Pioneer BDR-S13UBK Stopped Working
creator
Post by creator »
Hey everyone. Last night my Pioneer drive stopped ripping blu-rays. Directly before it stopped working, I upgraded to Windows 11 and to MakeMKV 1.18.2. Before I updated, the highest AACS version was 82, but that wasn't either of the most recent disks (the last working disk was 36 and the first non-working disk was 50). Anyone have any insight on what might be causing this issue?
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-S13U
Revision: 1.05
Serial number: xxxxxxxx
Firmware date: 2023-08-01
Highest AACS version: 36
Drive platform: RS9201
Firmware name: PIONEER BDR-213T
Firmware version: 1.05/ID43
And here is an example that keeps repeating from the log:
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom1'
DEBUG: Code 0 at -J6231Kpvy%-_GfBo:213130306
001003:0020 DEBUG: Code 0 at JP0V,W`B0e43*0h<e5:121264395
001003:0020 DEBUG: Code 1 at JP0V,W`B0e43*0h<e5:213130789
002004:0000 Error 'Scsi error - HARDWARE ERROR:INTERNAL TARGET FAILURE' occurred while issuing SCSI command A30..00200740100720..01BD162D532A433C08779091761DA503A76 to device 'SPTI:\Device\CdRom1'
001003:0020 DEBUG: Code 0 at -J6231Kpvy%-_GfBo:213130766
001003:0020 DEBUG: Code 0 at JP0V,W`B0e43*0h<e5:121263429
... which eventually, gives
003306:0000 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
Re: Pioneer BDR-S13UBK Stopped Working
Post by mike admin »
Just reboot the drive - viewtopic.php?p=186821#p186821
creator
Post by creator »
mike admin wrote: Sun Nov 23, 2025 10:51 pm Just reboot the drive - viewtopic.php?p=186821#p186821
Thanks for your response. Unfortunately, rebooting does not resolve the issue. I'm not sure if these messages are helpful, but this is what appears when MakeMKV is Scanning CD-ROM devices:
DEBUG: Code 3221225486 at baW0c/YZ^K,K|GTtwEpS:213130582
DEBUG: Code 4279394306 at ^\4O;l[]cZAB>C:7o:121264878
DEBUG: Code 4278603778 at ^\4O;l[]cZAB>C:7o:121264878
Eventually the disk shows up. But then the errors from my original post appear during the Decrypting phase.
WithoutRhythm
Post by WithoutRhythm »
Have you had any luck here? My BDR-S13U has also stopped working and is giving the following errors.
When first booting up, multiple lines of this:
DEBUG: Code 4279394306 at jQZW11fA"<#iHILp2:121264878
When attempting to access a blu ray:
Error 'Scsi error - HARDWARE ERROR:INTERNAL TARGET FAILURE' occurred while issuing SCSI command A30..00200740100720..0C5B80A48CD82035D5163B1B1B530AE1429 to device 'IoKit:/IOBDServices/0C9E1063'
DEBUG: Code 0 at 0~>lvnm&`B9&Di+|]:213130766
DEBUG: Code 0 at vU*<C%q5k#OFKC6+`K:121263429
DEBUG: Code 0 at vU*<C%q5k#OFKC6+`K:213130789
I've installed the latest SDF.bin (I'm on a Mac), I've rebooted, power cycled, etc. and cannot get any blu rays to open properly anymore. This drive was purchased just this summer and was working great up until a couple months ago when it suddenly started throwing these errors (it's in the MercuryPro enclosure recommended by Billy as well).
In case it's useful, here's the drive information:
OS device name: /dev/rdisk4
Revision: 1.05
Serial number: xxxxxxxxxxxx
Highest AACS version: 82
WithoutRhythm
WithoutRhythm wrote: Wed Dec 24, 2025 9:02 am Have you had any luck here? My BDR-S13U has also stopped working and is giving the following errors.
Revision: 1.05
Just an update on this in case anyone else runs into this issue. I was able to get my drive working by deleting my _private_data.tar file and disabling internet updates in MakeMKV's preferences. I suspect something about the new sdf.bin is not playing nicely with my drive and causing all those problems.
VECT0R
Post by VECT0R »
I am in the same boat for a Pioneer BDR-S12U and BDR-S13UBK the above fix (deleting _private_data.tar and setting to offline) did not work. I have also tried cleaning the disks (though all of them are brand new out of the packaging) and the readers. I have tried multiple USB ports and both my Linux and MacOS machines. Functionally the same issues regardless of configuration, number of restarts, reader power cycles, etc. Any help would be appreciated.
Issues when initially reading Blu-Rays:
DEBUG: Code 4279394306 at T{^&lxG%XM81Xv^(-:121264878
DEBUG: Code 4278603778 at T{^&lxG%XM81Xv^(-:121264878
Issues when attempting direct access:
Error 'Scsi error - NOT READY:MEDIUM NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0299B6541B3BA7CEB741857B7D883DD0E73 to device 'IoKit:/IOBDServices/956129E2'
DEBUG: Code 0 at y9yb`|da)(\XIm9jU:213130766
DEBUG: Code 0 at @}C}Kv6i=|1VVrx@<F:121263429
DEBUG: Code 0 at @}C}Kv6i=|1VVrx@<F:213130789
Error 'Scsi error - HARDWARE ERROR:INTERNAL TARGET FAILURE' occurred while issuing SCSI command A30..00200740100720..06CFBCDC1F791C0E859CAD129EA1C623BF1 to device 'IoKit:/IOBDServices/956129E2'
DEBUG: Code 1 at @}C}Kv6i=|1VVrx@<F:213130789
Error 'Scsi error - HARDWARE ERROR:INTERNAL TARGET FAILURE' occurred while issuing SCSI command A30..00200740100720..06FC318FCA520A7FAB36716B23DB05EEA3B to device 'IoKit:/IOBDServices/956129E2'
DEBUG: Code 2 at @}C}Kv6i=|1VVrx@<F:213130789
Error 'Scsi error - HARDWARE ERROR:INTERNAL TARGET FAILURE' occurred while issuing SCSI command A30..00200740100720..047096E18C8D715DB163B43B69115D48E89 to device 'IoKit:/IOBDServices/956129E2'
DEBUG: Code 3 at @}C}Kv6i=|1VVrx@<F:213130789
Error 'Scsi error - HARDWARE ERROR:INTERNAL TARGET FAILURE' occurred while issuing SCSI command A30..00200740100720..023BB410FD5F8AC402DAC05E15AE8E271E6 to device 'IoKit:/IOBDServices/956129E2'
DEBUG: Code 4 at @}C}Kv6i=|1VVrx@<F:213130789
The direct access attempt will continue forever as far as I can tell. When I manually direct it to stop I get:
DEBUG: Code 0 at f^[`{]=&]1>A-`Qm:121267063
DEBUG: Code 0 at 9KC1[0}=n;Lz) >~:213132721
DEBUG: Code 0 at 9KC1[0}=n;Lz) >~:213131341
VECT0R wrote: Sun Mar 08, 2026 7:09 pm I am in the same boat for a Pioneer BDR-S12U and BDR-S13UBK the above fix (deleting _private_data.tar and setting to offline) did not work. I have also tried cleaning the disks (though all of them are brand new out of the packaging) and the readers. I have tried multiple USB ports and both my Linux and MacOS machines. Functionally the same issues regardless of configuration, number of restarts, reader power cycles, etc. Any help would be appreciated.
try cleaning the laser
VECT0R
Post by VECT0R »
I went out and got a Maxell Maxlink lens cleaning disc. Ran it through both drives. I am still getting the same issues. Is there another way to clean the drive? Any alternatives if cleaning isn't the answer?
I appreciate the help!
VECT0R wrote: Mon Mar 23, 2026 8:48 pm I went out and got a Maxell Maxlink lens cleaning disc. Ran it through both drives. I am still getting the same issues. Is there another way to clean the drive? Any alternatives if cleaning isn't the answer?
  eject tray
unplug drive with tray out
pop off front bezel clips on sides and bottom with plastic tool
undo screws from bottom will be under stickers if you have an s13, 213 does not have stickers.
flip backover and remove top cover
clean lasers with a lint free cloth or qtip and alcohol and dry with another do this 2 times and do not let it air dry you must remove the residue with a dry one!
VECT0R
Post by VECT0R »
Apologies for the long delay; life got in the way of pulling the drives apart to clean them.
I was able to disassemble both and clean the lenses using 91% isopropyl alcohol and qtips following your instructions for application and drying.
Both drives are still getting stuck in the DEBUG and Error 'Scsi error - HARDWARE ERROR:INTERNAL TARGET FAILURE' loop. If I let them run long enough they will thrown an exception and crash.
I would appreciate any further troubleshooting steps!
VECT0R wrote: Fri Apr 10, 2026 12:23 am Apologies for the long delay; life got in the way of pulling the drives apart to clean them.
are they internal or external maybe the psu is not giving enough power kinda strange i usually dont see that on pioneers
VECT0R
Post by VECT0R »
Externally mounted using a OWC Mercury Pro enclosure. Powered directly from the wall. The only weak link I can think of on the connection side is that I am using an OWC dock (since I don't have a USB-B to USB-C cable for my laptop).
Connection flowchart (Power):
120v AC wall outlet -> Enclosure
Connection flowchart (Data):
Blu-Ray -> Pioneer BDR -> Enclosure -> OWC Dock -> Laptop
VECT0R wrote: Fri Apr 10, 2026 3:26 am Externally mounted using a OWC Mercury Pro enclosure. Powered directly from the wall. The only weak link I can think of on the connection side is that I am using an OWC dock (since I don't have a USB-B to USB-C cable for my laptop).
try direct sata to a pc to rule out the case
OneDay
Post by OneDay »
This is what happened to me when I had my OWC connected to a dock/hub that is powered from a wall plug. I thought my my drive was dying or was dead. When I bypassed the dock/hub and plugged the OWC directly to my laptop it work just fine. I guess the OWC is very sensitive.
I've been using this and haven't had any issues. Only issue I have with it is the cable is to short. It needs to be 2 to 3 inches longer. - BENFEI SATA to USB 3.0 Cable, USB 3.0 to SATA III Hard Drive Adapter Compatible for 2.5 3.5 Inch HDD/SSD Hard Drive Disk with 12V/2A Power Adapter, Support UASP ( https://a.co/d/0dwTAcRQ )
VECT0R
Post by VECT0R »
I appreciate the recommendation! I don't have the cables required to go direct to my computer. I'll update once they've arrived and I've tested the drives again.
