Request to enable LibreDrive on ASUS BW-16D1X-U
newsoftheworld
Post by newsoftheworld »
Hi All,
Apologies in advance if I've posted this in the wrong area. I have an ASUS BW-16D1X-U. I'd love to have some assistance please to see if I it is possible to change the firmware on this drive to enable LibreDrive?
I would be using a Mac to run any flashing software. Also is it possible to save the existing firmware so that I could always go back to that if the drive started misbehaving, or is that not possible?
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Serial number:
Firmware date: 2120-12-02 11:14
Bus encryption flags: 1F
Highest AACS version: 75
Thank you
Re: Request to enable LibreDrive on ASUS BW-16D1X-U
newsoftheworld wrote: Fri Dec 05, 2025 9:28 pm Hi All,
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Serial number:
Thank you
viewtopic.php?f=16&t=19634
newsoftheworld
Hi Coopervid,
Thank you for your reply. I've tried to make sense of the 'Ultimate UHD Drives Flashing Guide Updated 2025'
Can I confirm if my drive is capable of being patched please? I just want to get some guidance so that I don't damage the drive or do something I regret.
I was going to use the SDFtool Flasher but it looks like that windows only and I'm on a Mac. Do I use some Mac software or just command line entry in Terminal. I'd prefer a GUI software if available.
I've downloaded the files from here:
https://drive.google.com/file/d/1HRnbXi ... sp=sharing
Can you advise me which one do I use? The only ASUS one I can see is 'ASUS-BW-16D1HT-3.10-WM01601-211901041014.bin' is this the one I need?
Any leadership you can provide to steer me away from the pitfalls would be appreciated. Thank you.
newsoftheworld wrote: Fri Dec 05, 2025 10:05 pm Hi Coopervid,
ASUS don't make drives. The drive inside your enclosure is a LG. Flash it to LG WH16NS60 1.02-MK firmware. This is the recommended firmware which reads faster and removes the sleep bug affecting UHD discs.
Yes, on Mac you can use terminal or SDFtool Flasher if using a compatible VM.
newsoftheworld
Hi MartyMcNuts,
Thank you for your reply. I don't have VM of windows on my Mac or access to a windows machine so will be using Terminal on the Mac which I have very little experience of. So I have done this so far:
1) I've copied the file 'HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin' to the tmp folder. Is this the correct file?
2) I've navigated to the location: /Applications/MakeMKV.app/Contents/MacOS/
3) I've located my IOBDServices identifier and mine is called EAAE8032
4) As I understand it I need to copy an sdf.bin file to the tmp folder next. When I look at the Ultimate UHD Drives Flashing Guide Updated 2025. There are links to both ASUS and LG. Not sure which I need. Is this the correct file? https://www.mediafire.com/file/mezq26ac ... 9.zip/file
5) when I have this sdf.bin file and added it to the tmp folder am I correct that all I need do next is to paste the following command:
./makemkvcon f -d /IOBDServices/EAAE8032 -f /tmp/sdf.bin rawflash main -i /tmp/HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
Kind Regards,
David
newsoftheworld wrote: Sat Dec 06, 2025 2:04 pm Hi MartyMcNuts,
Kind Regards,
David
enc not main
newsoftheworld
Thank you Billycar11,
so like this:
./makemkvcon f -d /IOBDServices/EAAE8032 -f /tmp/sdf.bin rawflash enc -i /tmp/HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
As I understand it I need to copy an sdf.bin file to the tmp folder next. When I look at the Ultimate UHD Drives Flashing Guide Updated 2025. There are links to both ASUS and LG. Not sure which I need?
Can you direct me to the location of the correct sdf.bin file that I need please?
Kind Regards
newsoftheworld
HI All,
I found the sdf.bin file (on the Ultimate UHD Drives Flashing Guide Updated 2025 (for other Mac users it's not in the Unlocked Flashers, Downgrade Enabled Firmware and MK Firmware section but in the How To Flash Videos and commands section below it).
Everything went very smoothly. Thank you all. The only thing I thought I'd check with you all is that I observed an error code:
'Command produced error code 0x82062900'
Can anyone confirm please that this error code is nothing to be concerned about and all is well?
see below copy and paste from Terminal:
[Davids-iMac:MacOS root# ./makemkvcon f -1
Found 1 drives (s)
00: /IOBDServices/EAAE8032
ASUS_BW-16D1X-U_A105_212012021114_(Serial No Here)
[Davids-iMac:MacOS root# ./makemkvcon f -d /IOBDServices/EAAE8032 -f /tmp/sdf.bin] rawflash enc -i /tmp/HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
Reading input file /tmp/HL-DT-ST-BD-RE WH16NS60-1.02-NM00100-211810291936.bin
Flashing flags = 0x0: 0 0 0 0: ----
Current Drive ID: ASUS_BW-16D1X-U_A105_212012021114_KLSP4HJ3033 t Ready to write drive flash memory.
Type "yes" to continue,
"no" to abort
yes
• 100% Operation finished
_ Program Flash NG 06/29/00
In MakeMKV all looks good though:
Product: BD-RE WH16NS60
Revision: 1.02
Serial number: KLSP4HJ3033
Firmware version: 1.02
newsoftheworld wrote: Sat Dec 06, 2025 4:33 pm HI All,
Found 1 drives (s)
"no" to abort
yes
Revision: 1.02
Yep, that's fine. Nothing to worry about. The flash either worked or it didn't. From the info provided, it worked.
newsoftheworld
Hi MartyMcNuts,
Thank you for your reply and your support and advice. Good to know I can ignore the error. I tested the drive yesterday and it ripped a 4k of Get Carter (75gb) in just over an hour. The film played back fine.
Kind Regards,
David
