Flashing BDR-S12XLB to enable UHD
futon
#1 Post by futon » Thu Dec 04, 2025 2:02 am
Hi I am looking for help with flashing my drive to enable reading UHD discs. Is it possible with this drive?
Manufacturer: PIONEER
Product: BD-RW BDR-S12
Revision: 1.01
Serial number: ALDL007544WL
Firmware date: 2020-07-21
Highest AACS version: 62
Drive platform: RS8F00
Firmware version: 1.01/ID45
Re: Flashing BDR-S12XLB to enable UHD
#2 Post by Billycar11 » Thu Dec 04, 2025 2:44 am
sure just email me that drive info section
email below
futon
#3 Post by futon » Fri Dec 05, 2025 7:32 pm
Just flashed my drive and it is not reading any of the UHD discs that I insert. Emailed details to Billycar, but figured I would also post here in case anyone else can help.
It looks like the flasher did something because the Product now shows "BD-RW BDR-S12JX" instead of "BD-RW BDR-S12" and the Firmware Version changed to "1.01/ID72" from "1.01/ID45"
Any ideas/help would be much appreciated, thanks!
OS device name: G:
Product: BD-RW BDR-S12JX
Revision: 1.01
Serial number:
Drive platform: RS8F01
Firmware version: 1.01/ID72
#4 Post by Coopervid » Fri Dec 05, 2025 8:41 pm
futon wrote: Fri Dec 05, 2025 7:32 pm Just flashed my drive and it is not reading any of the UHD discs that I insert. Emailed details to Billycar, but figured I would also post here in case anyone else can help.
OS device name: G:
Revision: 1.01
Serial number:
You need to power off your PC, wait a bit and then restart it. Then try again.
futon
#5 Post by futon » Fri Dec 05, 2025 11:03 pm
Coopervid wrote: Fri Dec 05, 2025 8:41 pm
OS device name: G:
Revision: 1.01
Serial number:
Thanks for the reply. I powered down my PC for about 30 minutes and after turning it back on the drive still does not read UHD discs. I tried a 1080p bluray and the drive read it without any issues.
Please let me know if you have any other troubleshooting tips. Is there any info/logs I can post that would help?
#6 Post by Coopervid » Fri Dec 05, 2025 11:23 pm
Contact Billy. This firmware you have is usually not what is provided to ensure UHD compatibility.
#7 Post by Billycar11 » Sat Dec 06, 2025 1:20 am
Coopervid wrote: Fri Dec 05, 2025 11:23 pm Contact Billy. This firmware you have is usually not what is provided to ensure UHD compatibility.
Fw is fine likely just a dirty laser sent instructions for cleaning
futon
#8 Post by futon » Sat Dec 06, 2025 6:20 pm
I cleaned the laser and the drive was able to read a 4K disc, but makemkv threw a read error halfway through the rip. I re-cleaned the laser and now the drive is back to not reading 4K discs. It can still read and rip 1080p blu rays without any issues.
If anyone has additional troubleshooting ideas please let me know, but I’m starting to think UHD isn’t in the cards for this drive.
#9 Post by Billycar11 » Sat Dec 06, 2025 10:15 pm
futon wrote: Sat Dec 06, 2025 6:20 pm I cleaned the laser and the drive was able to read a 4K disc, but makemkv threw a read error halfway through the rip. I re-cleaned the laser and now the drive is back to not reading 4K discs. It can still read and rip 1080p blu rays without any issues.
Other than that clean the discs
