Failed to save title 0 to file
borgijoe
Post by borgijoe »
Just downloaded and installed MakeMKV BETA and I am getting the following problem:
The application reads the unenencrypted Blu-Ray disc ok (XMen 3) but when I press the Make MKV button I get the following message:
MakeMKV v1.4.6 beta win(x86-release) started
AACS directory not present, assuming unencrypted disc
File 00000.mpls was added as title #0
Operation sucessfully completed
Saving 1 titles into directory K:/Video/XMEN3_F1
Failed to save title 0 to file K:/Video/XMEN3_F1/title00.mkv
0 titles saved, 1 failed
Please help.
Re: Failed to save title 0 to file
Post by mike admin »
This error is most likely due to an incorrectly mastered blu-ray disc. In order to confirm, please open preferences dialog, enable "log debug messages", restart the program, try to open these files again and post the produced log here.
WobbelPobbel
Post by WobbelPobbel »
I can confirm this error (Bug?). As long as the Bluray files on harddisk use an VC-1 video stream, everything ist fine.
As soon as the video in the m2ts file is encoded in AVC the error message appears and the mkv creation aborts.
This is correct. Blu-ray discs must contain AccessUnit NAL units in AVC video stream. Re-encoded "pirate blu-rays" often lack this information and MakeMKV fails on them.
tkpittman
Post by tkpittman »
I had this error a couple of times. Each time I rebooted my pc and wiped off the disc and tried again. Each time it worked fine after that.
tkpittman
Post by tkpittman »
I get the failed to save title 0 to file everytime with Bluray disc First Blood;
Log file.
Debug log started at Fri Nov 13 00:54:21 2009 , written by MakeMKV v1.4.8 beta win(x86-release)
001014:000000:0000 MakeMKV v1.4.8 beta win(x86-release) started
001013:000000:0000 Debug logging enabled, log will be saved as C:\Documents and Settings\Todd/MakeMKV_log.txt
003010:000000:0000 Using direct disc access mode
003310:000000:0000 AACS directory not present, assuming unencrypted disc
003020:000000:0000 Title #00000.mpls has length of 80 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003316:000000:0000 Only extracting DTS core audio from stream #2 of type 'DTS-HD audio' in file 00001.m2ts
003313:000000:0000 File 00001.mpls was added as title #0
003313:000000:0000 File 00012.mpls was added as title #1
003020:000000:0000 Title #00000.m2ts has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00003.m2ts has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00004.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003313:000000:0000 File 00005.m2ts was added as title #2
003020:000000:0000 Title #00006.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003313:000000:0000 File 00009.m2ts was added as title #3
003313:000000:0000 File 00010.m2ts was added as title #4
003020:000000:0000 Title #00015.m2ts has length of 119 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00016.m2ts has length of 112 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00018.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005011:000000:0000 Operation sucessfully completed
005014:000000:0000 Saving 1 titles into directory C:/Video
001012:000000:0020 FAILURE: Code 49 at 1fXrukp|B?%VDS)|Cv5:213133365
FS ID=V_MPEG4/ISO/AVC C=49
001012:000000:0020 FAILURE: Code 0 at &]vQ?j]):Kn4LyoN5S0Cl:121264211
001011:000000:0020 LIBMKV_TRACE: Exception: Error while reading input
005003:000000:0000 Failed to save title 0 to file C:/Video/title00.mkv
005004:000000:0000 0 titles saved, 1 failed
005037:000000:0204 Copy complete. 0 titles saved, 1 failed.
it looks like something is wrong with an mpeg-4 video stream. to diagnose we would need to look at actual video frames that cause the problem but it looks like 49 lines with this information were removed from a log file.
tkpittman
Post by tkpittman »
attached is the entire log file
I have even tried ripping the bluray to the hard drive and then running makemkv from the hard drive but I get the same error.
It errors at the exact same part (as soon as the mkv file gets to 230mb it errors and stops).
I have tried 2 different First Blood bluray discs.
Other discs work fine.
Thanks for any assistance.
