Lightning fast help from Coopervid. Much appreciated. Drive is now flashed to XD06U.Coopervid wrote: Tue Nov 04, 2025 6:19 pmPM is coming.oranje wrote: Tue Nov 04, 2025 6:16 pm I'm also looking for help with this drive. Thanks to Coopervid or others who can help!
Manufacturer: PIONEER
Product: BD-RW BDR-XD05
Revision: 1.20
Serial number: NCDL012674UC
Firmware date: 2013-11-15
Drive platform: RS8231
Firmware name: PIONEER BDR-XD05
Firmware version: 1.20
Do I need to flash my BDR-XD05
oranje
Re: Do I need to flash my BDR-XD05
sweetrap1
Could I get help with mine as well?
OS device name: H:
Revision: 3.01
Serial number:
Firmware date: 2014-12-26
Firmware version: 3.01/ID34
OS device name: H:
Revision: 3.01
Serial number:
PM sent.sweetrap1 wrote: Mon Dec 01, 2025 5:32 pm Could I get help with mine as well?
OS device name: H:
Revision: 3.01
Serial number:
vinylontubes
This is the Info on my drive. Is it possible to flash it?
OS device name: F:
Revision: 3.10
Serial number:
Firmware date: 2017-06-22
Drive platform: RS8232
Firmware version: 3.10/ID34
OS device name: F:
Revision: 3.10
Serial number:
PM sent.vinylontubes wrote: Fri Dec 05, 2025 4:37 pm This is the Info on my drive. Is it possible to flash it?
OS device name: F:
Revision: 3.10
Serial number:
sorrel
I also have one of these and a stack of 4k discs that won't play. I didn't realise this might be an option until I arrived here. Drive info:
Revision: 3.10
Serial number:
Highest AACS version: 82
Please let me know what ought to be done, happy to read tech docs...
Revision: 3.10
Serial number:
PM sent.sorrel wrote: Fri Dec 05, 2025 6:52 pm I also have one of these and a stack of 4k discs that won't play. I didn't realise this might be an option until I arrived here. Drive info:
Revision: 3.10
Serial number:
sorrel
Brilliant - worked well on my ARM windows within a VM. Will be thanking you!Coopervid wrote: Fri Dec 05, 2025 8:42 pmPM sent.sorrel wrote: Fri Dec 05, 2025 6:52 pm I also have one of these and a stack of 4k discs that won't play. I didn't realise this might be an option until I arrived here. Drive info:
Revision: 3.10
Serial number:
vinylontubes
I had some difficulty downloading the large file. But after doing a search on the file that wouldn't download, I could pick the file itself (instead of the folder) and it went through.Coopervid wrote: Fri Dec 05, 2025 4:43 pmPM sent.vinylontubes wrote: Fri Dec 05, 2025 4:37 pm This is the Info on my drive. Is it possible to flash it?
OS device name: F:
Revision: 3.10
Serial number:
Thank you!
Beefgrits
Sorry to bother, seems a popular question. Is uhd possible for older xd05 never updated? label says mfd September 2014 but drive platform seems to match others here.
Revision: 3.00
Serial number:
Firmware date: 2014-07-30
Firmware version: 3.00/ID34
D_Idaho
Is it possible to flash my Pioneer BDR-XD05 to read 4k blu-ray? Stats are below. Thank You
OS device name: E:
Revision: 3.10
Serial number:
Highest AACS version: 77
OS device name: E:
Revision: 3.10
Serial number:
PM sent.Beefgrits wrote: Thu Dec 11, 2025 6:55 pm Sorry to bother, seems a popular question. Is uhd possible for older xd05 never updated? label says mfd September 2014 but drive platform seems to match others here.
Revision: 3.00
Serial number:
PM sent.D_Idaho wrote: Fri Dec 12, 2025 2:56 am Is it possible to flash my Pioneer BDR-XD05 to read 4k blu-ray? Stats are below. Thank You
OS device name: E:
Revision: 3.10
Serial number:
Beefgrits
Thanks. Donation sent. Flash and test rip successful. New life to a decade old drive.
Coopervid wrote: Fri Dec 12, 2025 12:28 pmPM sent.Beefgrits wrote: Thu Dec 11, 2025 6:55 pm Sorry to bother, seems a popular question. Is uhd possible for older xd05 never updated? label says mfd September 2014 but drive platform seems to match others here.
Revision: 3.00
Serial number:
lilbob2619
I would like to know how to flash the This drive also
