Longshot with Pioneer BDR-209D
Re: Longshot with Pioneer BDR-209D
movo01 wrote: Sun Nov 23, 2025 12:14 pm Hey, this is my first post in this forum. I recently got a UHD disc and wondered if it is possible to rip it with my BDR-209D? Is it possible to do this from linux? My details:
OS device name: /dev/sr0
Manufacturer: PIONEER
Product: BD-RW BDR-209D
Revision: 1.34
Serial number:
Firmware date: 2016-04-25
Bus encryption flags: 13
Highest AACS version: 62
Drive platform: RS8600
Firmware version: 1.34/ID61
PM sent.
HUMBY
Post by HUMBY »
Coopervid wrote: Sun Nov 23, 2025 10:31 am
HUMBY wrote: Fri Nov 21, 2025 8:40 pm Hi All
If i could just jump on the band wagon here could anyone tell me if my drive is flashable to read UHD disks?
Revision: 1.20
Serial number: NGDL056633WL
Firmware date: 2014-04-08
Highest AACS version: 39
Firmware version: 1.20/ID61
If so would it be possible to send me the software to flash it?
Thanks so much
Nick
PM sent.
That's awesome - can't believe the venerable old drive i rescued from my old computer is actually useful!! I'll sort a donation out ASAP
bionicbuk
Post by bionicbuk »
Hi everyone, great to see this thread is alive and well.
I happen to get my hands on a few BDR209. According to this thread, looks like it can be flashed but will leave that to the experts. Here is the info from makemkv.
One question that would be helpful to know, can I use the same FW flash for other BDR209 drives just with a different S/N?
Revision: 1.51
Serial number: QDDL092349WL
Firmware date: 2018-05-08
Firmware version: 1.51/ID61
bionicbuk wrote: Tue Nov 25, 2025 7:30 pm Hi everyone, great to see this thread is alive and well.
Revision: 1.51
PM sent.
bionicbuk
Post by bionicbuk »
Coopervid wrote: Tue Nov 25, 2025 8:08 pm
Revision: 1.51
PM sent.
Hi sir, got your PM. Maybe because it is a fresh account, I could not reply?
Is it possible to use the same flash for other BDR209 drives just with a different S/N and all other things considered equal? Revision, encryption flags, drive platform, firmware version appear to all be the same.
Thank you.
Edit: my mistake, I assumed they were all the same. Two are 1.20 FW:
Revision: 1.20
Serial number: NHDL060279WL
Yes. As long as it reports RS8600 as drive platform. RS8601 needs a different package.
bionicbuk
Post by bionicbuk »
Coopervid wrote: Tue Nov 25, 2025 8:53 pm Yes. As long as it reports RS8600 as drive platform. RS8601 needs a different package.
Sounds good to me, thanks for confirming and the flash info. Sent a few coffees your way. Enjoy.
Thanks a bunch!
norliss
Post by norliss »
@Coopervid - hey man, I got your PM but haven't been signed up long enough to reply. I downloaded the files and followed the instructions and it all seems to have worked ok. I now have S11 and have ripped my first UHD BD. I've sent you something to buy a coffee.
kmrtjr
Post by kmrtjr »
Sorry for posting but I need help flashing my Pioneer. Thanks
Current profile: DVD-ROM
Revision: 1.20
Serial number:
kmrtjr wrote: Wed Dec 17, 2025 10:50 pm Sorry for posting but I need help flashing my Pioneer. Thanks
Revision: 1.20
Serial number:
PM sent.
SHODAN
Post by SHODAN »
Hi jumping in here too, I also have a Pioneer drive I've received recently in the mail. Want to make it UHD disc compatible, can it be done? It is a BDR-209EBK and was manufactured in June 2014. Here is the MakeMKV information.
OS device name: /dev/sr1
Product: BD-RW BDR-209M
Revision: 1.20
Serial number:
Highest AACS version: 68
Firmware version: 1.20/ID60
Worth pointing out just to avoid wasting anyone's time is that I'm currently unconfident in flashing it over the "USB 3.0 to IDE/SATA" device I have it plugged into to so I will do it in a few months when I do have a new case with internal optical drive support. I'd just like to get everything in order beforehand.
SHODAN wrote: Thu Dec 18, 2025 2:40 pm Hi jumping in here too, I also have a Pioneer drive I've received recently in the mail. Want to make it UHD disc compatible, can it be done? It is a BDR-209EBK and was manufactured in June 2014. Here is the MakeMKV information.
Revision: 1.20
Serial number:
Post again when you are ready to flash.
SHODAN
Post by SHODAN »
Coopervid wrote: Thu Dec 18, 2025 3:37 pm
Revision: 1.20
Serial number:
Thanks, will do.
SHODAN
Post by SHODAN »
SHODAN wrote: Thu Dec 18, 2025 3:48 pm
Revision: 1.20
Serial number:
Thanks, will do.
Just put my PC in a new case and installed via SATA, ready to go.
