PM sent.maximum wrote: Wed Dec 03, 2025 3:58 pm Hello, I have the same problem.
Manufacturer: PIONEER
Product: BD-RW BDR-S09
Revision: 1.55
Serial number: NCDL008423WL
Firmware date: 2023-02-16
Drive platform: RS8600
Firmware version: 1.55/ID43
Pioneer BDR-S09XLT LibreDrive ready but not ripping UHD-discs
Re: Pioneer BDR-S09XLT LibreDrive ready but not ripping UHD-discs
Firmware date: 2023-02-16Coopervid wrote: Wed Dec 03, 2025 4:23 pmPM sent.maximum wrote: Wed Dec 03, 2025 3:58 pm Hello, I have the same problem.
Revision: 1.55
This is too new.
Marty is right. Not flashable. I will delete the PM if unread.
Edit: PM deleted.
Edit: PM deleted.
Thanks a lot, tried de FW yesterday and worked fine. Not sure if the drive is sleep bug free though.Coopervid wrote: Sun Aug 31, 2025 3:31 pmPM sent.loubd wrote: Sun Aug 31, 2025 2:41 am Fresh user in the forum. I would love to be able to use my drive to rip UHD and hope you can help me to flash it.
Here is the information of the drive.
OS device name: E:
Current profile: DVD-ROM
Revision: 1.34
Serial number:
Firmware date: 2016-04-25
Firmware version: 1.34/ID43
I had some problem when reading a disc and solved it by ejecting and loading it again but I guess it has nothing to do with that bug.
Pioneer drives don't have a sleep bug.loubd wrote: Fri Dec 05, 2025 11:31 pmThanks a lot, tried de FW yesterday and worked fine. Not sure if the drive is sleep bug free though.Coopervid wrote: Sun Aug 31, 2025 3:31 pmPM sent.loubd wrote: Sun Aug 31, 2025 2:41 am Fresh user in the forum. I would love to be able to use my drive to rip UHD and hope you can help me to flash it.
OS device name: E:
Revision: 1.34
Serial number:
I hope this is the correct thread.
I have 2 of these drives, that are Labeled Pioneer BDR-S09XLB, with different original Firmwares (1.30 and 1.34):
Can you help me with enabling UHD for them?
Drive 1:
Laufwerksinformation
OS-Gerätename: I:
Produzent: PIONEER
Produkt: BD-RW BDR-S09
Revision: 1.34
Serienummer: --------------
Firmware-Datum: 2016-04-25
Highest AACS version: 77
Drive 2:
OS-Gerätename: I:
Produzent: PIONEER
Revision: 1.30
Serienummer: ---------------
Firmware-Datum: 2014-12-05
Firmware version: 1.30/ID43
PM sent. Works for both drives.ripposaur wrote: Sat Dec 06, 2025 11:57 pm Hello,
Can you help me with enabling UHD for them?Code: Select all
Drive 1: Laufwerksinformation OS-Gerätename: I: Produzent: PIONEER Produkt: BD-RW BDR-S09 Revision: 1.34 Serienummer: -------------- Firmware-Datum: 2016-04-25 Markierungen der Bus-Verschlüsselung: 1B Highest AACS version: 77 LibreDrive Information Status: Enabled Drive platform: RS8600 Firmware name: PIONEER BDR-209 Firmware type: Original (unpatched) Firmware version: 1.34/ID43 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes Drive 2: Laufwerksinformation OS-Gerätename: I: Produzent: PIONEER Produkt: BD-RW BDR-S09 Revision: 1.30 Serienummer: --------------- Firmware-Datum: 2014-12-05 Markierungen der Bus-Verschlüsselung: 1B Highest AACS version: 77 LibreDrive Information Status: Enabled Drive platform: RS8600 Firmware name: PIONEER BDR-209 Firmware type: Original (unpatched) Firmware version: 1.30/ID43 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
It works. Thanks you very much!PM sent. Works for both drives.
I too Bought a Pioneer BDR-S09XLT looking for UHD ripping and playback firmware can anyone help
I need to check which firmware i am currently running but flying blind
Copy and paste the MakeMKV drive info and libredrive info sections.Mothy2501 wrote: Tue Dec 09, 2025 10:19 pm I too Bought a Pioneer BDR-S09XLT looking for UHD ripping and playback firmware can anyone help
Hiya to whom ever can help with getting this drive (Pioneer BDR-S09XLT) UHD ready if its possible my MakeMKV info is
OS device name: L:
Revision: 1.52
Serial number: QHDL026384WL
Firmware date: 2019-01-11
Highest AACS version: 62
Firmware version: 1.52/ID43
Anyhelp would be appreciated as I bought this drive in 2018 hoping it would read UHD discs
OS device name: L:
Revision: 1.52
PM is coming since you posted now the required information.Mothy2501 wrote: Wed Dec 10, 2025 3:30 pm Hiya to whom ever can help with getting this drive (Pioneer BDR-S09XLT) UHD ready if its possible my MakeMKV info is
OS device name: L:
Revision: 1.52
THANK YOU SO MUCH!!!
Just tried the drive with a UHD disc and VLC and its working I can now get rid of my UHD Bluray TV Player that doesn't work properly thank you so much!!
bigfatmonk
I think my message might have been missed when I posted a while ago. I would still like help enabling UHD on my drive if possible. Thanks!
bigfatmonk wrote: Sun Feb 23, 2025 10:26 pm Hey! Could you pleas help me enable UHD on my drive?
No disc insertedDrive Information
Revision: 1.52
Serial number: ...
Highest AACS version: 16
PM sent. I missed your post.bigfatmonk wrote: Fri Dec 19, 2025 6:48 pm I think my message might have been missed when I posted a while ago. I would still like help enabling UHD on my drive if possible. Thanks!
Revision: 1.52
Serial number: ...
