No success with LG WH12LS39
gawk9876
#1 Post by gawk9876 » Wed Feb 29, 2012 5:30 am
I just bought the LG WH12LS39 and I am trying to use it on my Mac. I have 2 Blu-Rays I own I have been trying to rip - The Incredible Hulk, whose digital copy version expired by the time I bought the Blu-Ray, and Iron Man 2, which did not come with a digital copy.
No matter what I try, I cannot get beyond the Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK errors.
I have the latest libdvd file installed in my AACs folder
I have deleted all the preferences.
I have both the KEYDB.cfg and the KEYDB 2.cfg in my ~/.makeMKV folder
I also have the KEYDB.cfg file in my ~/.config/aacs folder
I have libdvdcss.2.dylib in /usr/lib
Nothing seems to work, neither MakeDVD nor Handbrake (latest of both as of Feb 28 2012)
Has anyone had success with this combination? Should I try Parallels with Windows 7? has anyone had success with that?
Any and all help would be appreciated. I am a humble noob (but very tech savvy)
Smithcraft
Re: No success with LG WH12LS39
#2 Post by Smithcraft » Wed Feb 29, 2012 9:09 am
Would you be so kind as to post the full log?
SC
gawk9876
#3 Post by gawk9876 » Thu Mar 01, 2012 12:00 am
Smithcraft wrote:Would you be so kind as to post the full log?
SC
Working on it right now (it takes a while). In the interim, I noted this when it started running:
MakeMKV v1.7.2 darwin(x86-release) started
Debug logging enabled, log will be saved as /Users/-----/MakeMKV_log.txt
Optical drive "DVD+R-DL OPTIARC DVD RW AD-7170A 1.NC" opened in DASPI v1.3 mode.
Optical drive "BD-RE HL-DT-ST BD-RE WH12LS39 1.00" opened in DASPI v1.3 mode.
The Blu_Ray is in the 2nd bay in my 2008 tower, connected via SATA. From reading that, am I correct in assuming that the DASPI v1.3 driver failed and instead it is opening in direct access? Does MakeMKV have issues connecting to a Blu-Ray that is connected via SATA rather than FW or USB (or ATA)?
BTW, it is stuck at "opening Blu-ray disc" after reading a bunch of the .m2ts files, so now I can't even choose which tracks to import. And yes, I have power cycled the tower...
gawk9876
#4 Post by gawk9876 » Thu Mar 01, 2012 2:43 am
it's still working:
Evaluation version, 24 day(s) out of 30 remaining
Title #01000.mpls has length of 90 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01001.mpls has length of 90 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.mpls has length of 100 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00099.mpls has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00100.mpls has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00300.mpls was added as title #0
File 00846.mpls was added as title #1
Title #00360.mpls has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00361.mpls has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00362.mpls has length of 39 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00363.mpls has length of 77 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00365.mpls has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00366.mpls has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00847.mpls was added as title #2
Title #00385.mpls has length of 94 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00387.mpls has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00388.mpls has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00389.mpls has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00390.mpls has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00391.mpls has length of 88 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00392.mpls has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00393.mpls has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01000.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01001.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00022.m2ts has length of 47 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01002.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01003.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 53 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00095.m2ts has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00096.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00097.m2ts has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00098.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00000.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00800.m2ts was added as title #3
Title #00801.m2ts has length of 44 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00802.m2ts has length of 44 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00803.m2ts was added as title #4
Title #00804.m2ts has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00805.m2ts has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00806.m2ts was added as title #5
Title #00807.m2ts has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00808.m2ts has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00809.m2ts was added as title #6
Title #00810.m2ts has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00811.m2ts has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00812.m2ts was added as title #7
Title #00813.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00814.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00815.m2ts was added as title #8
Title #00816.m2ts has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00817.m2ts has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00818.m2ts was added as title #9
Title #00819.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00820.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00821.m2ts was added as title #10
Title #00822.m2ts has length of 88 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00823.m2ts has length of 88 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00824.m2ts has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00825.m2ts has length of 47 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00826.m2ts has length of 94 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Error 'Scsi error - NO SENSE:NO ADDITIONAL SENSE INFORMATION' occurred while reading '/BDMV/STREAM/00827.m2ts' at offset '7077888'
DEBUG: Code 0 at ^pMJv%CV@EhkoE_-)o12:213130996
DEBUG: Code 0 at F/rBi:~`L>C;2S*f<.mb:121261681
DEBUG: Code 0 at ^pMJv%CV@EhkoE_-)o12:121262210
DEBUG: Code 3456 at ^pMJv%CV@EhkoE_-)o12:213129984
DEBUG: Code 0 at ZJ&V4Wr`DCv3JkHS#7(ls:121266097
DEBUG: Code 0 at ~(5g&`<]' zAM0tX!w"&:29400876
DEBUG: Code 0 at T[uMsp/E,d4w`;uq4::121261681
DEBUG: Code 0 at T[uMsp/E,d4w`;uq4::213130191
Failed to decode audio/video data for title #11 - invalid mux or internal error, title skipped.
DEBUG: Code 0 at k7qcxY:atA+TZw ::121262762
DEBUG: Code 0 at xH/N^!:x\#vY EY:29400255
DEBUG: Code 0 at Zzln-F`6Fc\!-12@:213142427
Title #00827.m2ts was skipped
Title #00828.m2ts has length of 49 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00829.m2ts has length of 49 seconds which is less than minimum title length of 120 seconds and was therefore skipped
DEBUG: Code 0 at R\*">Gcf[zd3k7)O]:213132951
Error 'Scsi error - NO SENSE:NO ADDITIONAL SENSE INFORMATION' occurred while reading '/BDMV/STREAM/00830.m2ts' at offset '0'
gawk9876
#5 Post by gawk9876 » Thu Mar 01, 2012 5:45 pm
canceled out, got some titles, selected them and started, 18 hours later:
Saving 1 titles into directory /Volumes/Data HD/DONOTBACK
Error 'Scsi error - NO SENSE:NO ADDITIONAL SENSE INFORMATION' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '0'
DEBUG: Code 0 at ImnWv?1rWQJF5=HY=I:29393470
Failed to save title 2 to file /Volumes/Data HD/DONOTBACK/t02_Iron_Man_2_Disc_1.mkv
0 titles saved, 1 failed
#6 Post by mike admin » Sat Mar 03, 2012 9:11 am
It appears that there is a hardware problem with your drive. There is a simple test - close MakeMKV and try to copy all files from this disc in finder, then see if you get any errors.
