WhiteInk72
#3346 Post by WhiteInk72 » Fri Dec 05, 2025 7:55 am
I just have a question regarding the disclaimer. Is there a specific reason for not using an older drive? I'm only aware certain old drives won't work with 4k blu-rays, but is there something I'm missing? I have a Samsung SE-506CB/RSBD and judging by the disclaimers, it really sounds like I might break it or smth.
#3347 Post by Coopervid » Fri Dec 05, 2025 3:21 pm
ClueMeIN wrote: Fri Dec 05, 2025 7:04 am I am a complete rookie with this. I followed rule one and tried to read extensively, but I am lost on getting my particular drive UHD friendly. I would really appreciate a kind soul helping me out. I feel confident I can do what's needed if I have the right files and some very basic instructions.
Here is my info:
OS device name: K:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E101
Serial number: XXXXXXXXXXX
Firmware date: 2015-10-20
Drive platform: RS8600
Firmware version: E101/ID76
Thank you in advance for the help!
PM sent.
#3348 Post by Coopervid » Fri Dec 05, 2025 3:23 pm
ahaddadin wrote: Fri Dec 05, 2025 12:48 am Hello just got this drive but it won’t read uhd disks
Verbatim 43888 Pioneer UD03, UHD discs spin then ‘no disc inserted’, regular Blu-ray works fine”:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number:
Firmware date: 2020-06-15
Drive platform: RS8511
Firmware version: 1.14
PM sent.
ANZAC
#3349 Post by ANZAC » Sat Dec 06, 2025 5:52 am
OS device name: E:
Product: BD-RE BU40N
Revision: 1.02
Serial number: MO1P5691624
Bus encryption flags: 1F
Harware support: Yes
Firmware support: No
Firmware version: 1.02
Executed:
C:\Program Files (x86)\MakeMKV>makemkvcon64.exe f --all-yes -d E: rawflash -i "C:\Users\Glenn\Downloads\The all you need firmware pack\The all you need firmware pack\LG slim BU40N\HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin"
Reading input file C:\Users\Glenn\Downloads\The all you need firmware pack\The all you need firmware pack\LG slim BU40N\HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Current Drive ID: HL-DT-ST_BD-RE_BU40N_1.02_212012011716_MO1P5691624
 100% Operation finished
Done successfully
Drive still shows as 1.02 in MakeMkV..... I waited, I rebooted. Ran the flash again. Still 1.02.
Is it possible it is encrypted firmware 1.02?
Halp pls.
#3350 Post by MartyMcNuts » Sat Dec 06, 2025 9:55 am
ANZAC wrote: Sat Dec 06, 2025 5:52 am
OS device name: E:
Revision: 1.02
Executed:
Done successfully
Halp pls.
If this is an Archgon, you must take the drive out of the enclosure to flash.
Mr_Orange
#3351 Post by Mr_Orange » Sat Dec 06, 2025 10:05 am
I snagged a Hitachi/LG BU40N off Amazon recently to replace my defunct BH16NS55 (RIP following 7 years of service). It came with firmware version 1.05 but a quick flash to 1.03MK and I'm off to the races.
I'm glad to be back to two drives again.
xalanthyr
#3352 Post by xalanthyr » Sat Dec 06, 2025 1:09 pm
Hello!
I'm a long user of your software and first timer when it comes to Blu-Rays. I just have a brand new supported ASUS drive with firmware in revision 3.11. I'm preparing for flashing the drive according to the instruction. I downloaded last supported Linux version binary, 1.17.7, but when I tried to display the drive's identification, I see something is a bit off. According to the docs:
6. type "./makemkvcon f -l"
This will show your drive identifier should look similar to this ''/IOBDServices/D5D25996'
Found 1 drives(s)
00: /IOBDServices/D5D25996, /dev/rdisk3, /dev/rdisk3
HL-DT-ST_BD-RE_BU40N_1.01_211910161032_MOFK6283224
In my case I see the identifier to be a bit different:
lukasz@ryzen ~/makemkv-bin-1.17.7/bin/amd64 $ ./makemkvcon f -l
Found 1 drives(s)
00: dev_21:3, /dev/sr0, /dev/sr0
  ASUS_BW-16D1HT_3.11_212012011759_KLZP84G1350
Is "dev_21:3" identfier supported by the tool? I don't know if makemkvcon will understand this different syntax and follow smoothly. Thanks in advance for your support!
ANZAC
#3353 Post by ANZAC » Sat Dec 06, 2025 3:34 pm
MartyMcNuts wrote: Sat Dec 06, 2025 9:55 am
OS device name: E:
Revision: 1.02
Executed:
Done successfully
Halp pls.
Verbatim branded.
ANZAC
#3354 Post by ANZAC » Sat Dec 06, 2025 3:43 pm
ANZAC wrote: Sat Dec 06, 2025 5:52 am Drive still shows as 1.02 in MakeMkV..... I waited, I rebooted. Ran the flash again. Still 1.02.
Halp pls.
The YouTube how-to video said BU40N 1.04 onwards are encrypted.....
But then, looking at the encrypted firmware list it shows this:
HL-DT-ST-BD-RE_BU40N_1.02_212012011716_MO3L91F0715.bin
And my drive reports this:
Revision: 1.02
The serial numbers are different, but the dates look the same (though the filename formatting isn't the same).
Does this mean it is encrypted? Why can't the flashing program just detect if it is encrypted?
Thanks in advance.
#3355 Post by MartyMcNuts » Sat Dec 06, 2025 11:27 pm
ANZAC wrote: Sat Dec 06, 2025 3:43 pm
Halp pls.
Revision: 1.02
Thanks in advance.
Firmware dated 2020+ is encrypted, so yes, it is encrypted. I have never seen 1.02 on a Verbatim drive before. Always been 1.04 or 1.05 and I've flashed hundreds of them. Only ever seen 1.02 on the Archgon.
ANZAC
#3356 Post by ANZAC » Sun Dec 07, 2025 4:34 am
MartyMcNuts wrote: Sat Dec 06, 2025 11:27 pm Firmware dated 2020+ is encrypted, so yes, it is encrypted. I have never seen 1.02 on a Verbatim drive before. Always been 1.04 or 1.05 and I've flashed hundreds of them. Only ever seen 1.02 on the Archgon.
Well, "2120" is year 2021?
Anyway, that solved it. Thanks for help.
(This was a Verbatim from NewEgg).
#3357 Post by MartyMcNuts » Sun Dec 07, 2025 5:16 am
ANZAC wrote: Sun Dec 07, 2025 4:34 am
No, 2120 is 2020. The second digit should be a zero.
Bourney0
#3358 Post by Bourney0 » Mon Dec 08, 2025 10:01 pm
I would like to flash my Pioneer XD05S if possible. Here's the info from MakeMKV:
Product: BD-RW BDR-XD05
Revision: 3.01
Serial number:
Firmware date: 2014-12-26
Highest AACS version: 76
Drive platform: RS8231
Firmware name: PIONEER BDR-XD05
Firmware version: 3.01/ID34
#3359 Post by Billycar11 » Tue Dec 09, 2025 2:38 am
Bourney0 wrote: Mon Dec 08, 2025 10:01 pm I would like to flash my Pioneer XD05S if possible. Here's the info from MakeMKV:
Revision: 3.01
Serial number:
Just email me your makemkv drive info section like that see below
rayians
#3360 Post by rayians » Tue Dec 09, 2025 12:49 pm
I have been trying to find an Asus BW-16D1HT to flash for about 2 months. They used to be $99, then went up to $129, then several hundred dollars, and now for the past month there is absolutely none to be had anywhere. Can anyone confirm or deny if these have been discontinued? If not, is there any idea when they will be available again. If they are gone, what is a good alternative that is readily available?
