SDF update November 2025
Re: SDF update November 2025
Post by Billycar11 » Thu Nov 20, 2025 10:26 pm
Coopervid wrote: Thu Nov 20, 2025 10:16 pm
Are you sure? 8801 indicates a S11 /211 drive.
i will have to check i have not powered mine on yet and probably wont for some time have a lot of xd08 to do
i assumed its the same hw as the x13 series as its in the same case and similar release date
Post by Coopervid » Thu Nov 20, 2025 10:35 pm
Billycar11 wrote: Thu Nov 20, 2025 10:26 pm
X13s are 94xx. 8801 seems to be a S11 /211.
Post by Billycar11 » Thu Nov 20, 2025 10:42 pm
Coopervid wrote: Thu Nov 20, 2025 10:35 pm
does seem to be the case
viewtopic.php?t=27378&start=1380#p171443
Post by Coopervid » Thu Nov 20, 2025 10:48 pm
Then should be sending it to Mike.
mc_link
Post by mc_link » Fri Nov 21, 2025 8:09 am
So, jury's still out on this one then it seems?
I sent a bin dump to Mike when I got it.
androgenix
Post by androgenix » Sat Nov 22, 2025 10:13 am
Just submitted Firmware Dump for Pioneer BDR-212U Revision 1.04 to support@makemkv.com
Just 1K - hopefully complete/correct
Let me know if not
drgonzo
Post by drgonzo » Sat Nov 22, 2025 10:44 pm
Just submitted the firmware dump from my Pioneer BDR-X13JX revision 1.04 to support@makemkv.com.
It was also just under 1K, but when I extracted it on my computer it came out to about 4.3MB.
wahyaza
Post by wahyaza » Sun Nov 23, 2025 8:05 am
I'm still getting errors on trying to open UHD on the BDR-213...what am I doing wrong?
(in the log window makemkv did download the new sdf on startup)
The error:
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
Saved AACS dump file as
Drive Info:
OS device name: L:
Manufacturer: PIONEER
Product: BD-RW BDR-213U
Revision: 1.05
Serial number:
Firmware date: 2023-08-01
Highest AACS version: 77
Drive platform: RS9201
Firmware name: PIONEER BDR-213T
Firmware version: 1.05/ID58
standforme
Post by standforme » Sun Nov 23, 2025 10:13 am
With my USB drives, I disconnect them, restart MKV, then try again, and after a couple tries, it'll work. If I understand correctly, if you start MakeMKV first, then insert the disc, assuming it has the right key, or can download it (downloading HKs can take seemingly forever), that shouldn't happen.
CmdrKodi
Post by CmdrKodi » Tue Dec 02, 2025 12:46 am
My BDR-212U has stopped working.
I know the firmware is too recent to allow UHDs, but it was working fine for bluray/dvd until 1.18.2. Now I can't get it to work at all. I've tried manually installing sdf.bin. I've tried completely removing my .MakeMKV directory and starting over. Nothing works. Drive reports its information (below), so I know it's still alive in some sense. But inserting a blu ray causes a the light to blink a few times and then the drive icon just spins forever.
Fedora Linux 36
MakeMKV 1.18.2 (also tried 1.18.1, known good release with blu ray that worked before).
Product: BD-RW BDR-212U
Revision: 1.04
Serial number:
Firmware date: 2022-12-20
Drive platform: Pioneer RS8F01
Firmware version: ID83
I can't get it to dump the firmware, or I'd send it in. Just guessing, but is this drive model close enough to one that works to cause the wrong firmware to be loaded? I guess I could be unlucky enough that I've had a hardware failure that coincides with upgrading makemkv, but I'm doubtful.
I have an older drive that continues to work fine:
Revision: 1.01
Serial number:
Firmware date: 2020-07-21
Drive platform: RS8F01
Firmware version: 1.01/ID58
Any guesses?
Post by Billycar11 » Tue Dec 02, 2025 1:52 am
CmdrKodi wrote: Tue Dec 02, 2025 12:46 am My BDR-212U has stopped working.
Fedora Linux 36
Revision: 1.04
Serial number:
Revision: 1.01
Serial number:
Any guesses?
always let the os see the disc first then open makemkv
if still nothing clean the lasers
CmdrKodi
Post by CmdrKodi » Tue Dec 02, 2025 2:12 am
Billycar11 wrote: Tue Dec 02, 2025 1:52 am always let the os see the disc first then open makemkv
It's never been necessary to "let the os see the disc", but tried it and same result. makemkv shows "scanning CD-ROM devices" forever. (I've scanned many multidisk tv series and have never quit makemkv, inserted the next disc and restarted makemkv. )
The optics aren't dirty. Older drive in same environment works fine.
It's too much coincidence for this not to at least be tangentially related to the recent Pioneer updates.
Post by MartyMcNuts » Tue Dec 02, 2025 2:37 am
CmdrKodi wrote: Tue Dec 02, 2025 2:12 am
Do other discs still work in this drive? Did you try cleaning the disc? H?ave you power cycled the drive since updating to the latest SDF.bin? Just because the older drive still works fine doesn't automatically mean the optics aren't dirty.
If you continue to dismiss options provided without even trying them, you won't get much more help.
CmdrKodi
Post by CmdrKodi » Tue Dec 02, 2025 3:27 am
No.
No. I don't have anything to clean with. It's not the problem, never has been. I don't smoke or have cats.
> Have you power cycled the drive since updating to the latest SDF.bin?
Yes. Many times during the course of debugging.
Sure. And they became dirty just as I updated. That's seems high probability.
If "clean the lasers" is your first response, what are you saving for later?
What -would- help is an SDF.bin from, say, August or earlier that's safely before any of the Pioneer updates. I'm looking through old backups now to try to find one. Never occurred to me I'd need to archive them.
nicholfd
Post by nicholfd » Tue Dec 02, 2025 3:37 am
CmdrKodi wrote: Tue Dec 02, 2025 3:27 am > Do other discs still work in this drive?
No.
When asking for volunteer help in a public forum, more humility & less attitude/sarcasm usually gets you further.
Good luck with *your* "problem".
