Pioneer BDR-UD03 UHD possibility
haase79
Re: Pioneer BDR-UD03 UHD possibility
Just got myself this drive, any help to get uhd's working is greatly appreciated:
Laufwerksinformation
OS-Gerätename: D:
Aktuelles Profil: DVD-ROM
Produzent: ASUS
Produkt: SBW-06D5H-U
Revision: E102
Serienummer: CLDL284177WL
Firmware-Datum: 2023-04-20
Highest AACS version: 35
Drive platform: RS8511
Firmware version: E102/ID26
Thanks a lot
Christian
OS-Gerätename: D:
Produzent: ASUS
Revision: E102
Thanks a lot
Christian
PM is coming.haase79 wrote: Mon Nov 17, 2025 3:05 pm Hello,
OS-Gerätename: D:
Produzent: ASUS
Revision: E102
Thanks a lot
Christian
idelhands
Hi, I also am having a problem with uhd's and would greatly appreciate if you could help me out
Drive Information Manufacturer:
PIONEER Product: BD-RW BDR-UD03 Revision: 1.14
Serial number: *********
Firmware date: 2020-06-15
Highest AACS version: 82
Libre Drive Information Status: Enabled
Firmware version: 1.14
PM sent.idelhands wrote: Tue Nov 18, 2025 12:56 am Hi, I also am having a problem with uhd's and would greatly appreciate if you could help me out
nj_kman
I am also having difficulty with my drive. Does anyone know how I can fix the issue if my drive setup is this?
OS device name: H:
Product: BD-RE BU40N
Revision: 1.05
Serial number: MOEP6O90109
Highest AACS version: 61
OS device name: H:
Revision: 1.05
1st post of The Guide recommends:nj_kman wrote: Tue Nov 18, 2025 5:13 pm Hello,
OS device name: H:
Revision: 1.05
BU40N on any Firmware directly to > BU40N 1.03MK (HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin)
As you are running Windows, use the SDFtool Flasher.
redKernel83
Just got a Verbatim 43890 from the store and tried it tonight for DVD/BD.
Has the Pioneer BDR-UD03 in it surprisingly, so it must've been sitting there for some time.
Based on the box I think it's from 23JULY.
Can I get the firmware file to flash as UD04 for UHD support?
Here's the output from MakeMKV:
Manufacturer: PIONEER
Revision: 1.14
Serial number: DDDL526623WL
Much appreciated, thanks!
Revision: 1.14
PM sent.redKernel83 wrote: Wed Nov 19, 2025 3:43 am Just got a Verbatim 43890 from the store and tried it tonight for DVD/BD.
Revision: 1.14
kiosk
Just got the Verbatim 4390 from the store, wondering if I could get the firmware file to flash as UD04?
- Drive Information
Revision: 1.14
Serial number: CIDL503002WL
PM sent.kiosk wrote: Wed Nov 19, 2025 10:59 pm Just got the Verbatim 4390 from the store, wondering if I could get the firmware file to flash as UD04?
Thank you in advance!
- Drive Information
Revision: 1.14
DarkDriverHD
Hi Everyone,
does someone have the Firmware to enable UHD on this drive?
OS-Gerätename: D:
Aktuelles Profil: BD-ROM
Produzent: PIONEER
Produkt: BD-RW BDR-UD03
Revision: 1.11
Serienummer: TCDL296988WL
Firmware-Datum: 2018-11-28
Highest AACS version: 37
Firmware version: 1.11
Thanks in Advance!!
OS-Gerätename: D:
Produzent: PIONEER
Revision: 1.11
Thanks in Advance!!
PM sent.DarkDriverHD wrote: Fri Nov 21, 2025 2:21 pm Hi Everyone,
OS-Gerätename: D:
Produzent: PIONEER
Revision: 1.11
Thanks in Advance!!
Perto17
Hello! I'm also looking for the firmware of this drive:
Revision: 1.10
Serial number:
Firmware date: 2017-04-18
Firmware version: 1.10
THANK YOU!
Revision: 1.10
Serial number:
THANK YOU!
PM sent.Perto17 wrote: Mon Nov 24, 2025 1:03 pm Hello! I'm also looking for the firmware of this drive:
Revision: 1.10
Serial number:
THANK YOU!
bwcgrx
Grabbed a Verbatim 43890 at scored a Pioneer BDR-UD03 within.
I'd really like to get this cross flashed in order to rip 4k UHD. Any help would be greatly appreciated.
OS device name: G:
Revision: 1.14
Serial number:
OS device name: G:
Revision: 1.14
Serial number:
