BrantleyF
Post
by BrantleyF » Wed Nov 26, 2025 8:35 am
Hi @coopervid,
Thank you very much for the PM!
Before I upgraded the firmware I looked into MakeMKV again an realised that the status actually says "Enabled", just like in my initial message that I posted in the form. I must have missed that because I'm 100% sure it stated "Possible, not yet enabled", the first time I started MakeMKV.
Between both outputs changing I have only started SDFtool Flascher (v1.3.6) but didn't flash anything.
So, my question is, do I need to flash my drive with the fw you provided (S8F01430.100 & S8F01431.102) or is that not necessary.
Coopervid wrote: Tue Nov 25, 2025 3:59 pm
BrantleyF wrote: Tue Nov 25, 2025 2:56 pm
Please assist with the upgrade of Pioneer drive to read UHD.
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: DIDL1*******
Firmware date: 2020-07-21
Drive platform: RS8F00
Firmware version: E113/ID76
With thanks in advance
Brantley
PM sent.
Post
by Coopervid » Wed Nov 26, 2025 1:59 pm
BrantleyF wrote: Wed Nov 26, 2025 8:35 am
Hi @coopervid,
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Brantley
PM sent.
Libredrive enabled doesn't equal UHD capability. If you want to read UHDs you MUST flash the drive with the package you have now.
BrantleyF
Post
by BrantleyF » Wed Nov 26, 2025 2:40 pm
Thank you very much for the clarification!
diggs94
Post
by diggs94 » Wed Nov 26, 2025 7:24 pm
Thanks for helping so many people out!
I purchased a Pioneer BDR-209 drive. Can you provide assistance to enable it to read UHD discs?
It is on a Windows 11 machine
Here is the information in MakeMKV without a disc inserted:
OS device name: F:
Manufacturer: PIONEER
Product: BD-RW BDR-209M
Revision: 1.33
Serial number: PADL046070WL
Firmware date: 2015-12-09
Highest AACS version: 63
Drive platform: RS8600
Firmware version: 1.33
Apollo821
Post
by Apollo821 » Wed Nov 26, 2025 7:41 pm
MartyMcNuts wrote: Wed Nov 26, 2025 4:18 am
Apollo821 wrote: Wed Nov 26, 2025 1:52 am
Hello, friends!
I've got an XD08...is this flashable or otherwise upgradeable to rip UHDs? I'm a little lost.
Product: BD-RW BDR-XD08
Revision: 1.02
Serial number:
Firmware date: 2022-12-27
Highest AACS version: 60
Drive platform: RS9330
Firmware name: PIONEER BDR-BDS8
Firmware version: 1.02
No. The firmware is post 11/2022 and cannot be cross-flashed at this stage. You will have to wait for possible future cross-flash support.
Thanks so much for the clarification!
Post
by Coopervid » Wed Nov 26, 2025 9:25 pm
diggs94 wrote: Wed Nov 26, 2025 7:24 pm
OS device name: F:
Revision: 1.33
PM sent.
BrantleyF
Post
by BrantleyF » Fri Nov 28, 2025 10:41 am
Once again, thank you!
With the files provided I was able to change the firmware and make my drive UHD ready
Product: BD-RW BDR-S12U
Revision: 1.02
Firmware date: 2022-03-07
Highest AACS version: 77
Drive platform: RS8F01
Firmware version: 1.02/ID43
Coopervid wrote: Wed Nov 26, 2025 1:59 pm
Hi @coopervid,
PM sent.
Post
by Coopervid » Fri Nov 28, 2025 10:43 am
OS device name: F:
Revision: 1.33
PM sent.
aaditya
Post
by aaditya » Fri Nov 28, 2025 10:18 pm
To: Coopervid
I also have a Pioneer BDR-212T and am looking for the appropriate LibreDrive firmware.
OS device name: /dev/sr0
Product: BD-RW BDR-212D
Revision: 1.02
Serial number: DG**
Firmware date: 2022-03-16
Bus encryption flags: 13
Highest AACS version: 82
Firmware version: 1.02/ID61
Could I ask you to send me the appropriate information please?
Post
by Coopervid » Fri Nov 28, 2025 11:10 pm
aaditya wrote: Fri Nov 28, 2025 10:18 pm
To: Coopervid
Revision: 1.02
Serial number: DG**
PM sent.
aaditya
Post
by aaditya » Sat Nov 29, 2025 1:38 am
Cheers mate!
royale011
Post
by royale011 » Sat Nov 29, 2025 3:34 am
Hello there, I have XS08MB-S. Is there any chance to get LibreDrive firmware w/ UHD supported?
Product: BD-RW BDR-XS08U
Revision: 1.03
Serial number: BJDL000979JP
Firmware date: 2024-10-09
Highest AACS version: 76
Drive platform: RS9621
Firmware version: 1.03/ID69
Post
by MartyMcNuts » Sat Nov 29, 2025 5:12 am
royale011 wrote: Sat Nov 29, 2025 3:34 am
Revision: 1.03
This a UHD drive. It's already libredrive enabled and is ready to rip UHD discs. Pop in a UHD disc and start ripping it!
For UHD enabled drives (AU/NZ/SG + Others) & DIY Single Drive Flasher (WW):
https://uhdenableddrives.com
foxale08
Post
by foxale08 » Sat Nov 29, 2025 10:26 am
Update 2: the drive physically says "BDR-UD04TBD" on the outside. (I'm adding this information so it may benefit others.)
Update: I figured it out. I needed an SDF update (manually downloaded sdf.bin, placed it in %UserProfile%\.MakeMKV
and fully shut down then turned the computer back on.) Not sure why MakeMKV didn't download the newest SDF file, it's a new install.
Drive platform: RS8A10
Firmware version: 1.20/ID84
SDF v0a3: PIONEER_BD-RW__BDR-UD04D_1.20_XXXXXXXXXXXX
DEBUG: Code 3 at R/Ru3B(Mxaw 4&z'5FC}$>4::29395310
Hello, I have a BDR-UD04D from Japan which is mounted in a desktop PC (power shouldn't be an issue) the drive appears to be able to read normal Blu-ray disks fine but I get a crap ton of errors (and eventual failure to open disk, example error below) while attempting to read UHDs.
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..0BF to device 'SPTI:\Device\CdRom0'
DEBUG: Code 0 at -J6231Kpvy%-_GfBo:213130766
From MakeMKV 1.18.2
OS device name: G:
Product: BD-RW BDR-UD04D
Revision: 1.20
Serial number: XXXXXXXXXXXX
Firmware date: 2017-09-26
Drive platform: Pioneer RS8A10
Firmware version: ID84
Relevant logs show the following:
001003:0020 DEBUG: Code 0 at 3}LEXDFfdV,&S#:f:121276424
No SDF v097: PIONEER_BD-RW__BDR-UD04D_1.20_XXXXXXXXXXXX
DEBUG: Code 0 at ^\4O;l[]cZAB>C:7o:29396253
DEBUG: Code 0 at lS]g`,`;]*O'8w*t:213136746
SDF id v097: PIONEER_BD-RW__BDR-UD04D_1.20_XXXXXXXXXXXX
I am doing something wrong here?
foxale08 on Sun Nov 30, 2025 2:53 am, edited 1 time in total.
Webraider72
Post
by Webraider72 » Sun Nov 30, 2025 1:50 am
Good evening,
Here are the credentials of my drive. This Is the first time it has shown status Enabled for LibreDrive since I owned it and it was one of the dreadful firmware 1.03 which wasn't supported initially. As this is a UHD "capable" drive, Do I still need to flash it to rip UHD? I have a Mac by the way, and don't have access to windows. Thank you in advance!
Product: BD-RW BDR-XS07U
Revision: 1.03
Serial number: CEDL012202UC
Firmware date: 2023-01-06
Drive platform: RS8E21
Firmware version: 1.03/ID05
Webraider72 on Mon Dec 01, 2025 4:41 am, edited 1 time in total.
