-BD-RE_BU40N_1.02_212012011716_MO3L91F0715.bin
And my drive reports this:
Revision: 1.02
The serial numbers are different, but the dates look the same (though the filename formatting isn't the same).
Does this mean it is encrypted? Why can't the flashing program just detect if it is encrypted?
Thanks in advance.
Firmware dated 2020+ is encrypted, so yes, it is encrypted. I have never seen 1.02 on a Verbatim drive before. Always been 1.04 or 1.05 and I've flashed hundreds of them. Only ever seen 1.02 on the Archgon.ANZAC wrote: ↑Sat Dec 06, 2025 3:43 pmThe YouTube how-to video said BU40N 1.04 onwards are encrypted.....
Revision: 1.02
Thanks in advance.
Well, "2120" is year 2021?MartyMcNuts wrote: ↑Sat Dec 06, 2025 11:27 pmFirmware dated 2020+ is encrypted, so yes, it is encrypted. I have never seen 1.02 on a Verbatim drive before. Always been 1.04 or 1.05 and I've flashed hundreds of them. Only ever seen 1.02 on the Archgon.
Anyway, that solved it. Thanks for help.
(This was a Verbatim from NewEgg).
No, 2120 is 2020. The second digit should be a zero.ANZAC wrote: ↑Sun Dec 07, 2025 4:34 amWell, "2120" is year 2021?MartyMcNuts wrote: ↑Sat Dec 06, 2025 11:27 pmFirmware dated 2020+ is encrypted, so yes, it is encrypted. I have never seen 1.02 on a Verbatim drive before. Always been 1.04 or 1.05 and I've flashed hundreds of them. Only ever seen 1.02 on the Archgon.
I would like to flash my Pioneer XD05S if possible. Here's the info from MakeMKV:
Product: BD-RW BDR-XD05
Revision: 3.01
Serial number:
Firmware date: 2014-12-26
Highest AACS version: 76
Drive platform: RS8231
Firmware name: PIONEER BDR-XD05
Firmware version: 3.01/ID34
Revision: 3.01
Serial number:
Just email me your makemkv drive info section like that see belowBourney0 wrote: ↑Mon Dec 08, 2025 10:01 pmI would like to flash my Pioneer XD05S if possible. Here's the info from MakeMKV:
Revision: 3.01
Serial number:
I have been trying to find an Asus BW-16D1HT to flash for about 2 months. They used to be $99, then went up to $129, then several hundred dollars, and now for the past month there is absolutely none to be had anywhere. Can anyone confirm or deny if these have been discontinued? If not, is there any idea when they will be available again. If they are gone, what is a good alternative that is readily available?
