PM is coming.Lbrtydrmr wrote: Mon Nov 17, 2025 12:32 am Drive Information
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-209D
Revision: 1.51
Serial number: SGDL054873WL
Firmware date: 2018-05-08
Bus encryption flags: 13
Highest AACS version: 76
Drive platform: RS8601
Firmware version: 1.51/ID61
LibreDrive for Pioneer drives
MicAel1
Thank you for all your efforts! Today I received my Pioneer drive and would also like to cross flash it in order to enable UHD support.
This is the drive information:
Is there a way to flash it from Linux as well? (Otherwise I briefly install Windows.)
Thanks in advance!
OS device name: /dev/sr2
Revision: 1.33
Serial number: OFDL********
Firmware date: 2015-12-09
Highest AACS version: 82
Drive platform: RS8600
Firmware version: 1.33/ID61
Unrestricted read speed: YesThanks in advance!
PM sent.MicAel1 wrote: Tue Nov 18, 2025 5:41 pm Thank you for all your efforts! Today I received my Pioneer drive and would also like to cross flash it in order to enable UHD support.
This is the drive information:Is there a way to flash it from Linux as well? (Otherwise I briefly install Windows.)Code: Select all
Drive Information OS device name: /dev/sr2 Current profile: BD-ROM Manufacturer: PIONEER Product: BD-RW BDR-209D Revision: 1.33 Serial number: OFDL******** Firmware date: 2015-12-09 Bus encryption flags: 13 Highest AACS version: 82 LibreDrive Information Status: Enabled Drive platform: RS8600 Firmware name: PIONEER BDR-209 Firmware type: Original (unpatched) Firmware version: 1.33/ID61 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
Thanks in advance!
MicAel1
Thanks, this worked flawlessly! I used Windows 10 in Gnome Boxes and simply forwarded the USB adapter (JMicron JMS583Gen 2 to PCIe Gen3x2 Bridge) to the VM.
Result:
I also succesfully ripped the first UHD disk that caused me some issues on the previous drive (one of these slimline Verbatim ones).
Result:
OS device name: /dev/sr1
Product: BD-RW BDR-S11
Revision: 1.53
Firmware date: 2020-08-03
Drive platform: RS8800
Firmware name: PIONEER BDR-211
Firmware version: 1.53/ID43
Unrestricted read speed: Yes-
acs871
Please assist with the upgrade of Pioneer drive to read UHD.
OS device name: E:
Product: BD-RW BDR-209M
Revision: 1.50
Serial number: QLDL********
Firmware date: 2017-12-21
Drive platform: Pioneer RS8601
Firmware version: ID60
OS device name: E:
Revision: 1.50
MinistryOfMagic
Hi, can someone please help me activate Libredrive and UHD (if possible) with the following drive.
Product: BD-RW BDR-XD08U
Revision: 1.02
Serial number: DHDL********
Firmware date: 2022-12-27
Drive platform: Pioneer RS9331
Firmware version: ID05
Revision: 1.02
Last edited by MinistryOfMagic on Sat Nov 22, 2025 1:47 am, edited 1 time in total.
This should already be enabled. As it is not, you need to download the latest SDF.bin and put it in the MakeMKV data directory. Restart MakeMKV and it should be absorbed in to _private_data.tar and the drive should be libredrive enabled.MinistryOfMagic wrote: Sat Nov 22, 2025 1:10 am Hi, can someone please help me activate Libredrive and UHD (if possible) with the following drive.
Revision: 1.02
Serial number: DHDL006091UC
PM sent.acs871 wrote: Fri Nov 21, 2025 3:37 pm Hi,
OS device name: E:
Revision: 1.50
daerelas
May I please ask as well for help in getting this to work? Here is my MakeMKV info:
OS device name: F:
Revision: 1.31
Serial number: OHDL********
Firmware date: 2015-05-25
Firmware version: 1.31/ID60
OS device name: F:
Revision: 1.31
PM sent.daerelas wrote: Sat Nov 22, 2025 9:26 pm May I please ask as well for help in getting this to work? Here is my MakeMKV info:
OS device name: F:
Revision: 1.31
acs871
Thank you very much. UHD's are being read.Coopervid wrote: Sat Nov 22, 2025 12:24 pmPM sent.acs871 wrote: Fri Nov 21, 2025 3:37 pm Hi,
OS device name: E:
Revision: 1.50
BrantleyF
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: DIDL1*******
Firmware date: 2020-07-21
Drive platform: RS8F00
Firmware version: E113/ID76
With thanks in advance
Brantley
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Brantley
PM sent.BrantleyF wrote: Tue Nov 25, 2025 2:56 pm Hi,
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Brantley
Apollo821
Hello, friends!
I've got an XD08...is this flashable or otherwise upgradeable to rip UHDs? I'm a little lost.
Revision: 1.02
Serial number:
Highest AACS version: 60
Drive platform: RS9330
Firmware name: PIONEER BDR-BDS8
Firmware version: 1.02
Revision: 1.02
Serial number:
No. The firmware is post 11/2022 and cannot be cross-flashed at this stage. You will have to wait for possible future cross-flash support.Apollo821 wrote: Wed Nov 26, 2025 1:52 am Hello, friends!
Revision: 1.02
Serial number:
