hello
i say this message a couple of times today and i was like ????? the system i use is a monster 20 core unit latest everything 128gb ram and i get this message ?
i looked at the board and found several old old messages last one was from 2020 prior was before 2011 im using a LG blu ray m disc patched and no issue since patching over as year ago. it works great even when i cannot use my old faithful win 10 machine i9 built crazy also most discs I'm ripping are aacs 81 also these r blu rays I'm ripping that gives me this message, any ideas or ??? also when is next update beyond 81
Program reads data faster than it can write to disk
Back_up_AZ
Re: Program reads data faster than it can write to disk
Disk writing speed is most important here. If you can read disks quickly, you have to be able to store what's read just as quickly... and a lot of times, your disk write speed isn't as fast as you're thinking it is.
I typically would write to an 8-drive array, feeding it with 2 or 3 disks. When I would get that message, I would have to check my network cables, because it usually indicated that one was failing.
I would see it more often when I was writing to a local disk, WHILE doing other things. The network provided buffering that local wasn't. MakeMKV has surprisingly little overhead, but it can push your hardware. I ran tests with a Wintel miniature computer a few years ago; it could only manage a 10mb/s connection to the server, although it never actually reached that speed when writing. It had a small local disk, but not enough to hold a DVD or BD worth of data, so it was limited to network... and always posted that message.
That experiment ended when I got sick of having it NOT report that it had finished reading a disk until it finished writing it to storage, which sometimes took several minutes as the cache was emptied out. Gigabit networking and wide-bandwidth servers for the win!
I make decrypted backups of discs first and then create .mkv files from the backup. I see that message every single time when creating .mkv files. Granted, it is usually writing files at 400MB/s when I see those messages, but I see them. They're informational and in my case speak more to the limits of my local USB bus and the SSD hanging off it. In other cases, as Woodstock mentioned, they might indicate the network or NAS is busy or that a cable is failing. Or it might be that your machine is busy doing something else, installing an update of some kind maybe.
Unless something else is wrong on your computer, it probably doesn't really matter.
Back_up_AZ
ssd 2tb 6gbps drive makemkv is writing to never saw it before, but i was reading 22mbps on the drive 7.3 speed to a ssd onboard not on same drive as system
yauumm
In case of making mkv files from a decrypted backup on the same drive it is expected that the drive can read data faster than write. I got that message in this case too and upgrading the drive (as suggested by the message) won't change that, obviously. In my opinion, the message doesn't make sense when the source is not a physical disc (dvd or blu-ray)—at least not, when source and destination are on the same drive.
When making backups from blu-ray discs I got this message because my destination ssd was old and dropped significantly in (reading and writing) speed from time to time. Never had it happen again after buying a new pc with a new ssd.
LottieRoss
What’s the exact error you’re seeing and is it on all discs or just some?
Back_up_AZ
i just say it on one maybe two new blu ray discs, looked at my old 4td ssd and almost cried when i read the xfer rates so i just picked up a new m.2 ssd 4 tb with this...
EVERY TASK, TURBOCHARGED: Speed past productivity limits. With random read/write speeds up to 2,200K/2,600K IOPS, enjoy fast game loads, seamless AI apps, and efficient multitasking. Virtually no lag, no limits—just nonstop performance. now if i get that message again ill send a report to the admin but i don't think i 'll b sending any. the data just keeps getting larger. i'm looking for a petabyte system next
