UK 'In Time' Blu-ray
teuchterloon
#1 Post by teuchterloon » Mon Feb 27, 2012 5:39 pm
Just bought htis today and have tried a couple of times to rip it. I'm using the latest version of MakeMKV 1.7.2 win(X64-release).
When I first open the disc MakeMKV opens 36 SVQ files.
Then it tells me it "Failed to process BD+ code using generic SVQ from builtin/00003.svq".
It then tries /00002.svq and tells me, "BD+ code processed but no FUTs were obtained, errors may follow".
It then opens the menu as normal and lets me select the files I want to rip, but when I start ripping it stops exactly 42.8M into the film each time and throws up the following message, "Copy complete. 0 titles saved, 1 failed."
A log was created which I have attached.
I hope this can be fixed soon? :-)
MakeMKV_log.txt
(9.24 KiB) Downloaded 841 times
Krobar
Re: UK 'In Time' Blu-ray
#2 Post by Krobar » Mon Feb 27, 2012 6:59 pm
I get the same errors:
Processing BD+ code using generic SVQ from builtin/00003.svq
Processing BD+ code using generic SVQ from builtin/00002.svq
crowfax
#3 Post by crowfax » Mon Feb 27, 2012 7:16 pm
I hope you both submitted the BD+ dump.
teuchterloon
#4 Post by teuchterloon » Mon Feb 27, 2012 7:34 pm
Where do I find it to submit?
crowfax
#5 Post by crowfax » Mon Feb 27, 2012 10:48 pm
go to your settings, turn on BD+ dump creation. the file you need to send off will be in created whatever you settings folder is specified as.
UFO77
#6 Post by UFO77 » Tue Feb 28, 2012 5:10 am
I can also confirm same exact same error message.
I used latest file from here: http://www.makemkv.com/forum2/viewtopic.php?f=1&t=612 and still no love ;).
I have emailed dump file.
#7 Post by mike admin » Sat Mar 03, 2012 9:17 am
SVQ updated on March 1st.
teuchterloon
#8 Post by teuchterloon » Sat Mar 03, 2012 10:58 am
Thanks Mike :-)
