Can someone send me this firmware and kernel if that was also updated in this version? ID83 is the native version for my BDR-212UHBK. I've only been able to find 1.01 (it contained no kernel update) and 1.04 (contains both fw and kernel and is patched for downgrades and supported for Libredrive either)
PIONEER-BD-RW___BDR-212U-1.02-6023BC47-8F01ID83-20220307
SDF update November 2025
hollywoostars
Re: SDF update November 2025
I think I have a drive of interest but I'm not seeing any dump files generated. Can I manually generate a dump file or is there something I'm missing?mike admin wrote: Tue Nov 04, 2025 7:55 pm Below is a list of drives for which we do not have a firmware file. These drives are currently unsupported but will be enabled once we obtain a relevant firmware dump or firmware update file. Please send us the firmware dump if you have this drive.Code: Select all
PIONEER-BD-RW___BDR-212V-1.02-ACDL0061-8F00ID06-20220531.dat
Manufacturer: PIONEER
Product: BD-RW BDR-212V
Revision: 1.02
Serial number: XXXXXXXXXXXX
Firmware date: 2022-05-31
Bus encryption flags: 13
Highest AACS version: 68
Firmware version: ID06
Debug log started at Tue Dec 02 20:01:21 2025 , written by MakeMKV v1.18.2 win(x64-release)
001005:0000 MakeMKV v1.18.2 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\user/MakeMKV_log.txt
No SDF v0a3: PIONEER_BD-RW___BDR-212V_1.02_XXXXXXXXXXXX
DEBUG: Code 3 at R/Ru3B(Mxaw 4&z'5FC}$>4::29395310
SDF id v0a3: PIONEER_BD-RW___BDR-212V_1.02_XXXXXXXXXXXX
Application exited at Tue Dec 02 20:03:44 2025
Rojma
How can you rule it out as the problem if you haven't tried to clean the disc? If you clean the disc, and it still doesn't work, THEN you can rule it out as a problem. I've had plenty of discs that ripped just fine, sat in a case for a few years, and then when I had to re-rip them for whatever reason, they would no longer rip until I cleaned them. Usually, the culprit is off gassing of the plastics onto the disc while it's in the case.CmdrKodi wrote: Tue Dec 02, 2025 3:27 am
>Did you try cleaning the disc?
No. I don't have anything to clean with. It's not the problem, never has been. I don't smoke or have cats.
If you don't have the supplies to properly clean the discs, then go buy some instead of discounting the step. All you need is Isopropyl Alcohol and some microfiber cloths. I can't tell you the number of times this has solved problems for me.
Correlation doesn't equal causation. "High probability" doesn't equate to 100% causation. Part of troubleshooting issues is eliminating possible causes, no matter how unlikely YOU think they are. Having worked in technical support for 25+ years, I can't tell you the number of times where something simple the customer assumed wasn't the cause of the issue turned out to be the issue. Eliminate the easy stuff, then move on from there.CmdrKodi wrote: Tue Dec 02, 2025 3:27 am
>Just because the older drive still works fine doesn't automatically mean the optics aren't dirty.
Sure. And they became dirty just as I updated. That's seems high probability.
Clean lasers is the first response because it has fixed issues for a lot of users, including myself. Why do you want to skip the easy troubleshooting steps that might very likely resolve your problem and instead jump to more complex troubleshooting? You insinuate that we are hiding some type of advanced troubleshooting until you try the basic stuff. If you are such an expert and are dismissing our suggestions so easily, why don't YOU propose to us what you should try later?CmdrKodi wrote: Tue Dec 02, 2025 3:27 am
>If you continue to dismiss options provided without even trying them, you won't get much more help.
If "clean the lasers" is your first response, what are you saving for later?
You need to post your Makemkv info.haramia wrote: Tue Dec 02, 2025 5:12 pm Can someone send me this firmware and kernel if that was also updated in this version? ID83 is the native version for my BDR-212UHBK. I've only been able to find 1.01 (it contained no kernel update) and 1.04 (contains both fw and kernel and is patched for downgrades and supported for Libredrive either)
hollywoostars
It was in the bottom of my post. Is this what you're looking for?
Revision: 1.02
Here's the content of the log file generated by MakeMKV:
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\bravo/MakeMKV_log.txt
Revision: 1.02
PM sent.hollywoostars wrote: Tue Dec 02, 2025 11:41 pm It was in the bottom of my post. Is this what you're looking for?
Revision: 1.02
haramia
Why? I've flashed 1.01 (PIONEER-BD-RW___BDR-212U-1.01-DFAA920B-8F01ID83-20200721) and I see 1.02 in the supported firmware list but can't find it online.Coopervid wrote: Tue Dec 02, 2025 10:36 pmYou need to post your Makemkv info.haramia wrote: Tue Dec 02, 2025 5:12 pm Can someone send me this firmware and kernel if that was also updated in this version? ID83 is the native version for my BDR-212UHBK. I've only been able to find 1.01 (it contained no kernel update) and 1.04 (contains both fw and kernel and is patched for downgrades and supported for Libredrive either)
If you insert a blu-ray disc, a firmware dump should be created in the MakeMKV data directory for you to email in to support@makemkv.com.haramia wrote: Wed Dec 03, 2025 9:18 amWhy? I've flashed 1.01 (PIONEER-BD-RW___BDR-212U-1.01-DFAA920B-8F01ID83-20200721) and I see 1.02 in the supported firmware list but can't find it online.Coopervid wrote: Tue Dec 02, 2025 10:36 pmYou need to post your Makemkv info.haramia wrote: Tue Dec 02, 2025 5:12 pm Can someone send me this firmware and kernel if that was also updated in this version? ID83 is the native version for my BDR-212UHBK. I've only been able to find 1.01 (it contained no kernel update) and 1.04 (contains both fw and kernel and is patched for downgrades and supported for Libredrive either)
haramia
I'm requesting the firmware and kernel files if anyone have them.MartyMcNuts wrote: Wed Dec 03, 2025 9:40 amIf you insert a blu-ray disc, a firmware dump should be created in the MakeMKV data directory for you to email in to support@makemkv.com.
InigoMontoya
Thought I'd post my drive info to see if anyone could help. I've been reading through the forums and still find myself confused by the process. Ive added the new bin file to my .MakeMKV folder but still cant get any UHD disks to load. I have 2 pioneer drives. Any help would be appreciated.
1st Drive
Product: BD-RW BDR-XD05
Revision: 3.11
Serial number:
Firmware date: 2023-03-03
Highest AACS version: 81
Drive platform: RS8232
Firmware name: PIONEER BDR-XD05
Firmware version: 3.11/ID34
2nd Drive
Product: BD-RW BDR-XD08
Revision: 1.02
Serial number:
Firmware date: 2022-12-27
Drive platform: RS9330
Firmware name: PIONEER BDR-BDS8
Firmware version: 1.02
1st Drive
Revision: 3.11
Serial number:
2nd Drive
Revision: 1.02
Serial number:
Nope. Libredrive does not mean UHD compatibility. Both of these have firmware that is post 11/2022 and cannot be cross-flashed to UHD models for UHD compatibility at this stage.InigoMontoya wrote: Wed Dec 03, 2025 10:27 pm Thought I'd post my drive info to see if anyone could help. I've been reading through the forums and still find myself confused by the process. Ive added the new bin file to my .MakeMKV folder but still cant get any UHD disks to load. I have 2 pioneer drives. Any help would be appreciated.
1st Drive
Revision: 3.11
Serial number:
2nd Drive
Revision: 1.02
Serial number:
InigoMontoya
Yea. That's what I figured. Thanks for clearing that up. I guess the wait continues for me. Glad other people are benefiting from this!
I5ooo
Gidday sorry new to the forum;
I just wanted to thank Martin and the whole developers team for having provided the patch for my external Verbatim 43888 USA Amazon with the original firmware 1.05. Using your v1.3.6 SDFtool in my Win10 laptop and the two firmware files included in your pack file along with your clear guide and fantastic GIF I managed to patch it with your BU40N 1.03 MK firmware and its all good according to the beta MKV software.
Also I respectfuly wanted to ask you if is there any good advantage in using the BU40N 1.00 firmare instead of your BU40N 1.03 MK firmware and whether there is a limit on the number of times I can reflash from the 1.03MK to the BU40N 1.00 ?
MK firmware is only compatible with MakeMKV and Xrevela for UHD discs. If you want to use other ripping software for UHD discs, BU40N 1.00 is the firmware to use. I would not go flashing it any more than you have to. Yes, there is a limit but am unsure of how many flashes that is.I5ooo wrote: Fri Dec 05, 2025 5:13 am Gidday sorry new to the forum;
Cheers![]()
I5ooo
Hello Marty,
I really appreciate your prompt explanation and please excuse the typo on your name in my previous post. Cheers
