PM sent.bjohnson wrote: ↑Sun Nov 23, 2025 4:02 pmDrive Information
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E102
Serial number: _
Firmware date: 2017-01-15
Highest AACS version: 16
Drive platform: RS8600
Firmware version: E102/ID76
I have the above drive, is there a way to get this to support UHD?
Any assistance is greatly appreciated.
Asus BW-16D1X-U
Re: Asus BW-16D1X-U
theforkster
Re: Asus BW-16D1X-U
Thanks Coopervid! It worked and all is well!
Re: Asus BW-16D1X-U
Thanks so much, worked like a charm.Coopervid wrote: ↑Sun Nov 23, 2025 6:56 pmPM sent.bjohnson wrote: ↑Sun Nov 23, 2025 4:02 pmDrive Information
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E102
Serial number: _
rbadger332
Re: Asus BW-16D1X-U
Like many others I bought one of these drives recently as well. Can I get assistance making this drive UHD/4K friendly please?
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: XXXXXXX017WL
Firmware date: 2020-07-21
Highest AACS version: 57
Drive platform: RS8F00
Firmware version: E113/ID76
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Re: Asus BW-16D1X-U
PM sent.rbadger332 wrote: ↑Tue Nov 25, 2025 2:09 amLike many others I bought one of these drives recently as well. Can I get assistance making this drive UHD/4K friendly please?
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Re: Asus BW-16D1X-U
Im just about to order one of these from Amazon - advertised as Asus BW-16D1X-U
Am I doing the right thing?
Guessing everyones managed to flash with Libre drive firmware from MartyMcNuts pack.
Thank you
Thank you
Re: Asus BW-16D1X-U
Some of these contain LG drives, others Pioneer drives. It's just luck of the draw if you get a Pioneer drive inside! If it's a LG, yes, you can flash it yourself with the available tools. If it's a Pioneer you will need the non-public tool and firmware.
rbadger332
Re: Asus BW-16D1X-U
Worked great! Thanks!Coopervid wrote: ↑Tue Nov 25, 2025 10:41 amPM sent.rbadger332 wrote: ↑Tue Nov 25, 2025 2:09 amLike many others I bought one of these drives recently as well. Can I get assistance making this drive UHD/4K friendly please?
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Re: Asus BW-16D1X-U
I was starting to use my drive to rip and realized I might be able to use UHD as well. Can you help? Thank you in advance! Below is my drive info:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E101
Serial number:
Firmware date: 2015-10-20
Firmware version: E101/ID76
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E101
Serial number:
Re: Asus BW-16D1X-U
Seems i wasn't lucky in the BW-16D1X-U draw and got a pioneer drive and will need the proprietary drivers...
Any help would be greatly appreciated. thanks.
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: ---------4WL
Firmware version: ID76
Re: Asus BW-16D1X-U
I think you mean you were lucky!!knawrocke wrote: ↑Wed Nov 26, 2025 3:43 amSeems i wasn't lucky in the BW-16D1X-U draw and got a pioneer drive and will need the proprietary drivers...
Any help would be greatly appreciated. thanks.Code: Select all
Drive Information OS device name: D: Manufacturer: ASUS Product: BW-16D1X-U Revision: E113 Serial number: ---------4WL Firmware date: 2020-07-21 Bus encryption flags: 1B LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS8F00 Firmware version: ID76
Re: Asus BW-16D1X-U
Whoops. You are right. I just saw Pioneer and "freaked out"... Thanks for the responseMartyMcNuts wrote: ↑Wed Nov 26, 2025 4:16 amI think you mean you were lucky!!knawrocke wrote: ↑Wed Nov 26, 2025 3:43 amSeems i wasn't lucky in the BW-16D1X-U draw and got a pioneer drive and will need the proprietary drivers...
Re: Asus BW-16D1X-U
PM sent.bigkenw wrote: ↑Wed Nov 26, 2025 2:37 amI was starting to use my drive to rip and realized I might be able to use UHD as well. Can you help? Thank you in advance! Below is my drive info:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E101
Serial number:
Re: Asus BW-16D1X-U
Check your PM. It has information how to enable UHD capabilty for this drive.knawrocke wrote: ↑Thu Nov 27, 2025 12:45 amWhoops. You are right. I just saw Pioneer and "freaked out"... Thanks for the responseMartyMcNuts wrote: ↑Wed Nov 26, 2025 4:16 amI think you mean you were lucky!!knawrocke wrote: ↑Wed Nov 26, 2025 3:43 amSeems i wasn't lucky in the BW-16D1X-U draw and got a pioneer drive and will need the proprietary drivers...
Re: Asus BW-16D1X-U
Just taken delivery of this one
Think it's Pioneer? Just need Libredrive now
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number: DGDL....22WL
Highest AACS version: 82
Firmware version: E116/ID71
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
