Re: SDFtool Flasher
clichekhfan wrote: Sat Nov 08, 2025 8:32 am Hey Marty, I flashed my BU4ON to MK1.03 and it still works but when I insert a UHD disk the drive icon in makemkv just never stops spinning. I also tried flashing the BU4ON 1.00 and the buffalo BU firmware and I get the same result. do you have any advice? I tried it with two different UHD disks but that is all I have at the moment. One is a retail movie, and the other is the same movie decrypted on a verbatim BDXL M-disc.
1. Clean the discs.
2. Always let the os initialise the disc first, then open MakeMKV.
3.ensure MakeMKV has internet access so it can download the hashed keys database and updates as required.
BDbackerupper
Re: SDFtool Flasher
Post by BDbackerupper »
Just flashed my BP50NB40 to the BU40N 1.00 firmware, using the SDF GUI tool in Win11 with instructions provided previously. Ezpz.
Problem is, MakeMKV now reports "The program can't find any usable optical drives."
WTF?
after a power cycle, all seems to be well again. That was odd though.
It's now a full LibreDrive, yay!
rubaducky
Re: SDFtool Flasher
Post by rubaducky »
Not able to download the latest SDFtool Flasher. Looks like the links are broken on the first page.
Planning to flash my drive tonight and purchase MakeMKV! Thanks much!
Re: SDFtool Flasher
rubaducky wrote: Mon Nov 24, 2025 5:11 pm Not able to download the latest SDFtool Flasher. Looks like the links are broken on the first page.
Links are fine. It's something on your end.
Re: SDFtool Flasher
I was able to download SDFtool Flasher just now.
Rogim807
Re: SDFtool Flasher
Post by Rogim807 »
Hey Marty!
I've got a Verbatim 43888 That shows up as a Pioneer BRD-UD04. It hasn't been able to read any of the UHD disks that i've try to rip using it thus far. When I use the SDFtool Flasher to flash it to the BU40N_1.03_MK (22 Nov 2025) it gives me the "the drive you have selected does not have the correct drive platform (MT1959) and cannot be flashed" error. Not sure what to do!
Manufacturer: PIONEER
Product: BD-RW BDR-UD04
Revision: 1.14
Serial number:
Firmware date: 2020-06-15
Highest AACS version: 82
Drive platform: RS8A10
Firmware version: 1.14
Re: SDFtool Flasher
Rogim807 wrote: Wed Nov 26, 2025 11:09 pm Hey Marty!
Revision: 1.14
Serial number:
Your drive is a Pioneer!! It is already UHD ready. There's no flashing it.
If it won't read UHD discs you have another issue.
1. Clean the discs
2. Always ensure you insert the disc and let the OS initialise it before opening MakeMKV.
3. Ensure the drive is getting enough consistent power. Use a USB-C port if possible, direct from the motherboard or USB 3+ ports direct from the motherboard, otherwise use an AC self-powered USB hub of at least 30w. Do not use case ports.
4. Ensure MakeMKV has internet access as it needs to be able to download the UHD hashed keys.
Try pasting MakeMKV's log window text when you attempt to rip a UHD disc.
Rogim807
Re: SDFtool Flasher
Post by Rogim807 »
MartyMcNuts wrote: Thu Nov 27, 2025 1:12 am
Revision: 1.14
Serial number:
1. Clean the discs
Hokay!
1- done!
2- done!
3- plugged into motherboard USB 3.0
4- I think i'm not getting the update
MakeMKV v1.18.2 win(x64-release) started
Downloading latest SDF to D:/Video ...
Automatic SDF downloading is disabled or failed.
Using LibreDrive mode (v01.0 id=489CDFD6D392)
Downloading latest HK to D:/Video ...
Saved AACS dump file as D:/Video/MKB20_v76_Space_Jam-_A_New_Legacy_D785.tgz
Re: SDFtool Flasher
Rogim807 wrote: Thu Nov 27, 2025 1:40 am
Revision: 1.14
Serial number:
1. Clean the discs
Hokay!
1- done!
2- done!
This is your issue
Ensure that the checkbox to enable internet access is checked in MakeMKV preferences.
Something on your PC is geoblocking Russia (which is where the hashed keys are hosted). You might have to change your DNS servers and/or run MakeMKV through a VPN.
Rogim807
Re: SDFtool Flasher
Post by Rogim807 »
MartyMcNuts wrote: Thu Nov 27, 2025 2:56 am
This is your issue
Found the issue! I had region blocking enabled for a multitude of regions in my Unifi Dream Machine, I turned it off just to test and it worked! Thank you for the help :)
McMurphy66
Re: SDFtool Flasher
Post by McMurphy66 »
Apologies if this is in the wrong thread…newbie post but not new to the amazing makemkv software.
Bought the Buffalo BRUHD-PU3-BK. Read through the threads and wasn’t sure if it was BUN-40 flash process. I’m confused what to use, not done this before.
Thanks all.
OS device name: E:
Manufacturer: BUFFALO
Product: Optical Drive
Revision: BN14
Serial number:
Firmware date: 2121-06-21 13:33
Bus encryption flags: 1F
Highest AACS version: 48
Re: SDFtool Flasher
McMurphy66 wrote: Wed Dec 03, 2025 4:19 am Apologies if this is in the wrong thread…newbie post but not new to the amazing makemkv software.
Thanks all.
OS device name: E:
Revision: BN14
Serial number:
Yes, it's a BU40N. You can flash it to BU40N 1.03-MK.
McMurphy66
Re: SDFtool Flasher
MartyMcNuts wrote: Wed Dec 03, 2025 7:10 am [quote=McMurphy66 post_id=189135 time=<a href="tel:1764735582">1764735582</a> user_id=104006]
Thanks all.
OS device name: E:
Revision: BN14
Serial number:
[/quote]
Thank you Marty, I really appreciate your reply.
I’ll use the LG BU40N 1.03mk. Is it simply ‘select drive’ “select write’ open this firmware from the pack and start?
sukaimakyuri
Re: SDFtool Flasher
Post by sukaimakyuri »
Hi, my newly purchased a Verbatim Slimline drive currently cant rip certain DVDs and 4k Blurrays. A few do work, but I mostly use this specifc drives for 4k Blurrays and none of them worked.
Now, first of all, I could not find out if this drive is encrypted, and neither certain if the flashing shown here will work to enable LibreDrive. I downloaded the "All you need firmware pack" and the SDF Tool flasher already. Within the Firmware pack is a LG Slim BU40N, I assume that is the firmware required for this specifc drive. Am I missing something or coud I get started flashing using the flasher with the LG Slim Bu40N Firmware to enable LibreDrive?
Furthermore, from the list of encryped firmware I am uncertain if this drive is in fact coming with an encrypted firmware because I could not find the exact same one in the list but similar enough.
Product: BD-RE BU40N
Revision: 1.05
Serial number: MO4P33E2415
Excuse me for the silly questions. I would prefer not to instantly brick my newly purchased drive, given I already own an other drive which is not for 4k Blurrays and just the normal resolution.
Re: SDFtool Flasher
sukaimakyuri wrote: Wed Dec 03, 2025 1:41 pm Hi, my newly purchased a Verbatim Slimline drive currently cant rip certain DVDs and 4k Blurrays. A few do work, but I mostly use this specifc drives for 4k Blurrays and none of them worked.
Revision: 1.05
As the drive is manufactured in 2024 the firmware is encrypted. SDFTool flasher will set this oprion automatically and you should flash BU40N 1.03 as recommended firmware. If you are using other ripping software besides Makemkv you should flash 1.00. The files are in the "all you need firmware pack" in the SDFTool post by Marty.
viewtopic.php?f=16&t=22896&hilit=sdftool
