PM sent.seanmurf wrote: Sat Nov 29, 2025 3:01 am Hello! I'm trying to rip my first 4k uhd and not able to show the disc as inserted, what is this magic in this thread and is it applicable? My drive info is:
OS device name: G:
Manufacturer: PIONEER
Product: BD-RW BDR-XD07
Revision: 1.02
Serial number: [redacted]
Firmware date: 2019-09-05
Bus encryption flags: 13
Highest AACS version: 82
Drive platform: RS8D30
Firmware version: 1.02
Thank you for any help!
BDR-XD07B UHD Flash
Re: BDR-XD07B UHD Flash
p51jd
I am also looking to flash my bluray drive to rip 4ks:
OS device name: E:
Revision: 1.03
Serial number:
Firmware date: 2020-08-20
Firmware version: 1.03
OS device name: E:
Revision: 1.03
Serial number:
PM sent.p51jd wrote: Sat Nov 29, 2025 2:42 pm I am also looking to flash my bluray drive to rip 4ks:
OS device name: E:
Revision: 1.03
Serial number:
seanmurf
Thank you! I'm up and running perfectly nowCoopervid wrote: Sat Nov 29, 2025 10:47 amPM sent.seanmurf wrote: Sat Nov 29, 2025 3:01 am Hello! I'm trying to rip my first 4k uhd and not able to show the disc as inserted, what is this magic in this thread and is it applicable? My drive info is:
OS device name: G:
Revision: 1.02
MarcG
I need help too getting to rip 4K. I have the BDR-XD07B.
OS device name: E:
Revision: 1.06
Serial number:
Firmware date: 2024-10-09
Highest AACS version: 68
Drive platform: Pioneer RS8D30
Firmware version: GENE
OS device name: E:
Revision: 1.06
Serial number:
Cannot be done. The firmware is post 11/2022 and cannot be cross-flashed for UHD compatibility but you can enable libredrive for standard bluray by downloading the latest SDF.bin and placing it in the MakeMKV data directory.MarcG wrote: Sun Nov 30, 2025 5:14 pm I need help too getting to rip 4K. I have the BDR-XD07B.
OS device name: E:
Revision: 1.06
Serial number:
kmacphail
I too would appreciate unlocking the 4K capabilities of my Pioneer.
OS device name: E:
Revision: 1.03
Highest AACS version: 81
OS device name: E:
Revision: 1.03
PM sent.kmacphail wrote: Tue Dec 02, 2025 12:48 pm I too would appreciate unlocking the 4K capabilities of my Pioneer.
OS device name: E:
Revision: 1.03
kmacphail
Easy process, works great! Thank you!
mookoo
Hi all, I would also like to flash my Pioneer drive to rip my 4K and would appreciate some help
OS device name: F:
Revision: 1.02
Serial number: -
OS device name: F:
Revision: 1.02
Serial number: -
PM sent.mookoo wrote: Wed Dec 10, 2025 9:18 pm Hi all, I would also like to flash my Pioneer drive to rip my 4K and would appreciate some help
OS device name: F:
Revision: 1.02
Serial number: -
mookoo
Thank you Coopervid! That worked perfectly
Rahan_Crao
Hello! I am also looking to flash my bluray drive to rip 4ks:
Revision: 1.04
Serial number:
Firmware date: 2022-05-31
Firmware version: 1.04
Revision: 1.04
Serial number:
PM sent.Rahan_Crao wrote: Sun Dec 28, 2025 3:29 pm Hello! I am also looking to flash my bluray drive to rip 4ks:
Revision: 1.04
Serial number:
Rahan_Crao
Thanks a lot, it works well.
