AACS v82 Dump - Jackie Brown [IMPRINT]
Unable to rip the AU Jackie Brown blu-ray. Dump attached. Thanks
- MKB_v82_Jackie_Brown_9AFA.tgz
- (241.93 KiB) Downloaded 75 times
Re: AACS v82 Dump - Jackie Brown [IMPRINT]
You should email the dump to svq@makemkv.com so a key can be created for MakeMKV's built in hashed key mechanism. A few days after emailing the dump, try the disc again and if a key is available, MakeMKV will download it automatically in the background.
There is a separate second decryption mechanism that MakeMKV supports, the public KeyDB. To contribute to the public KeyDB, use the template and follow the instructions in the first post in the Public KeyDB Disc Submissions thread.
I have and the hash has already been done. so fast. thanks!
