Public KeyDB Disc Submissions
chucky527c
#1066 Post by chucky527c » Tue Nov 25, 2025 5:23 pm
Eyes Wide Shut UHD
Disc type: UHD
Disc dump filename: MKB20_v82_EYES_WIDE_SHUT_83A3.tgz
Drive: BD-RE WH16NS60
Drive firmware: 1.03
LibreDrive status: Enabled
Disc dump link: https://drive.google.com/file/d/19Yj4ip ... p=drivesdk
cjw73
#1067 Post by cjw73 » Tue Nov 25, 2025 5:33 pm
Central Station
Disc type: UHD
Disc dump filename: MKB20_v82_CENTRAL_STATION_5F9C.tgz
Drive: ASUS BW-16D1HT
Drive firmware: 3.10
Did you sync the public keydb within the last 15 minutes? yes
Have you verified that all submission links are accessible in incognito/private browsing?yes
MKB_RO.inf link: dump is 3.23 mb, should be included, unless requirements have changed now ?
Disc dump link: https://drive.proton.me/urls/P28FX4Q2EC#hyq5CL0B5mWY
thanks again
andypinkc
#1068 Post by andypinkc » Tue Nov 25, 2025 8:13 pm
The Long Walk
Disc type: UHD
Disc dump filename: MKB20_v82_The_Long_Walk_21AC.tgz
Drive: BD-RE BU40N (MT1959 Drive Platform)
Drive firmware: 1.0
MKB_RO.inf link: dump is 4.3 mb, should be included
Disc dump link: https://drive.google.com/file/d/1DjEgAo ... share_link
drop9
#1069 Post by drop9 » Tue Nov 25, 2025 10:01 pm
Disc type: Blu-Ray
Disc dump filename: MKB_v82_Gabby's_Dollhouse-_The_Movie_55C4.tgz
Drive: BD-RE BH14NS40
Drive firmware: 1.00
MKB_RO.inf link: https://drive.google.com/file/d/1APXrGa ... share_link
Disc dump link: https://drive.google.com/file/d/1Xa6oIT ... share_link
keydb_helper
#1070 Post by keydb_helper » Tue Nov 25, 2025 10:27 pm
tmtisfree wrote: Tue Nov 25, 2025 11:59 am At time of submission the disc did not Validate after Synchronize in the KeyDB Helper tool, and it still does not today with the same error "12:47:56 - Failed to init disc >AACS UNKNOWN ERROR >-1612<<". Fortunately I also submitted to the MakeMKV team and the disc is now successfully processed.
Sorry for being harsh, I'm also not sure what exactly that FindVUK error means and I appreciate you taking the time to check the status before posting in this thread. But the existing keydb entry is correct and now that you've synced the keydb it seems that MakeMKV is able to use it to decrypt your disc.
Trying to decrypt a disc with the MakeMKV and keydb combo is a good fallback when FindVUK validation fails as there may be a bus encryption issue preventing the validation from working.
aroclab wrote: Tue Nov 25, 2025 2:58 am ...
/EDIT/ Sigh, its a 2.1 Disc with a poison MKB :(
I'm not quite sure what gave you that idea. Your disc uses AACS 1.0, not AACS 2.1, and the MKB version is very workable. Your disc was added to the public keydb yesterday. Grab the latest keydb and you'll be able to backup your disc with MakeMKV.
chucky527c wrote: Tue Nov 25, 2025 5:23 pm Disc dump filename: MKB20_v82_EYES_WIDE_SHUT_83A3.tgz
Hey chucky527c, you were lucky this time as the media key was already known to the keydb but in general you will need to include the MKB_RO.inf file when you have such a small disc dump.
cjw73 wrote: Tue Nov 25, 2025 5:33 pm Disc dump filename: MKB20_v82_CENTRAL_STATION_5F9C.tgz
andypinkc wrote: Tue Nov 25, 2025 8:13 pm Disc dump filename: MKB20_v82_The_Long_Walk_21AC.tgz
You were both correct, these submissions did not require separate MKB_RO.inf file links as they were above 3MB.
All three of these discs have been added to the public keydb:
#1071 Post by SamuriHL » Tue Nov 25, 2025 11:25 pm
Thanks, that was helpful. ;)
MKB_v82_The_Long_Walk_855A
Now also supported.
reverandbob
#1072 Post by reverandbob » Wed Nov 26, 2025 2:28 am
After Glow
Disc type: Blu-ray (AACS 1.0 )
Disc dump filename: MKB_v82_Afterglow_25EE.tgz
Drive: BD-RE WP50NB40
LibreDrive status: N/A
Disc dump link: https://drive.google.com/file/d/1RdP3hc ... drive_link
reverandbob
#1073 Post by reverandbob » Wed Nov 26, 2025 2:36 am
2 discs
Last Exit to Brooklyn (Disc 1)
Disc dump filename: MKB_v82_Last_Exit_to_Brooklyn_Disc_1_1430.tgz
Disc dump link: https://drive.google.com/file/d/1hZ9JPe ... drive_link
Last Exit to Brooklyn (Disc 2)
Disc dump filename: MKB_v82_Last_Exit_to_Brooklyn_Disc_2_96BA.tgz
Disc dump link: https://drive.google.com/file/d/1eJ7OWe ... drive_link
Firefighter3270
#1074 Post by Firefighter3270 » Wed Nov 26, 2025 8:52 am
Good morning everyone,
I'm attaching the AACS output file. I was trying to rip this Blu-ray and I'm getting an error.
I hope it helps you solve the problem.
I also sent this file to MakeMKV via email.
https://drive.google.com/file/d/1VSWHfh ... drive_link
Bildschirmfoto 2025-11-25 um 16.31.20.png (364.96 KiB) Viewed 7172 times
99gagamel
#1075 Post by 99gagamel » Wed Nov 26, 2025 1:37 pm
Disc-Typ: UHD
Disc-Dump-Dateiname: MKB20_v77_FERRIS_BUELLERS_DAY_OFF_B753,tgz
Laufwerk: BH16NS55
Laufwerks-Firmware: 1.05
Haben Sie die öffentliche Schlüsseldatenbank in den letzten 15 Minuten synchronisiert? Ja
Haben Sie überprüft, ob alle Einreichungslinks im Inkognito-/Privatmodus erreichbar sind? Ja
Link zur Datei MKB_RO.inf: https://drive.google.com/file/d/1JUhrDx ... sp=sharing
Link zum Disc-Dump: https://drive.google.com/file/d/1z3KSMG ... sp=sharing
99gagamel
#1076 Post by 99gagamel » Wed Nov 26, 2025 4:56 pm
Disc-Typ: UHD
Disc-Dump-Dateiname: MKB20_v61_A_QUIET_PLACE_FCBF,tgz
Laufwerk: BH16NS55
Link zur Datei MKB_RO.inf: https://drive.google.com/file/d/1BB0n1V ... sp=sharing
Link zum Disc-Dump: https://drive.google.com/file/d/1C1vlWO ... sp=sharing
_______________________________________________________________________________________________________________
Disc-Typ: UHD
Disc-Dump-Dateiname: MKB20_v76_A_QUIET_PLACE_PART_II_A5BD.tgz
Laufwerk: BW-1601HT
Laufwerks-Firmware: 3.01
Link zur Datei MKB_RO.inf: https://drive.google.com/file/d/1q8PRnX ... sp=sharing
Link zum Disc-Dump: https://drive.google.com/file/d/199WXRX ... sp=sharing
Disc-Typ: UHD
Disc-Dump-Dateiname: MKB20_v72_TOP_GUN_E04D.tgz
Laufwerk: BW-1601HT
Link zur Datei MKB_RO.inf: https://drive.google.com/file/d/10bCdmA ... sp=sharing
Link zum Disc-Dump: https://drive.google.com/file/d/1PFyqEv ... sp=sharing
Disc-Typ: UHD
Disc-Dump-Dateiname: MKB20_v76_TOP_GUN_MAVERICK_5D39.tgz
Laufwerk: BW-1601HT
Link zur Datei MKB_RO.inf: https://drive.google.com/file/d/1GrS9MA ... sp=sharing
Link zum Disc-Dump: https://drive.google.com/file/d/18HYXs6 ... sp=sharing
rigormorti@aol.com
#1077 Post by rigormorti@aol.com » Wed Nov 26, 2025 7:24 pm
Here's the AACS Dump File for the Conjuring 4 Last Rights 4k
Traume
#1078 Post by Traume » Wed Nov 26, 2025 7:45 pm
MakeMKV was unable to process this UHD Blu-ray.
It looks like the volume key / hash is not yet in the database.
Disc title: NEW AVENGERS S1 D1 UHD
Region: UHD (region-free)
MakeMKV version: 1.18.2
Drive: HL-DT-ST BD-RE BU40N USB Device
Symptoms:
- Cannot decrypt disc
- Missing key/hash
- Using latest MakeMKV version
The SDF dump (.tgz) generated by MakeMKV is attached.
Thank you for adding support!
reverandbob
#1079 Post by reverandbob » Wed Nov 26, 2025 8:22 pm
Anemone
Disc type: Blu-ray
Disc dump filename: MKB_v82_Anemone_0F04.tgz
Disc dump link: https://drive.google.com/file/d/18U-C5c ... drive_link
psbcyan
#1080 Post by psbcyan » Wed Nov 26, 2025 9:53 pm
I have two submissions, i've tried everything I can to get auto HK key downloads working but nothing seems to work :-(. I've been downloading the sdf file manually and can see it transfers upon reloading the application. I downloaded the public KEYDB.cfg and have that in the Makemkv data folder. Would love any advice to get auto HK downloading working or if i'm doing anything wrong here.
Kind Regards
psbCYan
Expendables 3
Disc type: UHD
Disc dump filename: MKB20_v60_Expendables_3_0913.tgz
Drive firmware: 1.02
Disc dump link: https://drive.google.com/file/d/1W2kfTu ... drive_link
Expendables 4
Disc type: UHD
Disc dump filename: MKB20_v77_The_Expendables_4_6B6B.tgz
Disc dump link: https://drive.google.com/file/d/1-sTMTX ... drive_link
