Mayor of Kingstown
Toaster
Mayor of Kingstown
Post by Toaster » Mon Nov 24, 2025 11:45 pm
Hi everyone, new here so I'm sorry if this has all been covered somewhere else. Can anyone suggest anything to resolve the following issue(s), please? Please let me know if I need to add anything regarding the info posted here. Is it a lost cause? Is there maybe a roundabout way? Many Thanks in advance.
AACS version: 77
MakeMKV v1.18.2 win(x64-release) started
File 00055.mpls was added as title #0
File 00056.mpls was added as title #1
File 00057.mpls was added as title #2
File 00086.mpls was added as title #3
File 00058.mpls was added as title #4
File 00060.mpls was added as title #5
File 00095.mpls was added as title #6
File 00094.mpls was added as title #7
File 00061.mpls was added as title #8
File 00062.mpls was added as title #9
File 00063.mpls was added as title #10
File 00073.mpls was added as title #11
File 00064.mpls was added as title #12
File 00066.mpls was added as title #13
File 00087.mpls was added as title #14
File 00067.mpls was added as title #15
File 00068.mpls was added as title #16
File 00072.mpls was added as title #17
File 00071.mpls was added as title #18
File 00070.mpls was added as title #19
File 00069.mpls was added as title #20
File 00074.mpls was added as title #21
File 00075.mpls was added as title #22
File 00076.mpls was added as title #23
File 00077.mpls was added as title #24
File 00078.mpls was added as title #25
File 00079.mpls was added as title #26
File 00080.mpls was added as title #27
File 00081.mpls was added as title #28
File 00093.mpls was added as title #29
File 00082.mpls was added as title #30
File 00083.mpls was added as title #31
File 00059.mpls was added as title #32
File 00084.mpls was added as title #33
File 00085.mpls was added as title #34
File 00088.mpls was added as title #35
File 00089.mpls was added as title #36
File 00091.mpls was added as title #37
File 00092.mpls was added as title #38
File 00090.mpls was added as title #39
File 00096.mpls was added as title #40
File 00097.mpls was added as title #41
File 00098.mpls was added as title #42
File 00065.mpls was added as title #43
File 00099.mpls was added as title #44
File 00054.mpls was added as title #45
File 00800.mpls was added as title #46
File 00801.mpls was added as title #47
File 00802.mpls was added as title #48
File 00020.mpls was added as title #49
File 00804.mpls was added as title #50
File 00000.m2ts was added as title #51
Title #01007.m2ts has length of 0 seconds which is less than minimum title length of 1 seconds and was therefore skipped
File 01008.m2ts was added as title #52
File 01009.m2ts was added as title #53
File 01010.m2ts was added as title #54
File 01011.m2ts was added as title #55
File 00051.m2ts was added as title #56
File 00053.m2ts was added as title #57
File 01084.m2ts was added as title #58
File 01085.m2ts was added as title #59
File 01086.m2ts was added as title #60
File 01087.m2ts was added as title #61
File 01089.m2ts was added as title #62
File 01090.m2ts was added as title #63
File 01091.m2ts was added as title #64
File 01093.m2ts was added as title #65
Saving 66 titles into directory C:/Users/Toast/OneDrive/Desktop
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/01065.m2ts' at offset '6374031360'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom2' at offset '6374031360'
Failed to save title 46 to file C:/Users/Toast/OneDrive/Desktop/Mayor of Kingstown - Season 1 - Disc 1_t46.mkv
Toaster
Re: Mayor of Kingstown
Post by Toaster » Tue Nov 25, 2025 12:06 am
I've never had issues with this external blu-ray player before. Is it worth purchasing another one and trying? What kind would anyone recommend, please?
Post by dcoke22 » Tue Nov 25, 2025 2:00 pm
An error like this:
means the optical drive was unable to correctly read the data at a spot on the disc. The standard advice is to gently clean the disc and try again.
Toaster
Post by Toaster » Tue Nov 25, 2025 10:23 pm
An error like this:
Yes, I have tried gently washing the blu ray but same errors have come up again.
