0 out of 30 day trial after install of 1.7.2?
ottawaxblade
Post by ottawaxblade »
I was recently running version 1.7.1 with over 20 something days left of my trial and decided to upgrade to 1.7.2.
After installing it and trying to use the new version, I'm being told that there are 0 out of 30 days left from my trial.
It's still allowing me to make MKVs (actually just in the middle of trying one right now). Not sure if it will complete or not but thought to post here anyways in the meantime.
Is there a beta key that is supposed to be issued for this latest version?
Smithcraft
Re: 0 out of 30 day trial after install of 1.7.2?
Post by Smithcraft »
Current beta key is only valid for a few more days, but -
http://www.makemkv.com/forum2/viewtopic.php?f=5&t=1053
SC
ottawaxblade
Smithcraft wrote:Current beta key is only valid for a few more days, but -
SC
@Smithcraft, thanks for the link and your help :)
NotMike
Post by NotMike »
Did this error happen on 64-bit Windows?
Directory of C:\Program Files (x86)\MakeMKV
02/09/2012 03:26 AM 137,216 libmakemkv.dll
12/23/2011 01:06 AM 259,072 libmakemkv64.dll
Note that libmakemkv64.dll is older. It's the one from 1.7.0. It looks like the developers either forgot to re-build it when they created the 1.7.2 installer or haven't included it in the installer.
If you run MakeMKV 1.7.2 on 32-bit Windows it starts OK without entering a key. Likewise, you can use the 32-bit command-line program (makemkvcon.exe) on 64-bit Windows, but makemkvcon64.exe complains that it's too old. With the beta key, when you launch MakeMKV 1.7.2 on 64-bit Windows it says "MakeMKV v1.7.0 win(x64-release) started" and "The new version 1.7.2 is available for download at http://www.makemkv.com/download".
