Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' when reading 4K UHD BluRay
bryanvh
Post by bryanvh » Tue Nov 25, 2025 10:10 pm
Hi everyone. I've found other threads about errors like this but they're generally old and lacking answers and I didn't want to necro one of those.
I'm getting these errors all of a sudden when trying to rip a UHD Blu Ray. The Blu Ray drive has been acting fine ripping other Blu Rays, even UDH ones (LibreDrive firmware properly installed and UHD support enabled and working). So, this almost suggests it's a disk specific issue. But, the weird part is that it's just one disk in a box set of LoTR so I can't imagine why the others are reading fine and this one isn't.
and
Error 'OS error - The specified request is not a valid operation for the target device'
I'll attach the log from the rip. But, I'm sort of at a loss. Is there anything to try or anything that stands out as a culprit based on the logs? Thanks in advance and sorry if this is just basically chasing gremlins.
(Windows (sadly), MakeMKV running as admin,UHD reads working, other disks working)
LoTR 3 Read error.txt
Re: Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' when reading 4K UHD BluRay
Post by MartyMcNuts » Tue Nov 25, 2025 10:49 pm
bryanvh wrote: Tue Nov 25, 2025 10:10 pm Hi everyone. I've found other threads about errors like this but they're generally old and lacking answers and I didn't want to necro one of those.
and
Start by cleaning the disc, even if new.
bryanvh
Post by bryanvh » Mon Dec 01, 2025 4:28 pm
Thanks! I wouldn't have through that new disks would have needed it. I cleaned it and the error moved from ~4 million position to ~8 million position, but it still failed. Played with it a lot more, including a few more cleanings, but this thing was determined to fail no matter what.
Guess it was just a bad burn on the manufacturing side. Woo for statistical possibilities. Haha
Post by Woodstock » Mon Dec 01, 2025 8:16 pm
"New disks" is relative. I've found it more frequent that disks that were released 6 months ago have acquired a film from their packaging that prevents "error free" reading, and it needs to be cleaned off.
rjnichols
Post by rjnichols » Fri Dec 12, 2025 6:56 pm
Started seeing this a lot on my older 4K disks that ripped fine when they were new but second time around a few months later they fail. No visible surface errors. All the failed disks play perfectly on my standalone Panasonic UB9000 so I guess this player has some sort of error correction or just skips failed sectors.
Wonder if makemkv could implement an option to skip unreadable bits and carry on like standalone players must be doing.
Log file attached.
1wayjonny
Post by 1wayjonny » Wed Dec 24, 2025 10:16 pm
The black cases produces a weird film that causes so many headaches. You can see the film when you open 95% of the black UHD cases.
Releases such as arrow, collectors, etc have clear or a different black material never an issue. The bad cases you can smear the oil looking smuge with your finger. Why they use them is beyond me.
Clean multiple times...
mmmkv
Post by mmmkv » Thu Dec 25, 2025 10:29 am
1wayjonny wrote: Wed Dec 24, 2025 10:16 pm The black cases produces a weird film that causes so many headaches. You can see the film when you open 95% of the black UHD cases.
Does anyone have photos of 'good' black cases vs bad ones? Since almost without exception my collection came in black cases (it's kind of the trademark color for UHD BD).
This is very concerning for preservation/integrity.
Edit: apparently it's from polypropylene plastic off-gassing. Some place them in acid-free sleeves to avoid this.
