Pioneer BDR-S09XLT LibreDrive ready but not ripping UHD-discs
Re: Pioneer BDR-S09XLT LibreDrive ready but not ripping UHD-discs
#136 Post by Coopervid » Wed Dec 03, 2025 4:23 pm
maximum wrote: Wed Dec 03, 2025 3:58 pm Hello, I have the same problem.
Manufacturer: PIONEER
Product: BD-RW BDR-S09
Revision: 1.55
Serial number: NCDL008423WL
Firmware date: 2023-02-16
Drive platform: RS8600
Firmware version: 1.55/ID43
PM sent.
#137 Post by MartyMcNuts » Wed Dec 03, 2025 10:30 pm
Coopervid wrote: Wed Dec 03, 2025 4:23 pm
Revision: 1.55
PM sent.
This is too new.
#138 Post by Coopervid » Wed Dec 03, 2025 10:33 pm
Marty is right. Not flashable. I will delete the PM if unread.
Edit: PM deleted.
loubd
#139 Post by loubd » Fri Dec 05, 2025 11:31 pm
Coopervid wrote: Sun Aug 31, 2025 3:31 pm
loubd wrote: Sun Aug 31, 2025 2:41 am Fresh user in the forum. I would love to be able to use my drive to rip UHD and hope you can help me to flash it.
Here is the information of the drive.
OS device name: E:
Current profile: DVD-ROM
Revision: 1.34
Serial number:
Firmware date: 2016-04-25
Firmware version: 1.34/ID43
PM sent.
Thanks a lot, tried de FW yesterday and worked fine. Not sure if the drive is sleep bug free though.
I had some problem when reading a disc and solved it by ejecting and loading it again but I guess it has nothing to do with that bug.
#140 Post by MartyMcNuts » Sat Dec 06, 2025 3:35 am
loubd wrote: Fri Dec 05, 2025 11:31 pm
OS device name: E:
Revision: 1.34
Serial number:
PM sent.
Pioneer drives don't have a sleep bug.
ripposaur
#141 Post by ripposaur » Sat Dec 06, 2025 11:57 pm
I hope this is the correct thread.
I have 2 of these drives, that are Labeled Pioneer BDR-S09XLB, with different original Firmwares (1.30 and 1.34):
Drive 1:
Laufwerksinformation
OS-Gerätename: I:
Produzent: PIONEER
Produkt: BD-RW BDR-S09
Revision: 1.34
Serienummer: --------------
Firmware-Datum: 2016-04-25
Highest AACS version: 77
Drive 2:
OS-Gerätename: I:
Produzent: PIONEER
Revision: 1.30
Serienummer: ---------------
Firmware-Datum: 2014-12-05
Firmware version: 1.30/ID43
Can you help me with enabling UHD for them?
#142 Post by Coopervid » Sun Dec 07, 2025 10:51 am
ripposaur wrote: Sat Dec 06, 2025 11:57 pm Hello,
Drive 1:
OS-Gerätename: I:
Produzent: PIONEER
Revision: 1.34
Drive 2:
OS-Gerätename: I:
Produzent: PIONEER
Revision: 1.30
PM sent. Works for both drives.
ripposaur
#143 Post by ripposaur » Sun Dec 07, 2025 1:29 pm
It works. Thanks you very much!
Mothy2501
#144 Post by Mothy2501 » Tue Dec 09, 2025 10:19 pm
I too Bought a Pioneer BDR-S09XLT looking for UHD ripping and playback firmware can anyone help
I need to check which firmware i am currently running but flying blind
#145 Post by MartyMcNuts » Tue Dec 09, 2025 11:11 pm
Mothy2501 wrote: Tue Dec 09, 2025 10:19 pm I too Bought a Pioneer BDR-S09XLT looking for UHD ripping and playback firmware can anyone help
Copy and paste the MakeMKV drive info and libredrive info sections.
Mothy2501
#146 Post by Mothy2501 » Wed Dec 10, 2025 3:30 pm
Hiya to whom ever can help with getting this drive (Pioneer BDR-S09XLT) UHD ready if its possible my MakeMKV info is
OS device name: L:
Revision: 1.52
Serial number: QHDL026384WL
Firmware date: 2019-01-11
Highest AACS version: 62
Firmware version: 1.52/ID43
Anyhelp would be appreciated as I bought this drive in 2018 hoping it would read UHD discs
#147 Post by Coopervid » Wed Dec 10, 2025 3:39 pm
Mothy2501 wrote: Wed Dec 10, 2025 3:30 pm Hiya to whom ever can help with getting this drive (Pioneer BDR-S09XLT) UHD ready if its possible my MakeMKV info is
OS device name: L:
Revision: 1.52
PM is coming since you posted now the required information.
Mothy2501
#148 Post by Mothy2501 » Wed Dec 10, 2025 4:02 pm
THANK YOU SO MUCH!!!
Just tried the drive with a UHD disc and VLC and its working I can now get rid of my UHD Bluray TV Player that doesn't work properly thank you so much!!
bigfatmonk
#149 Post by bigfatmonk » Fri Dec 19, 2025 6:48 pm
I think my message might have been missed when I posted a while ago. I would still like help enabling UHD on my drive if possible. Thanks!
bigfatmonk wrote: Sun Feb 23, 2025 10:26 pm Hey! Could you pleas help me enable UHD on my drive?
Revision: 1.52
Serial number: ...
Highest AACS version: 16
#150 Post by Coopervid » Fri Dec 19, 2025 8:25 pm
bigfatmonk wrote: Fri Dec 19, 2025 6:48 pm I think my message might have been missed when I posted a while ago. I would still like help enabling UHD on my drive if possible. Thanks!
Revision: 1.52
Serial number: ...
PM sent. I missed your post.
