Pioneer BDR 208
AvidUser101
Pioneer BDR 208
Hello, can my Pioneer BDR 208D be flashed?
Manufacturer: PIONEER
Product: BD-RW BDR-208D
Revision: 1.50
Serial number:
Firmware date: 2015-09-24
Bus encryption flags: 13
Highest AACS version: 66
Drive platform: RS8301
Firmware name: PIONEER BDR-208
Firmware version: 1.50/ID61
Revision: 1.50
Serial number:
Re: Pioneer BDR 208
Sure email me that drive info section see below for emailAvidUser101 wrote: ↑Mon Oct 27, 2025 7:03 amHello, can my Pioneer BDR 208D be flashed?
Revision: 1.50
Serial number:
Re: Pioneer BDR 208
I have the Pioneer BDR-208DBK, and would like to have it flashed too. Just started my 4K/BD archiving journey. My drive specs from MakeMKV are below:
Revision: 1.50
Serial number:
Thanks for all your work!
Revision: 1.50
Serial number:
Re: Pioneer BDR 208
PM sent.SeanSa wrote: ↑Sat Nov 08, 2025 7:47 pmI have the Pioneer BDR-208DBK, and would like to have it flashed too. Just started my 4K/BD archiving journey. My drive specs from MakeMKV are below:
Revision: 1.50
Serial number:
Re: Pioneer BDR 208
Thank you so much Coopervid!
Drive is working great and making my archive! I am truly grateful!
Just for my knowledge, the Pioneer 208D drive so far max reads at 4X with the new firmware when ripping, so far on the 4K discs I've archived. Is this the max read speed for 4K discs on MakeMKV, for the 208D drive on this firmware?
Re: Pioneer BDR 208
4x is the max for UHD on all Pioneer drives.SeanSa wrote: ↑Mon Nov 10, 2025 3:20 amThank you so much Coopervid!
Re: Pioneer BDR 208
Got it. Thanks!
I was wondering about this drive as I've seemed to find an issue with it MakeMKV.
Tried an encrypted & decrypted rip of a regular Blu-ray disc, no problem.
Tried an encrypted rip of a UHD disc, no problem.
When I attempt a decrypted rip of a UHD disc, they all come with the error,
"The volume key is unknown for this disc - video can't be decrypted. Backup failed."
I was trying to read the forums for a solution, but it's not entirely clear how to use the 'discatt.dat' file, and how to decrypt an encrypted copy I already made, and what I am supposed to do on MakeMKV to accomplish this. How do I overcome this issue so I be able to play or edit/convert the video files on say Handbrake?
Re: Pioneer BDR 208
Read the Hashed Keys section of the UHD FAQ.SeanSa wrote: ↑Mon Nov 10, 2025 2:18 pmGot it. Thanks!
Tried an encrypted & decrypted rip of a regular Blu-ray disc, no problem.![]()
Tried an encrypted rip of a UHD disc, no problem.![]()
Re: Pioneer BDR 208
Hi I also have a Pioneer BDR-208D. Is this drive able to be flashed to read UHD Blu-Ray? What's the process involved, if so? I am new to the forum and am thankful for any help.
Re: Pioneer BDR 208
I've a problem with a BDR-208DBK which isn't firmware specific.
It opens the tray after pressing the button only with disc inside. Without disc it trys to unlock but without success. When I use the emergency opening only to unlock and press the button the try opens and close without a problem also.
I've not so much expierience to comprehend the several mechanic connections. I can push manually the white slider which is moving the laser plattform and opens the tray.
This part also is pushing a little blue slider? Is the problem to find there?
What can I do?
What can I do?
Re: Pioneer BDR 208
It's either a mechanical problem that the tray is obstructed somewhow or the switch for opening has a problem. If you depress the button the tray has to open regardless if a disc is in the drive or not. Only the other way around it is possible that if certain software uses the disc in the drive that the opening button can be blocked. Try to depress the button from several angles and if it tries to open but can not, try to move the tray from the outside with a little screwdriver up, down or sideways. Report back.zittrig wrote: ↑Tue Jan 20, 2026 7:47 amI've a problem with a BDR-208DBK which isn't firmware specific.
What can I do?
Re: Pioneer BDR 208
Thanks Coopervid, I'll try it tomorrow and report back after this.
Re: Pioneer BDR 208
Not a chance without a disc insideCoopervid wrote: ↑Tue Jan 20, 2026 10:58 amIt's either a mechanical problem that the tray is obstructed somewhow or the switch for opening has a problem. If you depress the button the tray has to open regardless if a disc is in the drive or not. Only the other way around it is possible that if certain software uses the disc in the drive that the opening button can be blocked. Try to depress the button from several angles and if it tries to open but can not, try to move the tray from the outside with a little screwdriver up, down or sideways. Report back.zittrig wrote: ↑Tue Jan 20, 2026 7:47 amI've a problem with a BDR-208DBK which isn't firmware specific.
What can I do?
Bad luck.
