UK 'In Time' Blu-ray
teuchterloon
Post by teuchterloon »
Just bought htis today and have tried a couple of times to rip it. I'm using the latest version of MakeMKV 1.7.2 win(X64-release).
When I first open the disc MakeMKV opens 36 SVQ files.
Then it tells me it "Failed to process BD+ code using generic SVQ from builtin/00003.svq".
It then tries /00002.svq and tells me, "BD+ code processed but no FUTs were obtained, errors may follow".
It then opens the menu as normal and lets me select the files I want to rip, but when I start ripping it stops exactly 42.8M into the film each time and throws up the following message, "Copy complete. 0 titles saved, 1 failed."
A log was created which I have attached.
I hope this can be fixed soon? :-)
MakeMKV_log.txt
(9.24 KiB) Downloaded 639 times
Krobar
Re: UK 'In Time' Blu-ray
Post by Krobar »
I get the same errors:
Processing BD+ code using generic SVQ from builtin/00003.svq
Processing BD+ code using generic SVQ from builtin/00002.svq
crowfax
Post by crowfax »
I hope you both submitted the BD+ dump.
teuchterloon
Where do I find it to submit?
crowfax
Post by crowfax »
go to your settings, turn on BD+ dump creation. the file you need to send off will be in created whatever you settings folder is specified as.
UFO77
Post by UFO77 »
I can also confirm same exact same error message.
I used latest file from here: http://www.makemkv.com/forum2/viewtopic.php?f=1&t=612 and still no love ;).
I have emailed dump file.
Post by mike admin »
SVQ updated on March 1st.
teuchterloon
Thanks Mike :-)
