LibreDrive for Pioneer drives
BrantleyF
#1756 Post by BrantleyF » Wed Nov 26, 2025 8:35 am
Hi @coopervid,
Thank you very much for the PM!
Before I upgraded the firmware I looked into MakeMKV again an realised that the status actually says "Enabled", just like in my initial message that I posted in the form. I must have missed that because I'm 100% sure it stated "Possible, not yet enabled", the first time I started MakeMKV.
Between both outputs changing I have only started SDFtool Flascher (v1.3.6) but didn't flash anything.
So, my question is, do I need to flash my drive with the fw you provided (S8F01430.100 & S8F01431.102) or is that not necessary.
Coopervid wrote: Tue Nov 25, 2025 3:59 pm
BrantleyF wrote: Tue Nov 25, 2025 2:56 pm Hi,
Please assist with the upgrade of Pioneer drive to read UHD.
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: DIDL1*******
Firmware date: 2020-07-21
Drive platform: RS8F00
Firmware version: E113/ID76
With thanks in advance
Brantley
PM sent.
#1757 Post by Coopervid » Wed Nov 26, 2025 1:59 pm
BrantleyF wrote: Wed Nov 26, 2025 8:35 am Hi @coopervid,
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Brantley
PM sent.
Libredrive enabled doesn't equal UHD capability. If you want to read UHDs you MUST flash the drive with the package you have now.
BrantleyF
#1758 Post by BrantleyF » Wed Nov 26, 2025 2:40 pm
Thank you very much for the clarification!
diggs94
#1759 Post by diggs94 » Wed Nov 26, 2025 7:24 pm
Thanks for helping so many people out!
I purchased a Pioneer BDR-209 drive. Can you provide assistance to enable it to read UHD discs?
It is on a Windows 11 machine
Here is the information in MakeMKV without a disc inserted:
OS device name: F:
Manufacturer: PIONEER
Product: BD-RW BDR-209M
Revision: 1.33
Serial number: PADL046070WL
Firmware date: 2015-12-09
Highest AACS version: 63
Drive platform: RS8600
Firmware version: 1.33
Apollo821
#1760 Post by Apollo821 » Wed Nov 26, 2025 7:41 pm
MartyMcNuts wrote: Wed Nov 26, 2025 4:18 am
Apollo821 wrote: Wed Nov 26, 2025 1:52 am Hello, friends!
I've got an XD08...is this flashable or otherwise upgradeable to rip UHDs? I'm a little lost.
Product: BD-RW BDR-XD08
Revision: 1.02
Serial number:
Firmware date: 2022-12-27
Highest AACS version: 60
Drive platform: RS9330
Firmware name: PIONEER BDR-BDS8
Firmware version: 1.02
No. The firmware is post 11/2022 and cannot be cross-flashed at this stage. You will have to wait for possible future cross-flash support.
Thanks so much for the clarification!
#1761 Post by Coopervid » Wed Nov 26, 2025 9:25 pm
diggs94 wrote: Wed Nov 26, 2025 7:24 pm Thanks for helping so many people out!
OS device name: F:
Revision: 1.33
PM sent.
BrantleyF
#1762 Post by BrantleyF » Fri Nov 28, 2025 10:41 am
Once again, thank you!
With the files provided I was able to change the firmware and make my drive UHD ready :D
Product: BD-RW BDR-S12U
Revision: 1.02
Firmware date: 2022-03-07
Highest AACS version: 77
Drive platform: RS8F01
Firmware version: 1.02/ID43
Coopervid wrote: Wed Nov 26, 2025 1:59 pm
PM sent.
#1763 Post by Coopervid » Fri Nov 28, 2025 10:43 am
OS device name: F:
Revision: 1.33
PM sent.
aaditya
#1764 Post by aaditya » Fri Nov 28, 2025 10:18 pm
To: Coopervid
I also have a Pioneer BDR-212T and am looking for the appropriate LibreDrive firmware.
OS device name: /dev/sr0
Product: BD-RW BDR-212D
Revision: 1.02
Serial number: DG**
Firmware date: 2022-03-16
Bus encryption flags: 13
Highest AACS version: 82
Firmware version: 1.02/ID61
Could I ask you to send me the appropriate information please?
#1765 Post by Coopervid » Fri Nov 28, 2025 11:10 pm
aaditya wrote: Fri Nov 28, 2025 10:18 pm To: Coopervid
Revision: 1.02
Serial number: DG**
PM sent.
aaditya
#1766 Post by aaditya » Sat Nov 29, 2025 1:38 am
Cheers mate!
royale011
#1767 Post by royale011 » Sat Nov 29, 2025 3:34 am
Hello there, I have XS08MB-S. Is there any chance to get LibreDrive firmware w/ UHD supported?
Product: BD-RW BDR-XS08U
Revision: 1.03
Serial number: BJDL000979JP
Firmware date: 2024-10-09
Highest AACS version: 76
Drive platform: RS9621
Firmware version: 1.03/ID69
#1768 Post by MartyMcNuts » Sat Nov 29, 2025 5:12 am
royale011 wrote: Sat Nov 29, 2025 3:34 am Hello there, I have XS08MB-S. Is there any chance to get LibreDrive firmware w/ UHD supported?
Revision: 1.03
This a UHD drive. It's already libredrive enabled and is ready to rip UHD discs. Pop in a UHD disc and start ripping it!
foxale08
#1769 Post by foxale08 » Sat Nov 29, 2025 10:26 am
Update 2: the drive physically says "BDR-UD04TBD" on the outside. (I'm adding this information so it may benefit others.)
Update: I figured it out. I needed an SDF update (manually downloaded sdf.bin, placed it in %UserProfile%\.MakeMKV
and fully shut down then turned the computer back on.) Not sure why MakeMKV didn't download the newest SDF file, it's a new install.
Drive platform: RS8A10
Firmware version: 1.20/ID84
SDF  v0a3: PIONEER_BD-RW__BDR-UD04D_1.20_XXXXXXXXXXXX
DEBUG: Code 3 at R/Ru3B(Mxaw 4&z'5FC}$>4::29395310
Hello, I have a BDR-UD04D from Japan which is mounted in a desktop PC (power shouldn't be an issue) the drive appears to be able to read normal Blu-ray disks fine but I get a crap ton of errors (and eventual failure to open disk, example error below) while attempting to read UHDs.
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..0BF to device 'SPTI:\Device\CdRom0'
DEBUG: Code 0 at -J6231Kpvy%-_GfBo:213130766
From MakeMKV 1.18.2
OS device name: G:
Product: BD-RW BDR-UD04D
Revision: 1.20
Serial number: XXXXXXXXXXXX
Firmware date: 2017-09-26
Drive platform: Pioneer RS8A10
Firmware version: ID84
Relevant logs show the following:
001003:0020 DEBUG: Code 0 at 3}LEXDFfdV,&S#:f:121276424
No  SDF v097: PIONEER_BD-RW__BDR-UD04D_1.20_XXXXXXXXXXXX
DEBUG: Code 0 at ^\4O;l[]cZAB>C:7o:29396253
DEBUG: Code 0 at lS]g`,`;]*O'8w*t:213136746
SDF id v097: PIONEER_BD-RW__BDR-UD04D_1.20_XXXXXXXXXXXX
I am doing something wrong here?
Webraider72
#1770 Post by Webraider72 » Sun Nov 30, 2025 1:50 am
Good evening,
Here are the credentials of my drive. This Is the first time it has shown status Enabled for LibreDrive since I owned it and it was one of the dreadful firmware 1.03 which wasn't supported initially. As this is a UHD "capable" drive, Do I still need to flash it to rip UHD? I have a Mac by the way, and don't have access to windows. Thank you in advance!
Product: BD-RW BDR-XS07U
Revision: 1.03
Serial number: CEDL012202UC
Firmware date: 2023-01-06
Drive platform: RS8E21
Firmware version: 1.03/ID05
