Verbatim 43890 External Slimline Mobile USB 3.2 Blu-ray Writer UHD Problem
symseven
Re: Verbatim 43890 External Slimline Mobile USB 3.2 Blu-ray Writer UHD Problem
Post by symseven » Sun Nov 16, 2025 7:30 pm
Hi Coopervid, I'd like my Verbatim drive to support UHD, would you also help me out? Many thanks!
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number:
Firmware date: 2020-06-15
Drive platform: RS8511
Firmware version: 1.14
Post by Coopervid » Tue Nov 18, 2025 10:02 am
gundelpfanne wrote: Sun Nov 16, 2025 10:58 am Hello i have a Problem with my BDR Pioneer.
Laufwerksinformation
OS-Gerätename: L:
Aktuelles Profil: DVD-ROM
Produzent: PIONEER
Produkt: BD-RW BDR-UD03
Revision: 1.11
Serienummer:
Firmware-Datum: 2018-11-28
Firmware version: 1.11
Keine Disk eingelegt
Can i have the modded Firmware.
Thank You
mfg gundelpfanne
PM sent.
Post by Coopervid » Tue Nov 18, 2025 10:04 am
symseven wrote: Sun Nov 16, 2025 7:30 pm Hi Coopervid, I'd like my Verbatim drive to support UHD, would you also help me out? Many thanks!
OS device name: E:
Revision: 1.14
Serial number:
PM sent.
GRS97
Post by GRS97 » Wed Nov 26, 2025 10:46 am
Hi Coopervid, I just bought this drive thinking it supported UHD but I tried a disc and nothing happened. like my Verbatim drive to support UHD, would you also help me out? Many thanks!
OS device name: E:
Product: BD-RE BU40N
Revision: 1.03
Serial number:
Firmware version: 1.03
Post by MartyMcNuts » Wed Nov 26, 2025 11:54 pm
GRS97 wrote: Wed Nov 26, 2025 10:46 am Hi Coopervid, I just bought this drive thinking it supported UHD but I tried a disc and nothing happened. like my Verbatim drive to support UHD, would you also help me out? Many thanks!
OS device name: E:
Revision: 1.03
Serial number:
Your drive is already libredrive enabled and UHD ready. If it won't read UHD discs you have some other issue. Try pasting MakeMKV's log window text when attempting to rip a UHD disc and we might be able to help further.
Also, you should insert the disc and let the OS initiialise it (you should see it in windows explorer) before you open MakeMKV.
Sam1969
Post by Sam1969 » Fri Nov 28, 2025 2:05 am
Hi, I got a Verbatim 43889 with the following Information. What are the steps for making it UHD ready?
Thanks a lot for support.
OS-Gerätename: G:
Produzent: PIONEER
Revision: 1.14
Serienummer: ALDL....
Firmware-Datum: 2020-06-15
Post by Coopervid » Fri Nov 28, 2025 10:33 am
Sam1969 wrote: Fri Nov 28, 2025 2:05 am Hi, I got a Verbatim 43889 with the following Information. What are the steps for making it UHD ready?
OS-Gerätename: G:
Produzent: PIONEER
Revision: 1.14
PM sent.
StarryEyed
Post by StarryEyed » Fri Nov 28, 2025 1:41 pm
My optical drive has recently failed so looking to get a replacement. Before purchasing can I ask a sanity check please: if I get a Verbatim 43890 will I be able to flash this drive myself?
Post by Coopervid » Fri Nov 28, 2025 1:54 pm
StarryEyed wrote: Fri Nov 28, 2025 1:41 pm My optical drive has recently failed so looking to get a replacement. Before purchasing can I ask a sanity check please: if I get a Verbatim 43890 will I be able to flash this drive myself?
If it's new stock it contains a LG BU40N and you can flash it according to the UHD guide. If it's old stock it might contain a Pioneer UD03 and you have to post again so I will forward a package to flash it.
wizrd54
Post by wizrd54 » Wed Dec 03, 2025 10:59 pm
I just purchased a Verbatim 43890 drive and I'm looking for some assistance to make it UHD capable. My drive information is listed below. Thank you in advance.
OS device name: F:
Revision: 1.14
Serial number:
Post by Coopervid » Thu Dec 04, 2025 10:35 am
wizrd54 wrote: Wed Dec 03, 2025 10:59 pm I just purchased a Verbatim 43890 drive and I'm looking for some assistance to make it UHD capable. My drive information is listed below. Thank you in advance.
OS device name: F:
Revision: 1.14
Serial number:
PM sent.
ahaddadin
Post by ahaddadin » Thu Dec 04, 2025 11:39 pm
just got this drive and its not reading uhd disks
Revision: 1.14
Serial number:
Post by MartyMcNuts » Fri Dec 05, 2025 3:25 am
ahaddadin wrote: Thu Dec 04, 2025 11:39 pm just got this drive and its not reading uhd disks
Revision: 1.14
Serial number:
Please don't post the same thing in multiple threads. Your other post has been answered.
bdr485
Post by bdr485 » Sat Dec 06, 2025 1:22 am
OS device name: F:
Revision: 1.14
Serial number:
Highest AACS version: 68
Post by Coopervid » Sat Dec 06, 2025 10:36 am
bdr485 wrote: Sat Dec 06, 2025 1:22 am I just purchased a Verbatim 43890 drive and I'm looking for some assistance to make it UHD capable. My drive information is listed below. Thank you in advance.
OS device name: F:
Revision: 1.14
Serial number:
PM sent.
