SDF update November 2025
I5ooo
Re: SDF update November 2025
Post by I5ooo » Sat Dec 06, 2025 11:05 am
Hello Marty,
Just to let you know that I have flashed my Verbatim a total of 4 times now as I was trying out my lifetime AnydvdHD and I setlled on your BU40N 1.0 firmware after listening to your explanation on your provided firmwares. I manily deal with BD and DVD and very rarely touch UHD. I really appreciate your work and that of your whole development team! Happy holidays! Cheers :mrgreen:
drgonzo
Post by drgonzo » Sun Dec 07, 2025 3:41 pm
Sorry for the newbie questions, but I was wondering what happens after you send your firmware dump to support@makemkv.com?
A couple of weeks ago I sent mine in from my Pioneer BDR-X13JX revision 1.04, which was one of the drives listed as needing a dump in the first post, but then I never heard anything back or saw MKV download a new sdf.bin file.
I wasn't sure if that was usual or if there was something wrong with the one I sent it.
nicholfd
Post by nicholfd » Sun Dec 07, 2025 4:13 pm
drgonzo wrote: Sun Dec 07, 2025 3:41 pm Sorry for the newbie questions, but I was wondering what happens after you send your firmware dump to support@makemkv.com?
I have never received any feedback when submitting svq or firmware dumps. I usually wait a day or two (sometimes takes a little longer) & just try again.
Make sure your MakeMKV app has internet access enabled in the settings. The new download is automatic and sometimes happens pretty quickly - easy to miss.
Make sure the drive has been power cycled & try a disc again.
drgonzo
Post by drgonzo » Sun Dec 07, 2025 4:25 pm
nicholfd wrote: Sun Dec 07, 2025 4:13 pm
Thanks! I made sure internet access was enabled, but didn't see any download, so I manually downloaded the sdf.bin file. I then power-cycled the drive, put a disc in, and fired up MakeMKV. I watched the sdf.bin file disappear from my MakeMKV folder, but the date on my _private_data.tar didn't change, so I don't think the sdf.bin file contained any updates?
So I went ahead and emailed support with my firmware dump into support again.
Right now, MakeMKV shows the following:
Manufacturer: PIONEER
Product: BD-RW BDR-X13JX
Revision: 1.04
Serial number:
Firmware date: 2023-08-01
Highest AACS version: 76
Firmware version: ID72
Lorenz
Post by Lorenz » Wed Dec 10, 2025 12:26 pm
Hi there!
I was testing the new MakeMKV 1.18.2 for Windows using a Pioneer BDR-X12EBK drive I had on hand. Unfortunately, it's running a 2023 firmware, and I'm still hoping it will one day support UHD, but at the moment, it doesn't even seem ready for LibreDrive.
When I connect it with the new SDF drives, MakeMKV keeps saying there's no SDF input for the drive and generates a dump file. I've sent the file to support@makemkv.com, but the file size is smaller than 1KB. Shouldn't it be larger?
I'm sharing the MakeMKV information and log for more details:
Drive information
OS device name: H:
Product: BD-RW BDR-X12
Revision: 1.07
Serial number: AFDL000137WL
Highest AACS version: 47
Drive platform: Pioneer RS9000
Firmware version: ID56
Log
No  SDF v0a3: PIONEER_BD-RW___BDR-X12_1.07_AFDL000137WL
DEBUG: Code 3 at R/Ru3B(Mxaw 4&z'5FC}$>4::29395310
SDF auto v0a3: PIONEER_BD-RW___BDR-X12_1.07_AFDL000137WL
003332:0000 Saved FW dump file as file://C:/Users/dalas/.MakeMKV/dump_FW_800BD86CCFEE232ED882.tgz
003347:0000 Please send the file "file://C:/Users/dalas/.MakeMKV/dump_FW_800BD86CCFEE232ED882.tgz" to support@makemkv.com
DEBUG: Code 0 at lS]g`,`;]*O'8w*t:213136746
SDF id v0a3: PIONEER_BD-RW___BDR-X12_1.07_AFDL000137WL
Post by dcoke22 » Thu Dec 11, 2025 6:32 pm
Lorenz wrote: Wed Dec 10, 2025 12:26 pm When I connect it with the new SDF drives, MakeMKV keeps saying there's no SDF input for the drive and generates a dump file. I've sent the file to support@makemkv.com, but the file size is smaller than 1KB. Shouldn't it be larger?
https://forum.makemkv.com/forum/viewtopic.php?p=187311#p187311
In that post, Mike said a firmware dump is around 2MB.
Lorenz
Post by Lorenz » Thu Dec 11, 2025 7:31 pm
Thanks for the reply. Yes, that's what I was afraid of.
Does anyone know how I could extract that complete dump so I can send it?
I've seen references to the "sdftool" utility, but from what I've seen, it doesn't work with Pioneer devices.
Sorry for these newbie questions, and thanks again.
drgonzo
Post by drgonzo » Thu Dec 11, 2025 9:05 pm
dcoke22 wrote: Thu Dec 11, 2025 6:32 pm
FWIW, when MakeMKV made a dump for my Pioneer BD-RW-BDR-X13JX that file was just about 1MB. When I unzipped it though, it contained another file, "dump_full_PIONEER_BD-RW__BDR-X13JX_1.04_CJDL000525WL.tar," which was 4.3MB in size.
I'm not sure if that's correct or not. I've not heard anything back, and MakeMKV hasn't downloaded a new SDF.bin file since I emailed it in.
Post by MartyMcNuts » Thu Dec 11, 2025 10:38 pm
Lorenz wrote: Thu Dec 11, 2025 7:31 pm Thanks for the reply. Yes, that's what I was afraid of.
Before you do anything, look inside the dump. When I had one, the file inside was 4MB. They just compress really well.
Lorenz
Post by Lorenz » Thu Dec 11, 2025 11:05 pm
Oh, yes, I did that and I found a file "dump_info_PIONEER_BD-RW___BDR-X12_1.07_AFDL000137WL.tar" which is 3Kb.
I was expecting a "dump_full_XXXXX" file but it seems the MakeMKV is not reading it.
Post by dcoke22 » Fri Dec 12, 2025 5:19 am
Lorenz wrote: Thu Dec 11, 2025 11:05 pm
Personally, I've never had a drive that MakeMKV has made a dump for, so I'm just guessing. I suggest you try removing _private_data.tar, any .tgz files, keydb.cfg (if you have it), and sdf.bin (if you have it) from your MakeMKV data directory. You don't have to (and probably shouldn't) delete those files, just move them out of the folder. You can leave the .xml and .conf files. Then I would make sure to power cycle your drive and probably reboot your computer just for completeness. If the drive is inside your computer, power your computer off for a few minutes just to make sure the drive gets power cycled.
Then start everything up, put a blu-ray in your drive, let the OS see it, then launch MakeMKV. I believe MakeMKV will redownload everything it needs and it should try again to produce a firmware dump for your drive.
If that doesn't work, you might have to download sdf.bin manually, put it in the data directory, and restart MakeMKV.
MartyMcNuts might have a better idea of what to try than me. I'm just making an educated guess. :)
Post by MartyMcNuts » Fri Dec 12, 2025 5:49 am
dcoke22 wrote: Fri Dec 12, 2025 5:19 am
Sounds good to me!
Lorenz
Post by Lorenz » Fri Dec 12, 2025 2:25 pm
dcoke22 wrote: Fri Dec 12, 2025 5:19 am Personally, I've never had a drive that MakeMKV has made a dump for, so I'm just guessing. I suggest you try removing _private_data.tar, any .tgz files, keydb.cfg (if you have it), and sdf.bin (if you have it) from your MakeMKV data directory. You don't have to (and probably shouldn't) delete those files, just move them out of the folder. You can leave the .xml and .conf files. Then I would make sure to power cycle your drive and probably reboot your computer just for completeness. If the drive is inside your computer, power your computer off for a few minutes just to make sure the drive gets power cycled.
Then start everything up, put a Blu-ray in your drive, let the OS see it, then launch MakeMKV. I believe MakeMKV will redownload everything it needs and it should try again to produce a firmware dump for your drive.
Thank you both for your advice! The drive is an external one and has been unplugged for hours. After that, I did:
1. Cleared the ".MakeMKV" directory.
2. Plugged in the drive with a br in it.
3. Waited for the OS to see it.
4. Launched MakeMKV.
The result has been the same as before. Same files and same log.
The only difference happened inside the "_private_data.tar", probably because the current sfd.bin is now newer than two days ago.
After that, I did:
5. Unplugged the drive for several minutes.
6. Downloaded, manually, the file from https://www.makemkv.com/svq/sdf.bin and placed it into the ".MakeMKV" directory.
7. Renamed the "dump_FW" file to force a re-dump.
8. Plugged in the drive with a br in it.
9. Waited for the OS to see it.
10. Launched MakeMKV.
Again, same log and same dump.
Any other ideas? : )
Post by MartyMcNuts » Fri Dec 12, 2025 11:59 pm
Lorenz wrote: Fri Dec 12, 2025 2:25 pm
After that, I did:
Email Mike at support@makemkv.com and say exactly what you have tried above and he might be able to assist you further.
greg1wto66
Post by greg1wto66 » Wed Dec 17, 2025 6:52 am
Have you tried to delete makemkv folder where the fw dump and sdf bin is located ? It should recreate folder and make full dump once you run mmkv again and insert uhd disk.
I had a same issue with my drive. It worked afterwards
