ASUS BW-16D1X-U Wanting To Play UHD/4K Discs
SpencerParsnips
Post by SpencerParsnips » Sun Nov 23, 2025 7:24 pm
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: DHDL119170WL
Firmware date: 2020-07-21
Highest AACS version: 81
Drive platform: RS8F00
Firmware version: E113/ID76
How do I go about flashing this drive so i can read 4k discs on makemkv? The Platform isnt MT1959, but another post said that with RS8F00 it is possible to flash. Thanks! :D
Re: ASUS BW-16D1X-U Wanting To Play UHD/4K Discs
Post by Billycar11 » Sun Nov 23, 2025 10:29 pm
Just email me that drive info section see below
SpencerParsnips
Post by SpencerParsnips » Sun Nov 23, 2025 11:15 pm
email sent!
Post by Billycar11 » Thu Nov 27, 2025 5:08 am
SpencerParsnips wrote: Sun Nov 23, 2025 11:15 pm email sent!
replied but your emails full got bounced back
SpencerParsnips
Post by SpencerParsnips » Thu Dec 25, 2025 8:33 pm
re-sent you an email under the email spencersparsnips@gmail.com, thanks.
Battlecat167#
Post by Battlecat167# » Sat Jan 17, 2026 4:57 am
I also purchased a ASUS BW-16D1X-U. Have you successfully got it working with the MakeMKV? I would also like to flash the drive. Does anyone have any information on a link to where I can download the install the flash? Thank you in advanced.
Post by Billycar11 » Sat Jan 17, 2026 4:59 am
Battlecat167# wrote: Sat Jan 17, 2026 4:57 am I also purchased a ASUS BW-16D1X-U. Have you successfully got it working with the MakeMKV? I would also like to flash the drive. Does anyone have any information on a link to where I can download the install the flash? Thank you in advanced.
depends if its a pioneer or lg inside the asus case
if is lg email me or marty
if its pioneer email me the drive info see below for contact details
Battlecat167#
Post by Battlecat167# » Sat Jan 17, 2026 5:20 am
Thank you for the prompt response. I'm not sure how I can tell as this is an external drive and it is enclosed . Looks like it was manufactured September of 2025. So, I can't tell. But the info screen on MakerMKV says:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Serial number: KLNP4I94155
Firmware date: 2120-12-02 11:14
Bus encryption flags: 1F
Post by Billycar11 » Sat Jan 17, 2026 5:23 am
Battlecat167# wrote: Sat Jan 17, 2026 5:20 am Thank you for the prompt response. I'm not sure how I can tell as this is an external drive and it is enclosed . Looks like it was manufactured September of 2025. So, I can't tell. But the info screen on MakerMKV says:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
its an lg see guide below or get the auto flasher from me or Marty
