MartyMcNuts wrote: Thu Nov 27, 2025 1:12 am
Rogim807 wrote: Wed Nov 26, 2025 11:09 pm
Hey Marty!
I've got a Verbatim 43888 That shows up as a Pioneer BRD-UD04. It hasn't been able to read any of the UHD disks that i've try to rip using it thus far. When I use the SDFtool Flasher to flash it to the BU40N_1.03_MK (22 Nov 2025) it gives me the "the drive you have selected does not have the correct drive platform (MT1959) and cannot be flashed" error. Not sure what to do!
Manufacturer: PIONEER
Product: BD-RW BDR-UD04
Revision: 1.14
Serial number:
Firmware date: 2020-06-15
Highest AACS version: 82
Drive platform: RS8A10
Firmware version: 1.14
Your drive is a Pioneer!! It is already UHD ready. There's no flashing it.
If it won't read UHD discs you have another issue.
1. Clean the discs
2. Always ensure you insert the disc and let the OS initialise it before opening MakeMKV.
3. Ensure the drive is getting enough consistent power. Use a USB-C port if possible, direct from the motherboard or USB 3+ ports direct from the motherboard, otherwise use an AC self-powered USB hub of at least 30w. Do not use case ports.
4. Ensure MakeMKV has internet access as it needs to be able to download the UHD hashed keys.
Try pasting MakeMKV's log window text when you attempt to rip a UHD disc.
Hokay!
1- done!
2- done!
3- plugged into motherboard USB 3.0
4- I think i'm not getting the update
MakeMKV v1.18.2 win(x64-release) started
Downloading latest SDF to D:/Video ...
Automatic SDF downloading is disabled or failed.
Using LibreDrive mode (v01.0 id=489CDFD6D392)
Downloading latest HK to D:/Video ...
Saved AACS dump file as D:/Video/MKB20_v76_Space_Jam-_A_New_Legacy_D785.tgz
