New version of AACS security.
MKB_v82_SHOGUNS_SAMURAI_5672.tgz
AACS tgz File: SHOGUNS_SAMURAI
- MKB_v82_SHOGUNS_SAMURAI_5672.tgz
- (119.55 KiB) Downloaded 72 times
Re: AACS tgz File: SHOGUNS_SAMURAI
At the moment, MakeMKV does not natively support AACS v82 blu-rays. You should email those dumps to svq@makemkv.com so a key can be created for MakeMKV's built in hashed key mechanism. A few days after emailing the dump, try the disc again and if a key is available, MakeMKV will download it automatically in the background.
There is a separate second decryption mechanism that MakeMKV supports, the public KeyDB. To contribute to the public KeyDB, use the template and follow the instructions in the first post in the Public KeyDB Disc Submissions thread.
