Flashing BDR-S12XLB to enable UHD
futon
Post by futon »
Hi I am looking for help with flashing my drive to enable reading UHD discs. Is it possible with this drive?
Manufacturer: PIONEER
Product: BD-RW BDR-S12
Revision: 1.01
Serial number: ALDL007544WL
Firmware date: 2020-07-21
Highest AACS version: 62
Drive platform: RS8F00
Firmware version: 1.01/ID45
Re: Flashing BDR-S12XLB to enable UHD
sure just email me that drive info section
email below
futon
Post by futon »
Just flashed my drive and it is not reading any of the UHD discs that I insert. Emailed details to Billycar, but figured I would also post here in case anyone else can help.
It looks like the flasher did something because the Product now shows "BD-RW BDR-S12JX" instead of "BD-RW BDR-S12" and the Firmware Version changed to "1.01/ID72" from "1.01/ID45"
Any ideas/help would be much appreciated, thanks!
OS device name: G:
Product: BD-RW BDR-S12JX
Revision: 1.01
Serial number:
Drive platform: RS8F01
Firmware version: 1.01/ID72
futon wrote:
Fri Dec 05, 2025 7:32 pm
OS device name: G:
Revision: 1.01
Serial number:
You need to power off your PC, wait a bit and then restart it. Then try again.
