I see this on occasion:
Error 'OS error - The end-of-file marker has been reached.
But the backup completes. Does that error have any impact on the backup?
Thanks in advance
Benign error? Error 'OS error - The end-of-file marker has been reached.
TheShoe
kaysee
Re: Benign error? Error 'OS error - The end-of-file marker has been reached.
I have encountered this error several times. After looking into the documentation and in the forums for information about it, I found that the message means that the software, sort of, reached -- you know -- the end of the, like, file... and... ummm... so, it's kind-of, uhh...
In other words, one of those vague, hand-wavey errors that MakeMKV displays without proper explanation of what it means to users.
Another such "error" is the dialogue box at the end of a copy process that indicates "Read Error" with some number of errors. This does >>NOT<< mean that files in the copy are either missing or corrupt (as implied by a "Read Error" dialogue box). I think it just means that the software encountered flakey parts of the optical disc which >>initially<< produced read errors, then were retried, and possibly eventually produced good data. The important thing to check is whether MakeMKV reports hash errors and files not saved. If files were not saved, then you have a problem of missing material. If all files were saved, with some percentage corrupt, then you have imperfect copies of some material. If there is not mention of hash errors, then you probably have a good copy, regardless of ambiguous, poorly-communicated "errors".
Each time I have encountered a "Read Error" dialogue box or an "Error 'OS error - The end-of-file marker has been reached. There is no valid data in the file beyond this marker' occurred while reading..." error, absent actual hash errors, the resulting copy has been fine, without no exception.
The log pane of the MakeMKV window for a successful copy operation should have these lines without mention of hash errors, and a dialogue box displayed about the backup being done but no mention of files not being saved:
Backup done
Backup done
tommik128
I had these errors today. Windows 11. What is interesting they occur right in the beginning but the copy process carries on normally after that. I was using 4 drives at once inside desktop PC on SATA ports. 2 drives were with no errors, other two had 2 errors each always on BD-50 discs.
I later tried another copy on different drive with no error and I used Synchronize directories command in Total Commander to compare the two backups. All files were identical except for discattd.dat which I believe is only generated by MakeMKV and has nothing to do with disc content itself.
I also tried once again the same drive with the same disc that had this "error" and second time there was no error at all.
That makes me think that this error is sort of "false alarm" that should not affect the actual backup output. It could be that multiple drives can be causing some timing bottlenecks in the system? But I decided that next time this happens I will cancel the backup process, delete the output folder and start over again until there is no error.
