Pioneer BDR-S09XLT LibreDrive ready but not ripping UHD-discs
Re: Pioneer BDR-S09XLT LibreDrive ready but not ripping UHD-discs
maximum wrote: Wed Dec 03, 2025 3:58 pm Hello, I have the same problem.
Manufacturer: PIONEER
Product: BD-RW BDR-S09
Revision: 1.55
Serial number: NCDL008423WL
Firmware date: 2023-02-16
Drive platform: RS8600
Firmware version: 1.55/ID43
PM sent.
Coopervid wrote: Wed Dec 03, 2025 4:23 pm
Revision: 1.55
PM sent.
This is too new.
Marty is right. Not flashable. I will delete the PM if unread.
Edit: PM deleted.
loubd
Post by loubd »
Coopervid wrote: Sun Aug 31, 2025 3:31 pm
loubd wrote: Sun Aug 31, 2025 2:41 am Fresh user in the forum. I would love to be able to use my drive to rip UHD and hope you can help me to flash it.
Here is the information of the drive.
OS device name: E:
Current profile: DVD-ROM
Revision: 1.34
Serial number:
Firmware date: 2016-04-25
Firmware version: 1.34/ID43
PM sent.
Thanks a lot, tried de FW yesterday and worked fine. Not sure if the drive is sleep bug free though.
I had some problem when reading a disc and solved it by ejecting and loading it again but I guess it has nothing to do with that bug.
loubd wrote: Fri Dec 05, 2025 11:31 pm
OS device name: E:
Revision: 1.34
Serial number:
PM sent.
Pioneer drives don't have a sleep bug.
ripposaur
Post by ripposaur »
I hope this is the correct thread.
I have 2 of these drives, that are Labeled Pioneer BDR-S09XLB, with different original Firmwares (1.30 and 1.34):
Drive 1:
Laufwerksinformation
OS-Gerätename: I:
Produzent: PIONEER
Produkt: BD-RW BDR-S09
Revision: 1.34
Serienummer: --------------
Firmware-Datum: 2016-04-25
Highest AACS version: 77
Drive 2:
OS-Gerätename: I:
Produzent: PIONEER
Revision: 1.30
Serienummer: ---------------
Firmware-Datum: 2014-12-05
Firmware version: 1.30/ID43
Can you help me with enabling UHD for them?
ripposaur wrote: Sat Dec 06, 2025 11:57 pm Hello,
Drive 1:
OS-Gerätename: I:
Produzent: PIONEER
Revision: 1.34
Drive 2:
OS-Gerätename: I:
Produzent: PIONEER
Revision: 1.30
PM sent. Works for both drives.
ripposaur
Post by ripposaur »
It works. Thanks you very much!
Mothy2501
Post by Mothy2501 »
I too Bought a Pioneer BDR-S09XLT looking for UHD ripping and playback firmware can anyone help
I need to check which firmware i am currently running but flying blind
Mothy2501 wrote: Tue Dec 09, 2025 10:19 pm I too Bought a Pioneer BDR-S09XLT looking for UHD ripping and playback firmware can anyone help
Copy and paste the MakeMKV drive info and libredrive info sections.
Mothy2501
Post by Mothy2501 »
Hiya to whom ever can help with getting this drive (Pioneer BDR-S09XLT) UHD ready if its possible my MakeMKV info is
OS device name: L:
Revision: 1.52
Serial number: QHDL026384WL
Firmware date: 2019-01-11
Highest AACS version: 62
Firmware version: 1.52/ID43
Anyhelp would be appreciated as I bought this drive in 2018 hoping it would read UHD discs
Mothy2501 wrote: Wed Dec 10, 2025 3:30 pm Hiya to whom ever can help with getting this drive (Pioneer BDR-S09XLT) UHD ready if its possible my MakeMKV info is
OS device name: L:
Revision: 1.52
PM is coming since you posted now the required information.
Mothy2501
Post by Mothy2501 »
THANK YOU SO MUCH!!!
Just tried the drive with a UHD disc and VLC and its working I can now get rid of my UHD Bluray TV Player that doesn't work properly thank you so much!!
bigfatmonk
Post by bigfatmonk »
I think my message might have been missed when I posted a while ago. I would still like help enabling UHD on my drive if possible. Thanks!
bigfatmonk wrote: Sun Feb 23, 2025 10:26 pm Hey! Could you pleas help me enable UHD on my drive?
Revision: 1.52
Serial number: ...
Highest AACS version: 16
bigfatmonk wrote: Fri Dec 19, 2025 6:48 pm I think my message might have been missed when I posted a while ago. I would still like help enabling UHD on my drive if possible. Thanks!
Revision: 1.52
Serial number: ...
PM sent. I missed your post.
