The Crow UHD Blu Ray
placebofx
Post by placebofx »
Cannot get this disc to rip.
https://www.blu-ray.com/movies/The-Crow ... ay/356015/
MKB20_v77_The_Crow_(Remastered)_01F5.tgz
(216.25 KiB) Downloaded 103 times
Re: The Crow UHD Blu Ray
You should email the dump to svq@makemkv.com so a key can be created for MakeMKV's built in hashed key mechanism. A few days after emailing the dump, try the disc again and if a key is available, MakeMKV will download it automatically in the background.
There is a separate second decryption mechanism that MakeMKV supports, the public KeyDB. To contribute to the public KeyDB, use the template and follow the instructions in the first post in the Public KeyDB Disc Submissions thread.
placebofx
Post by placebofx »
THank you so much!
I did email it, and I will check now.
Apologies for not reading the forum policy prior to posting. I saw it after and emailed it.
