Public KeyDB Disc Submissions
el_vandragon wrote:
Wed Dec 03, 2025 7:37 pm
Coopervid wrote:
Wed Dec 03, 2025 7:30 pm
If you use FindVUK to start DVDFab the disc and the keys will be automtically uploaded to the keydb.cfg. So what's the benefit to post those here? Makemkv needs VUKs. So you need to post your dumps generated by Makemkv.
Correct, but as you can see DVDFab only gets unit keys for UHD discs. Makemkv didn't need to generate a dump for these as it was able to dump them, I was just hoping there would be a way for me to share files from the backup in order to have the VUK be computed and added. I only copied the whole keydb entry so it was clear which discs I was talking about. Having the additional info wouldn't be helpful for MakeMKV but there are other people who use the keydb so I was hoping the VUK would be able to computed for them.
Other programs are OK with the UKs which are uploaded by FindVUK.
To generate the VUKs needed for Makemkv you need to post your Makemkv dumps here using the template.
sandman_satx213
Post by sandman_satx213 »
Hi. Checking to see if my request is malformed or in progress. I originally left out the link to the MKB_RO.inf file but that has been corrected. Thanks!
sandman_satx213 wrote:
Sat Nov 29, 2025 4:39 pm
After Hours
Disc type: UHD
Disc dump filename: MKB20_v77_AFTER_HOURS_3D55.tgz
Drive: BD-RE BP60NB10
Drive firmware: 1.02
LibreDrive status: Enabled
MKB_RO.inf link:https://drive.google.com/file/d/1AiNe8G ... drive_link
Disc dump link: https://drive.google.com/file/d/1-2vzWh ... drive_link
gentile2226
Post by gentile2226 »
Here's my UK Arrow copy of City on Fire. I didn't see anyone else submit it recently.
Disc type: 4K Blu-ray
Disc dump filename: MKB20_v82_CITY_ON_FIRE_0F35.tgz
Drive: LG BU40N
Drive firmware: 1.03
MKB_RO.inf link: https://www.mediafire.com/file/4fhwvg3q ... O.inf/file
Disc dump link: https://www.mediafire.com/file/b5onhx2i ... 5.tgz/file
keydb_helper
Post by keydb_helper »
gentile2226 wrote:
Wed Dec 03, 2025 9:03 pm
Hey gentile2226, your disc variant was added to the public keydb on October 12 but it is one of the unusual, unprotected discs which confuses MakeMKV. Make a protected backup of your disc, then delete or rename the "AACS" folder inside your backup. After that is done you should be able to open the protected backup with MakeMKV. See this post for the original discussion about your disc: Link
keydb_helper
Hey el_vandragon, thanks for reaching out to fill in some gaps within the public keydb. As Coopervid noted, the usual process is to post a MakeMKV disc dump to this thread and from that dump file all of the disc keys can be calculated (MK, VUK, and UK) - unless you have a Pioneer disc drive.
Now you should be able to force MakeMKV to generate a disc dump for a natively supported title by temporarily disabling internet access and moving the _private_data.tar file in your MakeMKV data directory to a different location. This is the same MakeMKV directory into which you probably copied the keydb.cfg file. For the sake of generating the disc dump files quickly you can also temporarily move out the keydb.cfg file to any other directory.
Once _private_data.tar has been renamed and internet access disabled, try to open/process one of your discs in MakeMKV. It should generate the dump file. If the dump file is under 1MB, grab the MKB_RO.inf from the disc itself and follow the submission template in the opening post of this thread.
Feel free to put back the _private_data.tar and keydb.cfg files once you have generated all of your disc dumps.
keydb_helper
Wed Dec 03, 2025 8:00 pm
Hey sandman_satx213, thank you for following the submission template. Your variant of After Hours was added to the public keydb on November 30. Because it shares a media key with another disc variant which was added to the public keydb on October 1, I didn't explicitly call out its inclusion. Such cases get absorbed into my line about how "All valid UHD discs dumps have been processed and incorporated into the public keydb" or "All valid submissions have been added to the public keydb". I still haven't settled on the final wording yet.
Just to be clear, if there were any issues with your submission I would've replied to your post.
gentile2226
keydb_helper wrote:
Wed Dec 03, 2025 9:29 pm
You're right it works if I do this, thanks a lot!
el_vandragon
Post by el_vandragon »
keydb_helper wrote:
Wed Dec 03, 2025 9:42 pm
That worked, thanks!
Disc type: UHD
Disc dump filename: MKB20_v72_1917_D6B5
Drive: BW-16D1HT
Drive firmware: 3.10MK
MKB_RO.inf link: https://drive.google.com/drive/folders/ ... drive_link
Disc dump link: https://drive.google.com/drive/folders/ ... drive_link
Disc type: UHD
Disc dump filename: MKB20_v61_KING_KONG_UHD_3E0F
Drive: BW-16D1HT
Disc type: UHD
Disc dump filename: MKB20_v61_PREDATOR_14F9
Drive: BW-16D1HT
Disc type: UHD
Disc dump filename: MKB20_v76_THE_SHAWSHANK_REDEMPTION_42C3
Drive: BW-16D1HT
timkur
Post by timkur »
keydb_helper wrote:
Wed Dec 03, 2025 12:40 pm
timkur wrote:
Wed Dec 03, 2025 4:16 am
Disc dump filename: MKB20_v82_A_Nightmare_on_Elm_Street_5-The_Dream_Child_F7EB
Disc dump filename: MKB20_v82_Freddy's_Dead-_The_Final_Nightmare_9179
cybr1d wrote:
Wed Dec 03, 2025 5:19 am
Disc dump filename: MKB_v82_Den_Ace_Chaos_25FE
Hey timkur and cybr1d, thanks for following the submission template. All three discs have been added to the public keydb.
Tim
sunday46ma
Post by sunday46ma »
Disc type: UHD
Disc dump filename: MKB20_v82_Departures_4CD6
Drive: BW-16D1HT
Drive firmware: 3.00
MKB_RO.inf link : https://drive.google.com/file/d/11N8mNl ... sp=sharing
Disc dump link:https://drive.google.com/file/d/1SOPXJ0 ... sp=sharing
keydb_helper
el_vandragon wrote:
Thu Dec 04, 2025 1:25 am
I'm glad to hear it worked. I'll need to save that post for future reference.
sunday46ma wrote:
Thu Dec 04, 2025 9:04 am
Thank you both for following the submission template. All five discs have been added to the public keydb.
at12pang
Post by at12pang »
Here's Japanese Disc
Disc type: BD-ROM
Disc dump filename: MKB_v82_ミュージカル「忍たま乱太郎」第15弾 走れ四年生!戦え六年生!~閻魔岳を駆け抜けろ~_8A52.tgz
Drive: LG BP50Nb40
Drive firmware: 1.00
MKB_RO.inf link: https://drive.google.com/file/d/1GH2zMM ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1g7L_Zx ... sp=sharing
99gagamel
Post by 99gagamel »
Disc-Typ: UHD
Disc-Dump-Dateiname: MKB20_v72_DOCTOR_SLEEP_BB2B,tgz
Laufwerk: BW-1601HT
Laufwerks-Firmware: 3.01
Haben Sie die öffentliche Schlüsseldatenbank in den letzten 15 Minuten synchronisiert? Ja
Haben Sie überprüft, ob alle Einreichungslinks im Inkognito-/Privatmodus erreichbar sind? Ja
Link zur Datei MKB_RO.inf: https://drive.google.com/file/d/1nYhgOD ... sp=sharing
Link zum Disc-Dump: https://drive.google.com/file/d/1OfUXHY ... sp=sharing
xiaoxiao
Post by xiaoxiao »
Disc type: UHD BLADE_RUNNER_2049
Disc dump filename: MKB20_v61_BLADE_RUNNER_2049_EBC7
Drive: BW-16D1HT
MKB_RO.inf link :https://drive.google.com/file/d/1XtIeVw ... drive_link
Disc dump link:https://drive.google.com/file/d/1XtIeVw ... drive_link
keydb_helper
at12pang wrote:
Thu Dec 04, 2025 11:28 am
99gagamel wrote:
Thu Dec 04, 2025 8:19 pm
Thank you both for following the submission template. Your discs have been added to the public keydb.
