Asus SBW-06D5H-U - Stopped Working
MagicianMoth
Post by MagicianMoth »
I have the above external DVD/Bluray drive which has been working fin for the past year, however it has recently started coming up with the following message;
Error 'Scsi error - HARDWARE ERROR:INTERNAL TARGET FAILURE' occurred while issuing SCSI command A30..01001000E0..0214F65476E654C6168430..0 to device 'SPTI:\Device\CdRom0'
Drive BD-RE ASUS SBW-06D5H-U E102 CLDL284244WL has RPC protection that can not be bypassed. Change drive region or update drive firmware from http://tdb.rpc1.org. Errors likely to follow.
Drive = Disc drive region 2, Disc Region 2
Anyone know whats causing it?
MagicianMoth
Asus SBW-06D5H-U - Stopped Working - Additional Info
Additional Information on MKV Drive
Current profile: DVD-ROM
Manufacturer: ASUS
Product: SBW-06D5H-U
Revision: E102
Serial number:
Firmware date: 2023-04-20
Highest AACS version: 70
Drive platform: RS8511
Firmware version: E102/ID26
Any help would be appreiated
MagicianMoth
Errror reports from MKV trying a Blueray Disc...
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..0F138EB4C416FD100E522641A04E94BAFFE to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..068C9961D7E40FBE48F6591FAD4202B2433 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..06572BEC553CBE1E9E8E661B8D455C90695 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..093139EEC782BF0DCBF19BC9B77DCDCBC99 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..01BECA7D32574A0B7C66F4E96B5BC8AC061 to device 'SPTI:\Device\CdRom0'
Any Ideas anyone..... Please
Re: Asus SBW-06D5H-U - Stopped Working
Have you power cycled the drive?
I've seen a couple of other people post on the forum with similar errors. I'm not sure what they mean.
MagicianMoth
Thanks for your reply....
If you mean - turned off Drive, Unplugged Drive from power and comp, then Restarted computer, I've done all that with no differnce to error.
I've even been to look for a flash, but can't see my drive, Asus or Pioneer on the listings
Any other ideas?
Thanks again....
Does the drive behave differently with a DVD vs a blu-ray?
MagicianMoth
Heres a selection of the errors when trying a Bluray, theres quite a few lines so this is just a selection;
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..053AA075562F783C943632C13E039ADD58D to device 'SPTI:\Device\CdRom0'
Eissuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
All the best and thanks again....
MagicianMoth
MKV details of sample Bluray disc and drive...
Manufacturer: ASUS
Revision: E102
Serial number: CLDL28424
Highest AACS version: 56
Disc Information
Label: DAD'S_ARMY
Timestamp: 2016-04-01 17:00:10
Protection: AACS v56
Data capacity: 23.86 Gb
Disc type: BD-ROM
Number of layers: 2
So can you rip the Bluray but not a DVD? Try to apply some logic if this only occurs with DVDs. All DVDs?
MagicianMoth
I can no longer rip DVD's or Bluray......
All the best
MagicianMoth
Just as an aside - It reads CD's perfectly
Thanks again for any help....
Kerubael
Post by Kerubael »
i have the exact same errors with the same drive and informations posted above. Running the Windows Version.
I've also installed makemkv on a separate linux pc with the exact same errors.
2 Month ago i've ripped a dozen dvds and blue rays without any error. Now with the same setup i can't rip neither.
I wonder, did MakeMKV produce a firmware dump file? If it did, it would be in the MakeMKV data directory. The General tab of MakeMKV's preferences lists the location of the data directory.
Kerubael
Post by Kerubael »
There are just the screen.conf, settings.conf, update.conf and the private_data.tar files in the makemkv data directory.
Theses are the logs of a failed blue ray:
MakeMKV v1.18.2 linux(x64-release) started
Debug logging enabled, log will be saved as /home/keru/MakeMKV_log.txt
DEBUG: Code 4278603778 at R}5I(mqyj*Y)l/y0L:121264878
Evaluation version, 29 day(s) out of 30 remaining
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..0A45C296406FA11AEDBAACBEB63FF15F74E to device 'SG:dev_21:0'
DEBUG: Code 0 at PwH=#GLZH Fj*4D?{:213130766
DEBUG: Code 0 at pKR,,<Y4`?)Y\ru%M^:121263429
DEBUG: Code 0 at pKR,,<Y4`?)Y\ru%M^:213130789
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..0B5C941A8400EA6D7F94CA54EB393C19EC0 to device 'SG:dev_21:0'
DEBUG: Code 1 at pKR,,<Y4`?)Y\ru%M^:213130789
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..080FC3924D43004CD03D73914142D595748 to device 'SG:dev_21:0'
DEBUG: Code 2 at pKR,,<Y4`?)Y\ru%M^:213130789
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..050445B29191DE8E681CAA5BB3AC67D93A3 to device 'SG:dev_21:0'
DEBUG: Code 3 at pKR,,<Y4`?)Y\ru%M^:213130789
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..08779B5C57F5283C5031960C2BA2B158EFB to device 'SG:dev_21:0'
DEBUG: Code 4 at pKR,,<Y4`?)Y\ru%M^:213130789
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..0864963550C893D561DAAFFB5726CA3A5B2 to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..01937BCCE9338EF5C113874F45B83759C63 to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..0F5E2C34B06A0E5A6F46E4EB240D6754027 to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..0A0B3E1E95906A16796D768ABE0FB3C34FB to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..0B8CDB5CB7BE8A81308DE46D58FAE86EF28 to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..086D10706A048277E36971F22ED01B0EE13 to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..0BD277799614B9DD2530A1001F814950041 to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..0E4A02A952E35F0091E652E8710C23F4E15 to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..019E9E8C82D6AC81A017E12CD2A3960DB47 to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..0F9049406AA64C03FEA0DBB8559D2DC6B45 to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..0512DB1F0BDECE837BBDBC0463F493127BF to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..00B7CBC733531AFBA3C0DB1345F829002DB to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..080742AA541DD2B9D526132C0813416A5AF to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..0F91DAFFEF9019613B4EBE5E456341AB65F to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..063E8DAB973D3D4EA408F6E18536A084EEB to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..0418A4E9AED1C9C5CDE193091E4CE89FE4C to device 'SG:dev_21:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SG:dev_21:0'
DEBUG: Code 0 at pKR,,<Y4`?)Y\ru%M^:121264395
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..0E9610EB2DA3AF83A0E730B9EA2A538A6E5 to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..086EDDB01CE93A06C8EB30D4CB43B929CD9 to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..029363815771751EDC308DC6E0BD83D0087 to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..0B707BF3A012C54AAD014E7F732EFDC7947 to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..0F760810C32C73E19F9DA0C6A0FD2928416 to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..0F99EAE3E58FC5B5D8821077E00141B7655 to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..077D61987AEED0E3A37933AAD9BACA94180 to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..0FF15DD7E4284FBFEC43FEC091C4D876752 to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..0C82DF269A2B2BD531A04702E33CADA68C9 to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..0F81CA716D8386BEECC9708A5C0A1369FB6 to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..0D4BD4B38F4C1B5FF23B2D59C1E4AAB6368 to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..06DAEBEA3CEFCA696BF0B551B988A7985CA to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..0DBF103AAAD2B465C7ABB9631FDAAEC202C to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..0B63AC1CD8290A70336A6EFECC985640441 to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..0CD3E23BFC8E1CD311B1F01B70815FAE32C to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..0CD6C8009FB9544CCF93AA5AC0F5C25AC5A to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..0839D9E5B33B19FED2F9746000E7E8A391D to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..0F59E61F7FEB72F8CDE60D2AB95448C6523 to device 'SG:dev_21:0'
Error 'Scsi error - BLANK CHECK:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A30..00200740100720..04607BA5211EFD08F6752B1AF58B596A0C6 to device 'SG:dev_21:0'
DEBUG: Code 0 at J9nz|TUj[9tsqH);:121268443
DEBUG: Code 0 at J9nz|TUj[9tsqH);:121267063
Title #00090.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00092.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01472.mpls has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
DEBUG: Code 0 at &NfZVA4WMEFg;8=P:213141852
DEBUG: Code 0 at @{s0#p_4!Po\J[hJ/:121263613
DEBUG: Code 0 at 71&Zr~Iv)1ip x1}:213142335
DEBUG: Code 0 at 71&Zr~Iv)1ip x1}:29397978
DEBUG: Code 0 at q#nl#`L7f`)}~1N~=Xli:29398461
DEBUG: Code 0 at ]63)-F}N^Nr}nj&h8:213133365
DEBUG: Code 0 at ]63)-F}N^Nr}nj&h8:29400071
DEBUG: Code 0 at :_ZjY%5_.'9[,F_d:121262578
DEBUG: Code 0 at MOzd~EW5Xo!5DlY:213138494
DEBUG: Code 0 at &NfZVA4WMEFg;8=P:29381878
Title #00800.mpls was skipped
Title #00900.mpls has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00901.mpls has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00702.mpls was skipped
Title #00705.mpls was skipped
Title #00902.mpls has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00903.mpls has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00091.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00093.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.mpls was skipped
Title #00100.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00101.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00102.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00103.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00104.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00105.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00106.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00107.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00108.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00109.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00110.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00111.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00112.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00113.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00114.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00115.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00116.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00117.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00118.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00119.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00120.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00121.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00122.mpls has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00123.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00203.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00204.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00205.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00206.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00207.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00208.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00209.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00210.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00211.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00212.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00213.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00214.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00215.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00216.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00710.mpls was skipped
Title #00720.mpls was skipped
Title #00730.mpls was skipped
Title #00731.mpls was skipped
Title #00732.mpls was skipped
Title #00733.mpls was skipped
Title #00734.mpls was skipped
Title #00735.mpls was skipped
Title #00736.mpls was skipped
Title #00737.mpls was skipped
Title #00001.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00030.m2ts has length of 85 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00031.m2ts has length of 85 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00143.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00144.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00145.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00146.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00147.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00100.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00101.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00102.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00103.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00104.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00105.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00106.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00107.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00108.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00109.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00110.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00111.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00112.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00113.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00114.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00115.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00116.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00117.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00118.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00119.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00120.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00121.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00122.m2ts has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00123.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00124.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00125.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00126.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00127.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00128.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00129.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00130.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00131.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00132.m2ts has length of 41 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00133.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00134.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00218.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00219.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00220.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00221.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00222.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00223.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00224.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00225.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00226.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00227.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00228.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00229.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00230.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00231.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00232.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00233.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00234.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00235.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00236.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00237.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00314.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00315.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00316.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00317.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00318.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00319.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00320.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00321.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00322.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00323.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00324.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00325.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00326.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00327.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00328.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00329.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00330.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00331.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00332.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00333.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00334.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00335.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00336.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00337.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00338.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00339.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00340.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00341.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00800.m2ts was skipped
Title #00905.m2ts has length of 48 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00906.m2ts was skipped
Title #00907.m2ts was skipped
Title #00908.m2ts was skipped
Title #00909.m2ts was skipped
Title #00910.m2ts was skipped
Title #00911.m2ts was skipped
Title #00912.m2ts was skipped
Title #00913.m2ts was skipped
Title #00914.m2ts was skipped
Title #00915.m2ts was skipped
Title #00916.m2ts has length of 117 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00917.m2ts was skipped
Title #00918.m2ts was skipped
Title #00919.m2ts was skipped
Title #00920.m2ts was skipped
Title #00921.m2ts was skipped
Title #00922.m2ts was skipped
Title #00923.m2ts was skipped
Title #00924.m2ts was skipped
Title #00925.m2ts has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00926.m2ts was skipped
Title #00927.m2ts was skipped
Title #00928.m2ts has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00929.m2ts has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00930.m2ts has length of 42 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00931.m2ts has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00932.m2ts has length of 44 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00933.m2ts has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00934.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00935.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00936.m2ts has length of 49 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00938.m2ts has length of 52 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00941.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
