MKVChaps - does anyone have a copy?
oscillator
Post by oscillator »
I lost my copy of MKVChaps from this post:
http://www.makemkv.com/forum2/viewtopic.php?f=1&t=690
Anyways, I can't download it again since it was hosted on megaupload. I tried using the code listed in the post but that is, as they say, outside my wheelhouse.
If anyone can upload a copy of it that would be great.
Thanks.
setarip_old
Re: MKVChaps - does anyone have a copy?
Post by setarip_old »
Have you tried to PM or email "Wasabi"?
Smithcraft
Post by Smithcraft »
I might still have it on my peecee but I only use it on the weekends.
I never got it to work, so I don't know if there is something wrong with it(corrupted download) or something else is wrong with it(pebkac most likely).
SC
robpdotcom
Post by robpdotcom »
oscillator
robpdotcom wrote:Here you go:
http://www.mediafire.com/?7l85net8dddle84
Thank you!
piccirilli
Post by piccirilli »
I got MKVChaps to work for one file. Now everytime I try to run it, the program crashes.
Note: I was having similar issue with ImgBurn shutting down on startup. Turns out it has something to do with Sandbox running in the background of some antivirus programs. I inactivated the AutoSandbox feature in my Avast Antivirus and the problem was resolved. Perhaps this will help others with the program crashing.
