Rough Guide: v1.18.1 on CachyOS(Arch Linux)
jayandp
#1 Post by jayandp » Fri Sep 19, 2025 7:01 am
I've managed to get MakeMKV v1.18.1 working with my Pioneer BD-RW BDR-S13U on my CachyOS install, including UHD discs, so thought I'd go through the steps I did to get it working, just in case it could help others figure out there own setups. Some of these steps might be redundant, but I wanted to note everything just in case.
Not sure if it ended up being relevant, but I first installed MakeMKV as a Flatpak, and then downgraded that to v1.17.9.
flatpak install makemkv
flatpak update --commit=df0d21a85e16b61460d1168a5d14e8963b836881bec7c6352a8d4f6be4a1f414 com.makemkv.MakeMKV
Then I made sure my drive was detected using:
sudo modprobe sg
sudo bash -c 'echo sg > /etc/modules-load.d/sg.conf'
Next I opened MakeMKV Flatpak, made sure it detected my drive, and then I registered my key. This way ~/.MakeMKV/_private_data.tar was generated. Then I closed it and removed the flatpak.
flatpak remove makemkv
Next I installed native versions of both VLC, and Kodi. We'll need VLC's plugins to make sure it works. Plus we'll install the correct version of Java for the Blu-ray menus while we're at it, since by default a newer incompatible version of Java is setup in many cases. Also installing the following libs seems to help.
sudo pacman -S vlc vlc-plugins-all kodi jre17-openjdk libbluray libdvdnav aribb24
sudo archlinux-java set java-17-openjdk
Next we'll install native MakeMKV and libaacs softlinks to libmmbd. Thankfully Arch's AUR makes this way simpler than building manually.
paru -S makemkv makemkv-libaacs
Now we should have native MakeMKV. Launch the app and make sure your drive is still being detected, and try popping in a bluray and loading it in MakeMKV to make sure it can decrypt it.
Next open VLC, go to Tools-> Preferences-> Show Settings - All-> Input/Codecs-> Access Modules-> Blu-ray and make sure you select your desired Bluray Menu Region. Save, and then press CTRL+D to open the Disc menu, select Blu-ray, uncheck No Disc Menus, and press Play. Hopefully your disc loads and you get functional Blu-ray menus.
For Kodi, open it up and you'll see a Disc option appear, ignore it(doesn't seem to work for some reason). Go up to the Settings gear button instead, then open the "File manager". If you have a disc inserted, you should see it listed. Click on it, then navigate to the BDMV folder and select the "index.bdmv" file. After a slightly lengthy wait, you should get a popup asking what you want to play, for now we're gonna pick "Show Blu-ray menu" in order to make sure everything is working. After loading for another slightly lengthy wait, you should see the disc start to play and eventually get presented the disc menu. Just use arrow keys and enter to navigate, as mouse is funky in Kodi.
And there you have it. Hopefully these steps are enough to get you a functioning Blu-ray setup on your CachyOS or other Arch based distro. Let me know if you have any questions and hopefully I can answer them.
Diznix
Re: Rough Guide: v1.18.1 on CachyOS(Arch Linux)
#2 Post by Diznix » Thu Nov 27, 2025 7:23 pm
Thank you jayandp. I recently switched from Mint to RebornOS (arch) and started to get a bit worried I wouldn't be able to run MakeMKV, then I found your post. As I already had MakeMKV 1.18.2 loaded, I only had to load the packages you listed and run the config on java and it's working fine. Thanks again.
Diznix
Dis93
#3 Post by Dis93 » Sat Dec 13, 2025 11:23 am
Thanks jayandp, my BD wasn't being detected, the modprobe fixed it :D
jayandp
#4 Post by jayandp » Sat Dec 13, 2025 8:14 pm
Diznix wrote: Thu Nov 27, 2025 7:23 pm Thank you jayandp. I recently switched from Mint to RebornOS (arch) and started to get a bit worried I wouldn't be able to run MakeMKV, then I found your post. As I already had MakeMKV 1.18.2 loaded, I only had to load the packages you listed and run the config on java and it's working fine. Thanks again.
Diznix
Yeah the Java part is a bit unintuitive since you need older versions instead of newer ones.
Dis93 wrote: Sat Dec 13, 2025 11:23 am Thanks jayandp, my BD wasn't being detected, the modprobe fixed it :D
Good to know that was important. Seems some BD drives just don't get detected automatically.
Nizrael
#5 Post by Nizrael » Fri Dec 26, 2025 11:39 pm
Thank you so very much! Confirming that following your steps to the letter works perfectly in Arch Linux 6.18.2 as of 26 December 2025.
jayandp
#6 Post by jayandp » Fri Dec 26, 2025 11:44 pm
Nizrael wrote: Fri Dec 26, 2025 11:39 pm Thank you so very much! Confirming that following your steps to the letter works perfectly in Arch Linux 6.18.2 as of 26 December 2025.
Good to know. Have fun ripping!
stevefox1620
#7 Post by stevefox1620 » Mon Jan 12, 2026 6:39 pm
This is a great guide to get things working, Thanks. However, after the new years 2026. The java situation has caused an issue with Cachyos with kernel updates. Bad news is, if you update currently after following this guide your system will not boot after any kernel updates. Luckily you can fallback to LTS to get in and fix it. It was not an easy fix mind you. You need to remove the old Java 8 if you installed it from this guide. Then you need to set the ENV variable to current. Which was 25 right now. Then you need to remove orphaned packages from the system. Once it asks to remove the java jre version 8 you are in business. Run the commands to check with Java's are installed and default. Once every bit of Java 8 is removed you can then run *reinstall all packages* if you see an error about java 8 and lowest version being 17 you missed something and need to back back remove all of java 8 again, and remove orphan packages. Once reinstall all packages from cachyos hello under apps/tweaks gives no java errors. You should be able to reboot normally with latest kernel again.
TLDR 2026: Follow this guide for Cachyt OS but ignore anything with flatpak and JAVA!!!
jayandp
#8 Post by jayandp » Wed Jan 28, 2026 2:23 am
stevefox1620 wrote: Mon Jan 12, 2026 6:39 pm This is a great guide to get things working, Thanks. However, after the new years 2026. The java situation has caused an issue with Cachyos with kernel updates. Bad news is, if you update currently after following this guide your system will not boot after any kernel updates. Luckily you can fallback to LTS to get in and fix it. It was not an easy fix mind you. You need to remove the old Java 8 if you installed it from this guide. Then you need to set the ENV variable to current. Which was 25 right now. Then you need to remove orphaned packages from the system. Once it asks to remove the java jre version 8 you are in business. Run the commands to check with Java's are installed and default. Once every bit of Java 8 is removed you can then run *reinstall all packages* if you see an error about java 8 and lowest version being 17 you missed something and need to back back remove all of java 8 again, and remove orphan packages. Once reinstall all packages from cachyos hello under apps/tweaks gives no java errors. You should be able to reboot normally with latest kernel again.
Sorry for the late reply. Life's been busy this month.
As for CachyOS update and Java8, I just updated my CachyOS for the first time this year and didn't encounter this issue. It's possible whatever bug that caused your issue has already been corrected though.
However, I will note that while I haven't uninstalled Java8, I have actually changed my default JDK to Java17 instead. This version of Java is the latest version I've managed to get working with BD Menus, and it causes less compatibility issues with other software so far. I'll probably update the guide to note this.
science-nerd
#9 Post by science-nerd » Thu Feb 05, 2026 6:51 am
If you guys have dependency problems I suggest getting the chaotic-aur repos installed to get the pre-compiled binary.
Plus, if you want to flash your drive, I whipped up my findings viewtopic.php?f=3&t=40977, because the downgrade to v1.17.7 was complete dependency hell for the needed, outdated libraries.
