Pioneer RS8F00
dsigma
Re: Pioneer RS8F00
#31 Post by dsigma » Sun Nov 30, 2025 1:46 pm
Thank you! (Too new here to reply to PM)
Coopervid wrote: Sun Nov 30, 2025 11:41 am
dsigma wrote: Sat Nov 29, 2025 9:28 pm Would love some help, @Coopervid :)
OS device name: H:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: DIDL127693WL
Firmware date: 2020-07-21
Highest AACS version: 82
Drive platform: RS8F00
Firmware version: E113/ID76
PM sent.
TimeSpace
Re: Pioneer RS8F00
#32 Post by TimeSpace » Sun Nov 30, 2025 10:54 pm
I also have an ASUS BW-16D1X-U, but the Drive platform is listed as a: Pioneer RS8F00. I am new to the forum, but I figured posting in an existing one that best matched my situation might make more sense.
This is my drive information with the Serial number omitted :
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Firmware version: ID76
I tried to review the main thread "Ultimate UHD Drives Flashing Guide Updated 2025", but this drive is not listed, but one like it is listed, but it sort of indicated it would be an LG, but based on the info it is a Pioneer RS8F00. Anyhow I got a little confused and figured I might ask some question before proceeding in an effort to avoiding any chance at bricking it.
Any help would be much appreciated,
Thanks.
Re: Pioneer RS8F00
#33 Post by Coopervid » Mon Dec 01, 2025 10:00 am
TimeSpace wrote: Sun Nov 30, 2025 10:54 pm I also have an ASUS BW-16D1X-U, but the Drive platform is listed as a: Pioneer RS8F00. I am new to the forum, but I figured posting in an existing one that best matched my situation might make more sense.
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Thanks.
PM sent.
randy_br
Re: Pioneer RS8F00
#34 Post by randy_br » Tue Dec 16, 2025 5:02 am
Hi I also just got this drive and am hoping to get UHD working with it, normal backup of BR/DVD is working great, no updates have been done on the device. Currently using a Mac M2 if that makes any difference. The drive info to confirm it's the same as others in this thread:
OS device name: /dev/rdisk6
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: <removed>
Highest AACS version: 58
etcetera
Re: Pioneer RS8F00
#35 Post by etcetera » Tue Dec 16, 2025 8:39 am
Wonder if I can make this drive read UHD. Thanks.
OS device name: /dev/sr0
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: **********
Highest AACS version: 68
Re: Pioneer RS8F00
#36 Post by Coopervid » Tue Dec 16, 2025 10:13 am
randy_br wrote: Tue Dec 16, 2025 5:02 am Hi I also just got this drive and am hoping to get UHD working with it, normal backup of BR/DVD is working great, no updates have been done on the device. Currently using a Mac M2 if that makes any difference. The drive info to confirm it's the same as others in this thread:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
PM sent.
TypTypTyp
Re: Pioneer RS8F00
#37 Post by TypTypTyp » Thu Dec 18, 2025 9:14 pm
Also have a rebranded Asus(BW-16D1X-U E113) Pioneer RS8F00 ID76 from 2020.
Since it isnt a LG, i can't follow the UHD flash guide. And would appreciate every information about the process with Pioneer drives.
I know its possible, but cant find the tools or firmwares.
Re: Pioneer RS8F00
#38 Post by Coopervid » Thu Dec 18, 2025 10:26 pm
TypTypTyp wrote: Thu Dec 18, 2025 9:14 pm Hello,
Post your Makemkv info.
TypTypTyp
Re: Pioneer RS8F00
#39 Post by TypTypTyp » Thu Dec 18, 2025 10:40 pm
I started MakeMKV as admin and now it is Status enabled.
It has a Pioneer BDR-212T firmware.
Guess it was a lucky shot and compatible by default.
Re: Pioneer RS8F00
#40 Post by Coopervid » Fri Dec 19, 2025 12:27 pm
TypTypTyp wrote: Thu Dec 18, 2025 10:40 pm I started MakeMKV as admin and now it is Status enabled.
If you want to flash it for UHD compatibility you should post your Makemkv info.
TypTypTyp
Re: Pioneer RS8F00
#41 Post by TypTypTyp » Fri Dec 19, 2025 4:15 pm
Coopervid wrote: Fri Dec 19, 2025 12:27 pm
oh okey, a bit confused. It took me a while to get the informations right on what, is when, why needed. Also no real UHD on hand, so didnt came to the point of test that.
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: x
Re: Pioneer RS8F00
#42 Post by Coopervid » Fri Dec 19, 2025 8:19 pm
TypTypTyp wrote: Fri Dec 19, 2025 4:15 pm
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: x
PM sent.
darch
Re: Pioneer RS8F00
#43 Post by darch » Sat Dec 20, 2025 7:00 pm
I have one of these that I'd like to get UHD-capable. I've got Linux and Mac, if that matters.
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Re: Pioneer RS8F00
#44 Post by Coopervid » Sat Dec 20, 2025 10:44 pm
darch wrote: Sat Dec 20, 2025 7:00 pm I have one of these that I'd like to get UHD-capable. I've got Linux and Mac, if that matters.
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
PM sent.
etcetera
Re: Pioneer RS8F00
#45 Post by etcetera » Sun Dec 21, 2025 8:02 pm
Can anybody help where I should post the inquiry? Been a few days and no reply in this forum so maybe there's a more suitable one. Thanks.
etcetera wrote: Tue Dec 16, 2025 8:39 am Wonder if I can make this drive read UHD. Thanks.
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
