PM is coming. Not tricky, easy peasy...penguinparatrooper wrote: Tue Nov 18, 2025 3:59 pm Drive Information
OS device name: /dev/sr0
Manufacturer: PIONEER
Product: BD-RW BDR-S09
Revision: 1.34
Serial number:
Firmware date: 2016-04-25
Highest AACS version: 65
Drive platform: RS8600
Firmware version: 1.34/ID43
Coopervid, please PM me for firmware update info. I have been flashing LG drives just fine but these Pioneers are a bit tricky =)
Pioneer BDR-S09XLT LibreDrive ready but not ripping UHD-discs
Re: Pioneer BDR-S09XLT LibreDrive ready but not ripping UHD-discs
davej9343
Considering the current lack of availability of UHD-compatible drives on the market, would this ASUS drive I have knocking around able to read UHD discs with some help?
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E102
Serial number: QLDL153126WL
Firmware date: 2018-01-15
Highest AACS version: 63
Firmware version: E102/ID76
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E102
PM sent.davej9343 wrote: Wed Nov 19, 2025 3:38 am Considering the current lack of availability of UHD-compatible drives on the market, would this ASUS drive I have knocking around able to read UHD discs with some help?
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E102
Zaxx256
Could you please help me with my Asus drive? It looks pretty similar to the last one.
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E102
Serial number: QLDL120914WL
Firmware date: 2015-10-20
Highest AACS version: 75
Firmware version: E101/ID76
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E102
PM sent.Zaxx256 wrote: Fri Nov 21, 2025 8:02 pm Could you please help me with my Asus drive? It looks pretty similar to the last one.
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E102
censez41
hi every one
i bought this drive today
i need help to play uhd disk
my informations
thank you for helps
OS device name: H:
Revision: 1.20
Serial number: **********
Firmware date: 2014-04-08
Highest AACS version: 25
Firmware version: 1.20/ID43
my informations
thank you for helps
OS device name: H:
Revision: 1.20
PM sent.censez41 wrote: Sat Nov 29, 2025 10:56 am hi every one
my informations
thank you for helps
OS device name: H:
Revision: 1.20
censez41
Can i ask you somethingCoopervid wrote: Sun Nov 30, 2025 11:50 amPM sent.censez41 wrote: Sat Nov 29, 2025 10:56 am hi every one
my informations
thank you for helps
OS device name: H:
Revision: 1.20
Do software have legion lock?.. i live in turkey and i bought blueray film in my country ...any problems because of this software
Region lock doesn't have to do with the firmware. Makemkv doesn't care about it.
blurayerme
Hey Guys,
got this used Pioneer S09XLT drive today and firmware says from 2014.
As expected it reads normal BluRays but not 4K UHD discs.
Is it possible to flash the drive?
This is the MakeMKV information:
PM sent.blurayerme wrote: Mon Dec 01, 2025 5:03 pm Hey Guys,
Rockit1
Hi would it be possible for someone to send me the flashing tool please.I looked here when i first got my drive a few years ago but it was not listed as compatable then Thank you here's my drive info.
OS device name: E:
Revision: 1.51
Serial number:
Firmware date: 2018-05-08
Drive platform: RS8601
Firmware version: 1.51/ID43
OS device name: E:
Revision: 1.51
Serial number:
PM sent.Rockit1 wrote: Tue Dec 02, 2025 8:22 pm Hi would it be possible for someone to send me the flashing tool please.I looked here when i first got my drive a few years ago but it was not listed as compatable then Thank you here's my drive info.
OS device name: E:
Revision: 1.51
Serial number:
Rockit1
Thank you coopervid
maximum
Hello, I have the same problem.
Revision: 1.55
Serial number: NCDL008423WL
Firmware date: 2023-02-16
Firmware version: 1.55/ID43
Revision: 1.55
