Asus SBW-06D5H-U - Stopped Working
MagicianMoth
#1 Post by MagicianMoth » Wed Nov 26, 2025 1:34 pm
I have the above external DVD/Bluray drive which has been working fin for the past year, however it has recently started coming up with the following message;
Error 'Scsi error - HARDWARE ERROR:INTERNAL TARGET FAILURE' occurred while issuing SCSI command A30..01001000E0..0214F65476E654C6168430..0 to device 'SPTI:\Device\CdRom0'
Drive BD-RE ASUS SBW-06D5H-U E102 CLDL284244WL has RPC protection that can not be bypassed. Change drive region or update drive firmware from http://tdb.rpc1.org. Errors likely to follow.
Drive = Disc drive region 2, Disc Region 2
Anyone know whats causing it?
MagicianMoth
Asus SBW-06D5H-U - Stopped Working - Additional Info
#2 Post by MagicianMoth » Thu Nov 27, 2025 7:08 am
Additional Information on MKV Drive
Current profile: DVD-ROM
Manufacturer: ASUS
Product: SBW-06D5H-U
Revision: E102
Serial number:
Firmware date: 2023-04-20
Highest AACS version: 70
Drive platform: RS8511
Firmware version: E102/ID26
Any help would be appreiated
MagicianMoth
#3 Post by MagicianMoth » Tue Dec 02, 2025 3:27 pm
Errror reports from MKV trying a Blueray Disc...
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..0F138EB4C416FD100E522641A04E94BAFFE to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..068C9961D7E40FBE48F6591FAD4202B2433 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..06572BEC553CBE1E9E8E661B8D455C90695 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..093139EEC782BF0DCBF19BC9B77DCDCBC99 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..01BECA7D32574A0B7C66F4E96B5BC8AC061 to device 'SPTI:\Device\CdRom0'
Any Ideas anyone..... Please
Re: Asus SBW-06D5H-U - Stopped Working
#4 Post by dcoke22 » Wed Dec 03, 2025 3:52 am
Have you power cycled the drive?
I've seen a couple of other people post on the forum with similar errors. I'm not sure what they mean.
MagicianMoth
#5 Post by MagicianMoth » Fri Dec 05, 2025 11:25 am
Thanks for your reply....
If you mean - turned off Drive, Unplugged Drive from power and comp, then Restarted computer, I've done all that with no differnce to error.
I've even been to look for a flash, but can't see my drive, Asus or Pioneer on the listings
Any other ideas?
Thanks again....
#6 Post by dcoke22 » Fri Dec 05, 2025 3:10 pm
Does the drive behave differently with a DVD vs a blu-ray?
MagicianMoth
#7 Post by MagicianMoth » Fri Dec 05, 2025 5:42 pm
Heres a selection of the errors when trying a Bluray, theres quite a few lines so this is just a selection;
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..053AA075562F783C943632C13E039ADD58D to device 'SPTI:\Device\CdRom0'
Eissuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
All the best and thanks again....
MagicianMoth
#8 Post by MagicianMoth » Fri Dec 05, 2025 5:46 pm
MKV details of sample Bluray disc and drive...
Manufacturer: ASUS
Revision: E102
Serial number: CLDL28424
Highest AACS version: 56
Disc Information
Label: DAD'S_ARMY
Timestamp: 2016-04-01 17:00:10
Protection: AACS v56
Data capacity: 23.86 Gb
Disc type: BD-ROM
Number of layers: 2
#9 Post by Coopervid » Fri Dec 05, 2025 8:50 pm
So can you rip the Bluray but not a DVD? Try to apply some logic if this only occurs with DVDs. All DVDs?
MagicianMoth
#10 Post by MagicianMoth » Sat Dec 06, 2025 5:07 am
I can no longer rip DVD's or Bluray......
All the best
MagicianMoth
#11 Post by MagicianMoth » Sun Dec 07, 2025 7:58 am
Just as an aside - It reads CD's perfectly
Thanks again for any help....
Kerubael
#12 Post by Kerubael » Sun Dec 07, 2025 11:11 am
i have the exact same errors with the same drive and informations posted above. Running the Windows Version.
I've also installed makemkv on a separate linux pc with the exact same errors.
2 Month ago i've ripped a dozen dvds and blue rays without any error. Now with the same setup i can't rip neither.
#13 Post by dcoke22 » Mon Dec 08, 2025 2:37 pm
I wonder, did MakeMKV produce a firmware dump file? If it did, it would be in the MakeMKV data directory. The General tab of MakeMKV's preferences lists the location of the data directory.
Kerubael
#14 Post by Kerubael » Mon Dec 08, 2025 6:49 pm
There are just the screen.conf, settings.conf, update.conf and the private_data.tar files in the makemkv data directory.
Theses are the logs of a failed blue ray:
MakeMKV v1.18.2 linux(x64-release) started
Debug logging enabled, log will be saved as /home/keru/MakeMKV_log.txt
DEBUG: Code 4278603778 at R}5I(mqyj*Y)l/y0L:121264878
Evaluation version, 29 day(s) out of 30 remaining
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..0A45C296406FA11AEDBAACBEB63FF15F74E to device 'SG:dev_21:0'
DEBUG: Code 0 at PwH=#GLZH Fj*4D?{:213130766
DEBUG: Code 0 at pKR,,<Y4`?)Y\ru%M^:121263429
DEBUG: Code 0 at pKR,,<Y4`?)Y\ru%M^:213130789
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..0B5C941A8400EA6D7F94CA54EB393C19EC0 to device 'SG:dev_21:0'
DEBUG: Code 1 at pKR,,<Y4`?)Y\ru%M^:213130789
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..080FC3924D43004CD03D73914142D595748 to device 'SG:dev_21:0'
DEBUG: Code 2 at pKR,,<Y4`?)Y\ru%M^:213130789
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..050445B29191DE8E681CAA5BB3AC67D93A3 to device 'SG:dev_21:0'
DEBUG: Code 3 at pKR,,<Y4`?)Y\ru%M^:213130789
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..08779B5C57F5283C5031960C2BA2B158EFB to device 'SG:dev_21:0'
DEBUG: Code 4 at pKR,,<Y4`?)Y\ru%M^:213130789
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..0864963550C893D561DAAFFB5726CA3A5B2 to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..01937BCCE9338EF5C113874F45B83759C63 to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..0F5E2C34B06A0E5A6F46E4EB240D6754027 to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..0A0B3E1E95906A16796D768ABE0FB3C34FB to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..0B8CDB5CB7BE8A81308DE46D58FAE86EF28 to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..086D10706A048277E36971F22ED01B0EE13 to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..0BD277799614B9DD2530A1001F814950041 to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..0E4A02A952E35F0091E652E8710C23F4E15 to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..019E9E8C82D6AC81A017E12CD2A3960DB47 to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..0F9049406AA64C03FEA0DBB8559D2DC6B45 to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..0512DB1F0BDECE837BBDBC0463F493127BF to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..00B7CBC733531AFBA3C0DB1345F829002DB to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..080742AA541DD2B9D526132C0813416A5AF to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..0F91DAFFEF9019613B4EBE5E456341AB65F to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..063E8DAB973D3D4EA408F6E18536A084EEB to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..0418A4E9AED1C9C5CDE193091E4CE89FE4C to device 'SG:dev_21:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SG:dev_21:0'
DEBUG: Code 0 at pKR,,<Y4`?)Y\ru%M^:121264395
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..0E9610EB2DA3AF83A0E730B9EA2A538A6E5 to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..086EDDB01CE93A06C8EB30D4CB43B929CD9 to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..029363815771751EDC308DC6E0BD83D0087 to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..0B707BF3A012C54AAD014E7F732EFDC7947 to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..0F760810C32C73E19F9DA0C6A0FD2928416 to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..0F99EAE3E58FC5B5D8821077E00141B7655 to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..077D61987AEED0E3A37933AAD9BACA94180 to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..0FF15DD7E4284FBFEC43FEC091C4D876752 to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..0C82DF269A2B2BD531A04702E33CADA68C9 to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..0F81CA716D8386BEECC9708A5C0A1369FB6 to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..0D4BD4B38F4C1B5FF23B2D59C1E4AAB6368 to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..06DAEBEA3CEFCA696BF0B551B988A7985CA to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..0DBF103AAAD2B465C7ABB9631FDAAEC202C to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..0B63AC1CD8290A70336A6EFECC985640441 to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..0CD3E23BFC8E1CD311B1F01B70815FAE32C to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..0CD6C8009FB9544CCF93AA5AC0F5C25AC5A to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..0839D9E5B33B19FED2F9746000E7E8A391D to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..0F59E61F7FEB72F8CDE60D2AB95448C6523 to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..04607BA5211EFD08F6752B1AF58B596A0C6 to device 'SG:dev_21:0'
DEBUG: Code 0 at J9nz|TUj[9tsqH);:121268443
DEBUG: Code 0 at J9nz|TUj[9tsqH);:121267063
Title #00090.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00092.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01472.mpls has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
DEBUG: Code 0 at &NfZVA4WMEFg;8=P:213141852
DEBUG: Code 0 at @{s0#p_4!Po\J[hJ/:121263613
DEBUG: Code 0 at 71&Zr~Iv)1ip x1}:213142335
DEBUG: Code 0 at 71&Zr~Iv)1ip x1}:29397978
DEBUG: Code 0 at q#nl#`L7f`)}~1N~=Xli:29398461
DEBUG: Code 0 at ]63)-F}N^Nr}nj&h8:213133365
DEBUG: Code 0 at ]63)-F}N^Nr}nj&h8:29400071
DEBUG: Code 0 at :_ZjY%5_.'9[,F_d:121262578
DEBUG: Code 0 at MOzd~EW5Xo!5DlY:213138494
DEBUG: Code 0 at &NfZVA4WMEFg;8=P:29381878
Title #00800.mpls was skipped
Title #00900.mpls has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00901.mpls has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00702.mpls was skipped
Title #00705.mpls was skipped
Title #00902.mpls has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00903.mpls has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00091.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00093.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.mpls was skipped
Title #00100.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00101.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00102.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00103.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00104.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00105.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00106.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00107.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00108.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00109.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00110.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00111.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00112.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00113.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00114.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00115.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00116.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00117.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00118.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00119.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00120.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00121.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00122.mpls has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00123.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00203.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00204.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00205.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00206.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00207.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00208.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00209.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00210.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00211.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00212.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00213.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00214.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00215.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00216.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00710.mpls was skipped
Title #00720.mpls was skipped
Title #00730.mpls was skipped
Title #00731.mpls was skipped
Title #00732.mpls was skipped
Title #00733.mpls was skipped
Title #00734.mpls was skipped
Title #00735.mpls was skipped
Title #00736.mpls was skipped
Title #00737.mpls was skipped
Title #00001.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00030.m2ts has length of 85 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00031.m2ts has length of 85 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00143.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00144.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00145.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00146.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00147.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00100.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00101.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00102.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00103.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00104.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00105.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00106.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00107.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00108.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00109.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00110.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00111.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00112.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00113.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00114.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00115.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00116.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00117.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00118.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00119.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00120.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00121.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00122.m2ts has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00123.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00124.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00125.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00126.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00127.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00128.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00129.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00130.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00131.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00132.m2ts has length of 41 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00133.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00134.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00218.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00219.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00220.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00221.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00222.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00223.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00224.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00225.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00226.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00227.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00228.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00229.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00230.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00231.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00232.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00233.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00234.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00235.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00236.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00237.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00314.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00315.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00316.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00317.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00318.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00319.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00320.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00321.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00322.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00323.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00324.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00325.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00326.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00327.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00328.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00329.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00330.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00331.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00332.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00333.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00334.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00335.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00336.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00337.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00338.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00339.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00340.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00341.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00800.m2ts was skipped
Title #00905.m2ts has length of 48 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00906.m2ts was skipped
Title #00907.m2ts was skipped
Title #00908.m2ts was skipped
Title #00909.m2ts was skipped
Title #00910.m2ts was skipped
Title #00911.m2ts was skipped
Title #00912.m2ts was skipped
Title #00913.m2ts was skipped
Title #00914.m2ts was skipped
Title #00915.m2ts was skipped
Title #00916.m2ts has length of 117 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00917.m2ts was skipped
Title #00918.m2ts was skipped
Title #00919.m2ts was skipped
Title #00920.m2ts was skipped
Title #00921.m2ts was skipped
Title #00922.m2ts was skipped
Title #00923.m2ts was skipped
Title #00924.m2ts was skipped
Title #00925.m2ts has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00926.m2ts was skipped
Title #00927.m2ts was skipped
Title #00928.m2ts has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00929.m2ts has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00930.m2ts has length of 42 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00931.m2ts has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00932.m2ts has length of 44 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00933.m2ts has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00934.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00935.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00936.m2ts has length of 49 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00938.m2ts has length of 52 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00941.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
