USB Drive with Blu-ray disk stuck on "Disk is being loaded"
frank42
Post by frank42 »
Hi there,
I would like to have some assistance with my problem. I checked the FAQ and the "common problems" section, and I searched this forum for similar entries, but I found only one where the solution of OP was to "use another computer", which isn't really helpful for me :-)
I compiled and installed MakeMKV for linux v1.18.2 as described in viewtopic.php?f=3&t=224. The software seems to run as expected.
I connected a Blu-Ray drive via USB to my Linux Mint (Ubuntu) powered workstation. Additionally, it's powered with an external power supply to make sure USB power is not a problem. The drive works fine, the Blu-Ray disk in question works fine. I can watch the movie via vlc player.
When starting MakeMKV with debug log enabled, I see this output when trying to access the disk:
Debug log started at Wed Nov 26 13:14:02 2025 , written by MakeMKV v1.18.2 linux(x64-release)
001005:0000 MakeMKV v1.18.2 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file:///home/freddy/MakeMKV_log.txt
Network access is ENABLED, CURL version 8.5.0/OpenSSL/3.0.13/1.59.0 (x86_64-pc-linux-gnu) , proxy server not set.
001003:0020 DEBUG: Code 0 at [$&!cPHsNoNC,vJT%<05$ :29393631
No  SDF v0a3: HL-DT-ST_BD-RE_BU40N_1.05_212404231347_MZFP6AC1752
SDF id v0a3: HL-DT-ST_BD-RE_BU40N_1.05_212404231347_MZFP6AC1752
The software keeps showing "Loading disk" on the screen but doesn't do anything else. It's stuck at this point.
Creating an ISO file from the same Blu-Ray with dd and opening the image with MakeMKV, everything works fine, and I get the same debug output as above followed by
005053:0608 This functionality is shareware. You may evaluate it for 30 days after what you would need to purchase an activation key if you like the functionality. Do you want to start evaluation period now?
005050:0000 Evaluation version, 30 day(s) out of 30 remaining
DEBUG: Code 2147483648 at J9nz|TUj[9tsqH);:121265499
003338:0000 Downloading latest HK to /home/freddy/.MakeMKV ...
001003:0020 DEBUG: Code 0 at J9nz|TUj[9tsqH);:121267063
So, how can I narrow this down? I don't get any debug information besides the above mentioned, no errors either in the debug log or ring buffer or anywhere else...
Re: USB Drive with Blu-ray disk stuck on "Disk is being loaded"
You need to flash your drive to enable Libredrive support.
viewtopic.php?f=16&t=19634
Have you applied the beta key for Makemkv?
viewtopic.php?f=5&t=1053
frank42
Post by frank42 »
Hmmm,
thanks for the reply, but...
First: I find my drive HL-DT-ST-BD-RE_BU40N in the list of drives to flash, but the page is listing firmware revision 1.02 while my drive already has 1.05 installed.
Second: I tested with HandBrake (handbrake.fr) which a friend recommended, and that one does connect to the Blu-Ray drive without any problems (and without LibreDrive, whatever that is).
Also, as already stated, I can create an ISO file from the disk with dd and can encode from this one, so access to the media should already be possible without any flashing?
Or do I miss something here?
On Linux, BU40N drives often work better on 1.00 firmware. I do not know if that will solve your problem in this case.
https://forum.makemkv.com/forum/viewtopic.php?f=3&t=34312
Does MakeMKV get stuck 'loading' on every disc or just one or two discs?
