Coopervid wrote: Sun Nov 30, 2025 11:41 amPM sent.dsigma wrote: Sat Nov 29, 2025 9:28 pm Would love some help, @Coopervid
OS device name: H:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: DIDL127693WL
Firmware date: 2020-07-21
Highest AACS version: 82
Drive platform: RS8F00
Firmware version: E113/ID76
Pioneer RS8F00
dsigma
Re: Pioneer RS8F00
Thank you! (Too new here to reply to PM)
TimeSpace
Re: Pioneer RS8F00
I also have an ASUS BW-16D1X-U, but the Drive platform is listed as a: Pioneer RS8F00. I am new to the forum, but I figured posting in an existing one that best matched my situation might make more sense.
This is my drive information with the Serial number omitted :
I tried to review the main thread "Ultimate UHD Drives Flashing Guide Updated 2025", but this drive is not listed, but one like it is listed, but it sort of indicated it would be an LG, but based on the info it is a Pioneer RS8F00. Anyhow I got a little confused and figured I might ask some question before proceeding in an effort to avoiding any chance at bricking it.
Any help would be much appreciated,
Thanks.
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Firmware version: ID76
Thanks.
Re: Pioneer RS8F00
PM sent.TimeSpace wrote: Sun Nov 30, 2025 10:54 pm I also have an ASUS BW-16D1X-U, but the Drive platform is listed as a: Pioneer RS8F00. I am new to the forum, but I figured posting in an existing one that best matched my situation might make more sense.
This is my drive information with the Serial number omitted :I tried to review the main thread "Ultimate UHD Drives Flashing Guide Updated 2025", but this drive is not listed, but one like it is listed, but it sort of indicated it would be an LG, but based on the info it is a Pioneer RS8F00. Anyhow I got a little confused and figured I might ask some question before proceeding in an effort to avoiding any chance at bricking it.Code: Select all
Drive Information OS device name: G: Manufacturer: ASUS Product: BW-16D1X-U Revision: E113 Serial number: Firmware date: 2020-07-21 Bus encryption flags: 1B LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS8F00 Firmware version: ID76 No disc inserted
Thanks.
randy_br
Re: Pioneer RS8F00
Hi I also just got this drive and am hoping to get UHD working with it, normal backup of BR/DVD is working great, no updates have been done on the device. Currently using a Mac M2 if that makes any difference. The drive info to confirm it's the same as others in this thread:
OS device name: /dev/rdisk6
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: <removed>
Highest AACS version: 58
Firmware version: ID76-
etcetera
Re: Pioneer RS8F00
Wonder if I can make this drive read UHD. Thanks.
OS device name: /dev/sr0
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: **********
Highest AACS version: 68
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Re: Pioneer RS8F00
PM sent.randy_br wrote: Tue Dec 16, 2025 5:02 am Hi I also just got this drive and am hoping to get UHD working with it, normal backup of BR/DVD is working great, no updates have been done on the device. Currently using a Mac M2 if that makes any difference. The drive info to confirm it's the same as others in this thread:
Drive Information OS device name: /dev/rdisk6 Current profile: BD-ROM Manufacturer: ASUS Product: BW-16D1X-U Revision: E113 Serial number: <removed> Firmware date: 2020-07-21 Bus encryption flags: 1B Highest AACS version: 58 LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS8F00 Firmware version: ID76
TypTypTyp
Re: Pioneer RS8F00
Also have a rebranded Asus(BW-16D1X-U E113) Pioneer RS8F00 ID76 from 2020.
Since it isnt a LG, i can't follow the UHD flash guide. And would appreciate every information about the process with Pioneer drives.
I know its possible, but cant find the tools or firmwares.
Re: Pioneer RS8F00
Post your Makemkv info.TypTypTyp wrote: Thu Dec 18, 2025 9:14 pm Hello,
TypTypTyp
Re: Pioneer RS8F00
I started MakeMKV as admin and now it is Status enabled.
It has a Pioneer BDR-212T firmware.
Guess it was a lucky shot and compatible by default.
Re: Pioneer RS8F00
If you want to flash it for UHD compatibility you should post your Makemkv info.TypTypTyp wrote: Thu Dec 18, 2025 10:40 pm I started MakeMKV as admin and now it is Status enabled.
TypTypTyp
Re: Pioneer RS8F00
oh okey, a bit confused. It took me a while to get the informations right on what, is when, why needed. Also no real UHD on hand, so didnt came to the point of test that.Coopervid wrote: Fri Dec 19, 2025 12:27 pm
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: x
Re: Pioneer RS8F00
PM sent.TypTypTyp wrote: Fri Dec 19, 2025 4:15 pmoh okey, a bit confused. It took me a while to get the informations right on what, is when, why needed. Also no real UHD on hand, so didnt came to the point of test that.Coopervid wrote: Fri Dec 19, 2025 12:27 pm
Drive Information OS device name: /dev/sr0 Manufacturer: ASUS Product: BW-16D1X-U Revision: E113 Serial number: x Firmware date: 2020-07-21 Bus encryption flags: 1B LibreDrive Information Status: Enabled Drive platform: RS8F00 Firmware name: PIONEER BDR-212T Firmware type: Original (unpatched) Firmware version: E113/ID76 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes No disc inserted
darch
Re: Pioneer RS8F00
I have one of these that I'd like to get UHD-capable. I've got Linux and Mac, if that matters.
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Re: Pioneer RS8F00
PM sent.darch wrote: Sat Dec 20, 2025 7:00 pm I have one of these that I'd like to get UHD-capable. I've got Linux and Mac, if that matters.
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
etcetera
Re: Pioneer RS8F00
Can anybody help where I should post the inquiry? Been a few days and no reply in this forum so maybe there's a more suitable one. Thanks.
etcetera wrote: Tue Dec 16, 2025 8:39 am Wonder if I can make this drive read UHD. Thanks.
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
