All Pioneer drives will be LibreDrive supported
Re: All Pioneer drives will be LibreDrive supported
Post by Coopervid » Sun Nov 30, 2025 11:31 am
mossman1120 wrote: Sun Nov 30, 2025 9:08 am
MartyMcNuts wrote: Sun Nov 30, 2025 8:58 am
mossman1120 wrote: Sun Nov 30, 2025 8:49 am I just want to make sure I am understanding correctly.
Based on the SDF update November 2025 I see that there are a bunch of BDR-209D firmware versions listed:
PIONEER-BD-RW___BDR-209D-1.10-44290838-8600ID61-20130910
PIONEER-BD-RW___BDR-209D-1.20-90EB76E2-8600ID61-20140408
PIONEER-BD-RW___BDR-209D-1.30-6901C899-8600ID61-20141205
PIONEER-BD-RW___BDR-209D-1.31-8CF13BF3-8600ID61-20150525
PIONEER-BD-RW___BDR-209D-1.32-F3AD8FFF-8600ID61-20150825
PIONEER-BD-RW___BDR-209D-1.33-CC733748-8600ID61-20151209
PIONEER-BD-RW___BDR-209D-1.34-FCF25369-8600ID61-20160425
PIONEER-BD-RW___BDR-209D-1.50-7F6800F0-8600ID61-20171221
PIONEER-BD-RW___BDR-209D-1.50-F67F9D64-8601ID61-20171221
PIONEER-BD-RW___BDR-209D-1.51-148709AB-8600ID61-20180508
PIONEER-BD-RW___BDR-209D-1.51-664813FF-8601ID61-20180508
Would this mean that a a BDR-209DBK (I am going to assume that BK means black) manufactured in 2022 it should now work?
For standard blu-ray, yes. For UHD no. If the firmware is pre 12/2022 it can be cross-flashed to a UHD model firmware.
I would be looking to UHD. Is the cross flashing something that I could do myself? I have previous flashed LG drives.
If the drive is manufactured before 12/2022 would that mean the firmware is okay? Would the version be on the label or it is something that would need to be dumped from the drive?
You need to post your Makemkv info. Afterwards you will receive instructions for flashing your drive for UHDs.
mossman1120
Post by mossman1120 » Sun Nov 30, 2025 2:24 pm
Coopervid wrote: Sun Nov 30, 2025 11:31 am
So noted. For this model is there something to look for to make sure the firmware allows for flashing? Is the manufacture date sufficient?
Post by Coopervid » Sun Nov 30, 2025 2:37 pm
Post your Makemkv info.
mossman1120
Post by mossman1120 » Sun Nov 30, 2025 2:39 pm
Coopervid wrote: Sun Nov 30, 2025 2:37 pm Post your Makemkv info.
I don’t have it yet otherwise I would. Trying to avoid getting stuck with a drive that I can’t use.
Post by Coopervid » Sun Nov 30, 2025 3:49 pm
mossman1120 wrote: Sun Nov 30, 2025 2:39 pm
My crystal ball seems to be too dull. Get the drive and if it has firmware younger than 12/2022 it's fine. If not, return it.
BendingTorx
Post by BendingTorx » Tue Dec 09, 2025 7:59 pm
Here's a spare I just picked up from a yard sale, chinese box and all. Looks like the firmware is very recent. I'm wondering if it's possible with this one?
OS device name: E:
Current profile: DVD-ROM
Manufacturer: PIONEER
Product: BD-RW BDR-XD08
Revision: 1.04
Serial number:
Firmware date: 2024-10-09
Drive platform: Pioneer RS9330
Firmware version: GENE
bionicbuk
Post by bionicbuk » Tue Dec 09, 2025 8:29 pm
Hey @Mossman1120, got your DM. Sorry, did not have notifications on. Did you get a drive?
Post by MartyMcNuts » Tue Dec 09, 2025 10:46 pm
BendingTorx wrote: Tue Dec 09, 2025 7:59 pm Here's a spare I just picked up from a yard sale, chinese box and all. Looks like the firmware is very recent. I'm wondering if it's possible with this one?
OS device name: E:
Revision: 1.04
Serial number:
No, the firmware is post 11/2022 so cannot be cross-flashed for UHD compatibility but you can enable libredrive for standard blu-ray discs. Just download the latest SDF.bin and put it in the MakeMKV data directory then restart MakeMKV.
BendingTorx
Post by BendingTorx » Tue Dec 09, 2025 11:12 pm
MartyMcNuts wrote: Tue Dec 09, 2025 10:46 pm
OS device name: E:
Revision: 1.04
Serial number:
Thank you for the swift reply! I've missed forums haha
Will this firmware date eventually be possible to be cross-flashed? And I did add the sdf bin file, should the info panel be saying that libredrive is enabled now?
Post by MartyMcNuts » Tue Dec 09, 2025 11:29 pm
BendingTorx wrote: Tue Dec 09, 2025 11:12 pm
OS device name: E:
Revision: 1.04
Serial number:
Once you add the SDF.bin file to the MakeMKV data directory (where the dumps and private_data.tar file are located) you need to power cycle the drive and restart MakeMKV. The SDF.bin file will be absorbed into the private_data.tar file and LibreDrive should be enabled. If it still isn't enabled, insert a blu-ray disc into the drive and MakeMKV should create a firmware dump in the data directory for you to email to support@makemkv.com.
Stevey
Post by Stevey » Fri Dec 19, 2025 8:40 am
Good morning,
I have tried to get this to work on my drive with no look, my info is:
Product: BD-RW BDR-S13U
Revision: 1.04
Serial number: CEDL000416WL
Firmware date: 2022-12-12
Highest AACS version: 65
Drive platform: RS9201
Firmware name: PIONEER BDR-213T
Firmware version: 1.04/ID43
I get the following error
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
Downloading latest HK to C:\Users\steve/.MakeMKV ...
Can anyone help?
I have tried putting the file in the mkv folder, following the all the steps, i have tried uninstalling the software then deleting all folders and rebooting and reinstalling and this morning I have taken the drive into work and using a different pc and still getting the same issues, im not sure what i am doing wrong? Thanks for the help
Post by MartyMcNuts » Sat Dec 20, 2025 12:59 am
Stevey wrote: Fri Dec 19, 2025 8:40 am Good morning,
Revision: 1.04
Can anyone help?
Your drive is good to go. I suggest you power off the PC and drive for a few minutes before trying again.
Stevey
Post by Stevey » Fri Dec 26, 2025 6:15 pm
Thanks for the reply MartyMcNuts, I have tried turning it off and on again and it still comes up with the same error. I have taken the drive to my work and tried on my work PC with a fresh install of MakeMKV and still the same error. I have also tried with different Disc's and still get the same error. Blue rays work fine but no 4K discs work, they all come up with this error :cry:
bultom
Post by bultom » Sat Dec 27, 2025 5:45 pm
oops wrong thread :lol:
Stevey
Post by Stevey » Mon Dec 29, 2025 9:55 am
Stevey wrote: Fri Dec 26, 2025 6:15 pm Thanks for the reply MartyMcNuts, I have tried turning it off and on again and it still comes up with the same error. I have taken the drive to my work and tried on my work PC with a fresh install of MakeMKV and still the same error. I have also tried with different Disc's and still get the same error. Blue rays work fine but no 4K discs work, they all come up with this error :cry:
FYI it all seems to be working well now, thanks :D
