All Pioneer drives will be LibreDrive supported
Re: All Pioneer drives will be LibreDrive supported
Could you PM me pricing on your drives? Thanks!
g0th1ckn1ght wrote: Fri Oct 17, 2025 8:26 pmNo worries. I have an LG that I bought from Marty that I am using in the meantime. CheersCoopervid wrote: Fri Oct 17, 2025 8:19 pm You gotta wait until Mike comes up with a solution. No ETA. But he pomised.
Word on the street from sources I would consider reliable is that it will be Real Soon Now(tm),
- Contact:
"You are not authorised to read this forum" - what gives?
That was a temporary message.Mr_Orange wrote: Tue Nov 04, 2025 10:05 pm"You are not authorised to read this forum" - what gives?
Unplanned9977
So? Automatic doesn't work.Unplanned9977 wrote: Tue Nov 04, 2025 10:08 pm Mike basically reset that post:
viewtopic.php?f=19&t=39869
Thanks but it didn't redirect.Unplanned9977 wrote: Tue Nov 04, 2025 10:08 pm Mike basically reset that post:
Unplanned9977
Not for me presently but I'm only 1 interested user.
Unplanned9977
It wasn't meant to. My guess is he recreated the 'SDF update November 2025' post, which is now the link I shared. Maybe I'm wrong.Mr_Orange wrote: Tue Nov 04, 2025 10:12 pmThanks but it didn't redirect.Unplanned9977 wrote: Tue Nov 04, 2025 10:08 pm Mike basically reset that post:
This new SDF, once working, still doesn't make a drive read UHD, right?
Not unless you have a UHD model.OB11BO wrote: Wed Nov 05, 2025 12:17 am This new SDF, once working, still doesn't make a drive read UHD, right?
mossman1120
I just want to make sure I am understanding correctly.
Based on the SDF update November 2025 I see that there are a bunch of BDR-209D firmware versions listed:
Would this mean that a a BDR-209DBK (I am going to assume that BK means black) manufactured in 2022 it should now work?
PIONEER-BD-RW___BDR-209D-1.10-44290838-8600ID61-20130910
PIONEER-BD-RW___BDR-209D-1.20-90EB76E2-8600ID61-20140408
PIONEER-BD-RW___BDR-209D-1.30-6901C899-8600ID61-20141205
PIONEER-BD-RW___BDR-209D-1.31-8CF13BF3-8600ID61-20150525
PIONEER-BD-RW___BDR-209D-1.32-F3AD8FFF-8600ID61-20150825
PIONEER-BD-RW___BDR-209D-1.33-CC733748-8600ID61-20151209
PIONEER-BD-RW___BDR-209D-1.34-FCF25369-8600ID61-20160425
PIONEER-BD-RW___BDR-209D-1.50-7F6800F0-8600ID61-20171221
PIONEER-BD-RW___BDR-209D-1.50-F67F9D64-8601ID61-20171221
PIONEER-BD-RW___BDR-209D-1.51-148709AB-8600ID61-20180508
PIONEER-BD-RW___BDR-209D-1.51-664813FF-8601ID61-20180508
For standard blu-ray, yes. For UHD no. If the firmware is pre 12/2022 it can be cross-flashed to a UHD model firmware.mossman1120 wrote: Sun Nov 30, 2025 8:49 am I just want to make sure I am understanding correctly.
Based on the SDF update November 2025 I see that there are a bunch of BDR-209D firmware versions listed:Would this mean that a a BDR-209DBK (I am going to assume that BK means black) manufactured in 2022 it should now work?Code: Select all
PIONEER-BD-RW___BDR-209D-1.10-44290838-8600ID61-20130910 PIONEER-BD-RW___BDR-209D-1.20-90EB76E2-8600ID61-20140408 PIONEER-BD-RW___BDR-209D-1.30-6901C899-8600ID61-20141205 PIONEER-BD-RW___BDR-209D-1.31-8CF13BF3-8600ID61-20150525 PIONEER-BD-RW___BDR-209D-1.32-F3AD8FFF-8600ID61-20150825 PIONEER-BD-RW___BDR-209D-1.33-CC733748-8600ID61-20151209 PIONEER-BD-RW___BDR-209D-1.34-FCF25369-8600ID61-20160425 PIONEER-BD-RW___BDR-209D-1.50-7F6800F0-8600ID61-20171221 PIONEER-BD-RW___BDR-209D-1.50-F67F9D64-8601ID61-20171221 PIONEER-BD-RW___BDR-209D-1.51-148709AB-8600ID61-20180508 PIONEER-BD-RW___BDR-209D-1.51-664813FF-8601ID61-20180508
mossman1120
I would be looking to UHD. Is the cross flashing something that I could do myself? I have previous flashed LG drives.MartyMcNuts wrote: Sun Nov 30, 2025 8:58 amFor standard blu-ray, yes. For UHD no. If the firmware is pre 12/2022 it can be cross-flashed to a UHD model firmware.mossman1120 wrote: Sun Nov 30, 2025 8:49 am I just want to make sure I am understanding correctly.
If the drive is manufactured before 12/2022 would that mean the firmware is okay? Would the version be on the label or it is something that would need to be dumped from the drive?
