Hello All! I'm new to the scene with an internal 2018 LG WH14NS40 Blu-Ray/DVD/CD Writer, and would really appreciate some Help.
Essentially, I picked the wrong Firmware, and it prevented me from ejecting the tray. That was fixed(thanks to the video on the Ultimate Guide) but now discs are no longer read. I've tried DVDs and Blu-Ray discs, but neither works. The drive itself still flashes, and MakeMKV recognizes that a disc is inserted but ultimatly stops and asks for a disc to be inserted. Thank you for your response
OS device name: F:
Product: BD-RE WH14NS40
Revision: 1.02
Serial number:
Firmware date: 2115-12-11 15:03
Highest AACS version: 81
Firmware version: 1.02
WH14NS40 not reading
Re: WH14NS40 not reading
Is your sn actually blank?96Chaser wrote: Sat Nov 29, 2025 4:58 pm Hello All! I'm new to the scene with an internal 2018 LG WH14NS40 Blu-Ray/DVD/CD Writer, and would really appreciate some Help.
OS device name: F:
Revision: 1.02
Serial number:
If so you forgot your cal data
I can give you some but before we do that post your build date sticker from your drive
96Chaser
Billycar11 wrote: Sat Nov 29, 2025 8:42 pmIs you and actually blank?96Chaser wrote: Sat Nov 29, 2025 4:58 pm Hello All! I'm new to the scene with an internal 2018 LG WH14NS40 Blu-Ray/DVD/CD Writer, and would really appreciate some Help.
OS device name: F:
Revision: 1.02
Serial number:
Cal?
https://imgur.com/a/Ezt4lpB
96Chaser
I'm sorry. The imgur is a photo of my Drive's sticker
Ok look like the correct drive
Now for the question auto correct butchered
Is your drive sn actually blank ?
96Chaser
The sticker has a S/N but the MakeMV shows it as a diffrent SN(possibly from another flash).Billycar11 wrote: Sun Nov 30, 2025 10:09 pmOk look like the correct drive
I tried reflashing and currently it shows "
OS device name: F:
Revision: 1.03
Serial number: M6JIA172052
Firmware date: 2117-11-21 16:58
Firmware version: 1.03
Still unable to read discs though.
if you stll have a sn your drive fw is likely fine lg fw and hw sn never match.96Chaser wrote: Sun Nov 30, 2025 10:37 pmThe sticker has a S/N but the MakeMV shows it as a diffrent SN(possibly from another flash).Billycar11 wrote: Sun Nov 30, 2025 10:09 pmOk look like the correct drive
OS device name: F:
Revision: 1.03
your only shot is probably cleaning the lasers
but since you have wrong fw you likely fried lasers
96Chaser
I think your right. I just tried a CD, DVD, and a BluRay disc. The CD worked but it thinks that their blank and wants to format itBillycar11 wrote: Mon Dec 01, 2025 5:10 amif you stll have a sn your drive fw is likely fine lg fw and hw sn never match.96Chaser wrote: Sun Nov 30, 2025 10:37 pmThe sticker has a S/N but the MakeMV shows it as a diffrent SN(possibly from another flash).Billycar11 wrote: Sun Nov 30, 2025 10:09 pm
OS device name: F:
Revision: 1.03
